OWS-1636LA-8B
OWS-1636LA-8B
    OLEWOLFF
    8 Ohms 通用 扬声器 500 mW 100 Hz ~ 20 kHz 顶部 圆形
OWS-1636LA-8B 数据手册
Date Page 17-Aug-2021 1/8 DK P/N: OWS-1636LA-8B OLE WOLFF www.owolff.com Revision: A SPECIFICATION SPECIFICATION FOR APPROVAL Speaker Part Number OWS-1636LA-8B This item was compliance with the following requirements: 1. RoHS directive 2. REACH Note Customer P/N Prepared Signature / Date Ole Wolff Checked Approved TANQIANFENG 21.08.17 Confirmation Signature / Date Customer REVISION NOTES: Date Rev. 2021.08.17 A OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 Description of Revision Initial release OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 2/8 DK P/N: OWS-1636LA-8B OLE WOLFF www.owolff.com Revision: A SPECIFICATION 1. SCOPE THIS SPECIFICATION IS APPLIED FOR A DYNAMIC SPEAKER. 2. TEST CONDITIONS TEMPERATURE : 15°C  35°C HUMIDITY : 45%85% (R.H.) ATMOSPHERE : 860  1060 hPa 3. GENERAL REQUIREMENTS OPERATING TEMPERATURE RANGE: -25°C  60°C STORAGE TEMPERATUR RANGE: -25°C  60°C 4. MECANICAL LAYOUT & DIMENSIONS DIMENSIONS : SHOWN IN FIGURE.5 NET WEIGHT: approx 1.3+/-0.5g 5. ELECTRICAL AND ACOUSTICAL CHARACTERISTICS 1 Resonance Frequency 900± 20% 2 Impedance 8 ± 15% (at 4KHz/1.55V) 3 Sensitivity 4 Input Power (Nom./Max.): 0.5 W / 0.8 W 5 Frequency Response Shown in fig.2 6 7 Total Harmonic Distortion (THD) Buzz & Rattle OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 Hz/0.3W(1.55V) input power 94±3 dB AT 1KHz 0.3W(1.55V)/0.1m Shown in Fig.2 THD shown in fig.3 2.0V 400~10KHz OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 3/8 DK P/N: OWS-1636LA-8B OLE WOLFF www.owolff.com Revision: A SPECIFICATION 6. RELIABILITY TEST REQUIREMENTS. After any following tests the S.P.L should not deviate more than ± 3dB from initial value. No. ITEMS TEST CONDITION 1. High temp. Test Keep 96 hours at +60℃± 3℃ and leave 3 hours in normal temperature and then check 2. Low temp. Test Keep 96 hours at -25℃± 3℃ and leave 3 hours in normal temperature and then check 3. Humidity test Keep 96 hours at + 40℃± 3℃ relative humidity 90~95% and leave 3 hours in normal temperature and then checked. 4. Thermal cycle test. Low temperature: -30℃± 3℃, temperature:+60℃± 3℃, cycle: 2 hour/cycle each, and then keep 5 cycles in a room. 5. Vibration Frequency:50Hz/min Amplitude:1.5mm X,Y,Z 3 direction.2 hours each, total 6 hours. 6. Drop test(for sample) Height:1m Total times:10 times 7. Drop test(for package) The speaker shall be fixed in cabinet, packed with carton and dropped 1m height vertically to 10cm wooden board.( one point ,three corners ,six sides. 1 times each, total 10 times.) 8. Load test Rated Power Pink noise is applied for 96 hours 9. MAX. SHORT TERM POWER TEST Max power Sine wave 1sec ON, 1min OFF, 60cycles . OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 4/8 DK P/N: OWS-1636LA-8B OLE WOLFF www.owolff.com Revision: A SPECIFICATION 7. ELECTRICAL CHARACTERISTICS MEASURMENT (FIGURE.1) 10cm OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 5/8 DK P/N: OWS-1636LA-8B OLE WOLFF www.owolff.com Revision: A SPECIFICATION 8. STANDARD FREQUENCY RESPONSE CURVE(Fig.2) Test condition:1.55Vrms/10cm 1/6OCTIVE Hz 900 ... 1000 ... 5000 ... 8000 dB (Up) +6 +6 +3 +5 +6 +6 +7 Hz 900 ... 1000 ... 5000 ... 8000 dB (Down) -6 -6 -3 -5 -5 -6 -7 9. STANDARD THD CURVE(Fig.3) Test condition:1.55Vrms/10cm 1/6OCTIVE Hz 1000 1400 8000 THD% (Up) 15 10 10 OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 6/8 DK P/N: OWS-1636LA-8B SPECIFICATION OLE WOLFF www.owolff.com Revision: A 10. IMPEDANCE RESPONSE CURVE(fig.4) Test condition:1.55Vrms/10cm 1/6OCTIVE 11.OUTVIEW (Fig.5) Unless otherwise specified,tolerance:±0.2(unit:mm) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 7/8 DK P/N: OWS-1636LA-8B SPECIFICATION OLE WOLFF www.owolff.com Revision: A 12.MARKING(Fig.6) YEAR OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 WEEK year marking week marking 2015 5 1 01 2016 6 2 02 2017 7 3 03 2018 8 4 04 2019 9 5 05 2020 0 2021 1 2022 2 50 50 51 51 52 52 53 53 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 17-Aug-2021 8/8 DK P/N: OWS-1636LA-8B SPECIFICATION OLE WOLFF www.owolff.com Revision: A 13.PACKING(Fig. 7) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156
OWS-1636LA-8B 价格&库存
很抱歉,暂时无法提供与“OWS-1636LA-8B”相匹配的价格&库存,您可以联系我们找货
