ESP32-POE
ESP32-POE IOT DEVELOPMENT BOARD WITH 100MB ETHERNET, POWER OVER ETHERNET, WIFI, BLE,
PROGRAMMER
ESP32-POE-EA
ESP32-POE is OSHW certified Open Source Hardware with UID BG000009
ESP32-PoE is an IoT WIFI/BLE/Ethernet development board with Power-Over-Ethernet feature. The Si3402-B chip is
IEEE 802.3-compliant, including pre-standard (legacy) PoE support. The board takes power from the Ethernet cable
and can be expanded with sensors and actuators. Perfect solution for Internet-of-Things projects.
Important notice: ESP32-POE has no galvano isolation from Ethernet's power supply, when you program the
board via the micro USB connector the Ethernet cable should be disconnected (if you have power over the Ethernet
cable)! Consider using Olimex USB-ISO to protect your computer and board from accidental short circuit. Also
consider instead using Olimex ESP32-PoE-ISO board which is insulated.
ESP32-POE-EA has module with U.FL connector and external antenna attached.
FEATURES
ESP32-WROOM-32 WiFi/BLE module
Ethernet 100Mb interface with IEEE 802.3 PoE support
LiPo battery charger
LiPo battery connector
UEXT connector
User button
Reset button
Micro USB with programmer for ESP32 programming
MicroSD card
Two extension connectors 0.1" step spaced at 1"
PCB dimensions: (75 x 28)mm ~ (3 x 1)"
DOCUMENTS
ESP32-POE latest schematic in PDF format
ESP32-POE connector signals
HARDWARE
ESP32-POE CAD files on GitHub
SOFTWARE
Demo software
Simple Ethernet demo for ESP-IDF
Works with default Arduino for ESP32
Simple Ethernet and SD card demo for Arduino
WIFI webserver and UEXT demo for Arduino
LCD demo with MOD-LCD2.8RTP
More Arduino examples at our GitHub pages
USB drivers:
USB driver for Windows
High-speed USB driver for Linux
USB driver for Linux (for old kernels; pre-3.14.x)
USB driver for Mac
USB driver for Android
NOTICE
Evaluation Board/Kit Important Notice
FAQ
ESP32-PoE doesn't work well with bauds over 115200. What to do?
Some older drivers might have wrong timings, causing worse throughput. Download and install the latest drivers for
CH340. If you are using Linux make sure to try with these drivers: high-speed driver for Linux
https://www.olimex.com/Products/IoT/ESP32/EP32-POE/open-source-hardware/6-20-19
很抱歉,暂时无法提供与“ESP32-POE-EA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+235.654331+30.63430
- 3+215.574603+28.02400
