ESP32-POE-ISO
ESP32-POE IOT DEVELOPMENT BOARD WITH 100MB ETHERNET, POWER OVER ETHERNET, WIFI, BLE,
PROGRAMMER
ESP32-PoE is an IoT WIFI/BLE/Ethernet development board with Power-Over-Ethernet feature. The Si3402-B chip is
IEEE 802.3-compliant, including pre-standard (legacy) PoE support. The board takes power from the Ethernet cable
and can be expanded with sensors and actuators. Perfect solution for Internet-of-Things projects.
ESP32-POE-ISO has 3000VDC galvanic insulation from Ethernet power.
ESP32-POE-ISO-EA has module with U.FL connector and external antenna attached, which allow mounting in metal
box.
FEATURES
ESP32-WROOM-32 - WiFi and bluetooth module
Low power design - 200uA consumption in deep sleep
Ethernet 100Mb interface with IEEE 802.3 PoE support
3000VDC galvanic insulation between the PoE Ethernet part and board's power supply circuit
Micro USB connector for ESP32 programming
MicroSD card working in 1 bit mode (3 more GPIOs)
LiPo battery charger with LiPo battery connector
Battery level monitor pin on ADC
External power supply detection pin on ADC
DC-DC 2W 5V/400mA
UEXT connector
User button
Reset button
Two extension connectors, 0.1" step spaced at 1"
PCB dimensions: (100 x 28)mm ~ (3 x 1)"
NOTICE
Evaluation Board/Kit Important Notice
DOCUMENTS
ESP32-POE-ISO latest schematic in PDF format
HARDWARE
ESP32-POE-ISO CAD files on GitHub
SOFTWARE
Demo software
Simple Ethernet demo for ESP-IDF
Works with default Arduino for ESP32
Simple Ethernet and SD card demo for Arduino
WIFI webserver and UEXT demo for Arduino
More Arduino examples at our GitHub pages
USB drivers
USB driver for Windows
High-speed USB driver for Linux
USB driver for Linux (for old kernels; pre-3.14.x)
USB driver for Mac
USB driver for Android
FAQ
ESP32-PoE-ISO doesn't work well with bauds over 115200. What to do?
Some older drivers might have wrong timings, causing worse throughput. Download and install the latest drivers for
CH340. If you are using Linux make sure to try with these drivers: high-speed driver for Linux
https://www.olimex.com/Products/IoT/ESP32/ESP32-POE-ISO/open-source-hardware/6-20-19
很抱歉,暂时无法提供与“ESP32-POE-ISO-EA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+341.007721+44.32990
- 3+320.927993+41.71960
- 10+279.8123510+36.37470
