MOD-WIFI-AR9271-ANT
MOD-WIFI-AR9271-ANT
    OLIMEX
    USB WIFI ADAPTER WHICH IS WITH O
MOD-WIFI-AR9271-ANT 数据手册
    MOD-WIFI-AR9271-ANT MOD-WIFI-AR9271-ANT IS USB WIFI ADAPTER WHICH IS WITH OPEN SOURCE LINUX DRIVER AND LINUX KERNEL BUILD IN SUPPORT SINCE KERNEL 2.6.35 AR9271 chipset uses free software drivers and firmware. Both the driver and the firmware of this adapter are free under the GNU GPL v2 and the 3-clause BSD licenses, respectively, and thus you can use it with a completely free GNU/Linux distribution, which has the kernel Linux-libre, clean of the nonfree blobs from Linux. The adapter works out of the box when plugging it on USB, and you don't have to manually install the firmware or drivers.   FEATURES          AR9271 chipset USB 2.0 2.4GHz 150Mbps MIMO configuration: 1x1 (1 txchain; 2 RX RF chains; 1 rx stream) IEEE 802.11 PHY Modes: b,g,n external antenna with excellent reception USB dongle size: 80x25x15 mm Antenna size 200 mm   Olimex © 1997-2016
MOD-WIFI-AR9271-ANT 价格&库存
很抱歉,暂时无法提供与“MOD-WIFI-AR9271-ANT”相匹配的价格&库存,您可以联系我们找货
