A24002-002
A24002-002
    OMNETICS
    2 位置矩形连 插座 连接器 焊杯 镀金
A24002-002 数据手册
PART NO. A 2 4 0 0 2 -0 0 2 M AT E R IAL S & S P E C IF I C AT IO N S INSULATOR: P O L Y P H E N Y L E N E S U L F ID E (P P S ) P E R M IL -M -2 4 5 1 9 , T Y P E G S T 40F. REV ECO DATE AP P B 103924 10-27 -1 7 TLM N O T E O R IE N T A T IO N CONTACT: B E R Y L L IU M C O P P E R P E R A S T M B194, C 17200. G O LD PLATED P E R A S T M B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 . .2 8 5 7 .2 4 TERMINATION: S O L D E R P L A T E D P E R A M S -P 81728. A C T U A L S IZ E L AT C H B O X : B E R Y L L IU M C O P P E R P E R A S T M B 1 9 4 N IC K E L P L A T E P E R S A E A M S -2 4 0 4 .1 7 4 .3 CU R R E N T C AP AC ITY: 3 A M P M AX. CON TACT RE S IS TAN CE: 2 6 M IL L IO H M S ( 6 5 m V ) M A X @ 2 .5 A M P S . PERFORMANCE: P R O D U C T F A M IL Y T E S T E D T O A N D PASSED THE PERFO RMANCE S P E C IF IC A T IO N S O F T A B L E V II O F M IL - D T L - 8 3 5 1 3 . BO N D E D 1 .1 0 M A X 2 .4 M A X .0 7 5 1 .9 1 (2 ) S P A C E S @ . 0 5 0 = .1 0 0 [1 .2 7 ] [2 .5 4 ] .0 3 5 0 .8 9 . 1 3 5 M AX 3 . 4 3 M AX NOTE: T H IR D A N G L E PS1 S L DW D IM E N S IO N S IN [ ] A R E IN M I L L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R REFER EN CE ON LY -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 CAG E CO DE DW G NO . T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . J M J CHK 'D. AP P 'D. DATE 03-29 -1 3 DATE DATE T I T LE : (2) PIN MALE SINGLE ROW CONNECTOR W/LATCH 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM 61873 A 2 4 0 0 2 -0 0 2 SHEET 1 OF 1 REV S C A L E : 4 :1 B
A24002-002 价格&库存
很抱歉,暂时无法提供与“A24002-002”相匹配的价格&库存,您可以联系我们找货
