A25000-012
A25000-012
    OMNETICS
    12 矩形电缆组件 插口至单条导线引线 1.50'(457.20mm)
A25000-012 数据手册
PART NO. M AT E R IAL S & S P E C IF I C AT IO N S INSULATOR: P O L Y P H E N Y L E N E S U L F ID E (P P S ) P E R M IL -M -2 4 5 1 9 , T Y P E G S T 40F. A 2 5 0 0 0 -0 1 2 REV ECO DATE AP P E 100283 02-12 -1 4 TLM .6 7 17 CONTACT: C O P P E R A L L O Y P E R M IL -D T L 83513, G O LD PLATED PER ASTM B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 . .0 7 5 1 .9 1 12 1 TERMINATION: 2 6 A W G (7 -3 4 ) T Y P E E , P E R NEM A H P3, CO LO R C O D ED PER TABLE . (1 2 ) S P A C E S @ . 0 5 0 = .6 0 0 [1 .2 7 ] [1 5 .2 4 ] LATCH: B E R Y L L IU M C O P P E R P E R A S T M B 1 9 4 N IC K E L P L A T E P E R S A E A M S -2 4 0 4 . A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H .0 3 5 0 .8 9 CU R R E N T C AP AC ITY: 3 A M P M AX. CON TACT RE S IS TAN CE: 2 6 M IL L IO H M S ( 6 5 m V ) M A X @ 2 .5 A M P S . . 1 2 6± . 0 1 0 3 . 2 0± 0 . 2 5 PERFORMANCE: P R O D U C T F A M IL Y T E S T E D T O AND PAS SED TH E PERFO R M AN CE S P E C I F IC A T I O N S O F T A B L E V II O F M IL -D T L -8 3 5 1 3 . SOCKET # CO L O R 1, 11 BLA C K 2, 12 BROW N 3 RE D 4 ORANGE 5 YELLOW 6 GRE E N 7 BLU E 8 VIOLET 9 GRAY 10 WHITE T H IR D A N G L E S L DW D IM E N S IO N S IN [ ] A R E IN M I L L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R REFER EN CE ON LY B R O W N B L A C K W H I T E G V B R I L A O U Y L E E T G R E E N Y E L L O W O R B B R E R L A D O A N W C G N K E + .3 8 - .0 0 + 9 .7 4 5 7 .2 0 1 8 .0 0 2 6 A W G (7 -3 4 ) PTFE, C O LO R C O D ED SSB NOTE: .1 2 5 3 .1 8 -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . P E R CHK 'D. AP P 'D. DATE 08-28 -02 DATE DATE T I T LE : (12) SOCKET FEMALE SINGLE ROW CONNECTOR W/ LATCH OMNETICS A 2 5 0 0 0 - 0 1 2 CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM CAG E CO DE DW G NO . 61873 SHEET 1 OF 1 REV S C A L E : 4 :1 E
A25000-012 价格&库存
很抱歉,暂时无法提供与“A25000-012”相匹配的价格&库存,您可以联系我们找货
A25000-012
  • 1+792.255091+102.99060
  • 10+673.4424310+87.54534
  • 25+631.3088625+82.06811
  • 50+601.2065450+78.15491
  • 100+572.54916100+74.42954
库存:44
