A25001-010
A25001-010
    OMNETICS
    10 位置矩形连 插头 连接器 焊杯 镀金
A25001-010 数据手册
PART NO. M AT E R IAL S & S P E C IF I C AT IO N S INSULATOR: P O L Y P H E N Y L E N E S U L F ID E (P P S ) P E R M IL -M -2 4 5 1 9 , T YP E G S T 40F . A 2 5 0 0 1 -0 1 0 REV ECO DATE AP P D 96884 0 7 -1 4 -1 0 T LM .5 7 1 4 .5 CONTACT: C O P P E R A L L O Y P E R M IL D T L -8 3 5 1 3 , G O L D P L A T E D P E R A S T M B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 . A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H .0 7 5 1 .9 1 10 TERMINATION: C O P P E R A L L O Y P E R M IL D T L -8 3 5 1 3 , G O L D P L A T E D P E R A S T M B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 . 1 (1 0 ) S P A C E S @ .0 5 0 = .5 0 0 1 2 .7 0 .0 3 5 0 .8 9 L AT C H S P R I N G : B E R Y L L IU M C O P P E R P E R A S T M B 1 9 4 N IC K E L P L A T E P E R A M S -C -2 6 0 7 4 .. CU R R E N T C AP AC ITY: 3 A M P M AX. CON TACT RE S IS TAN CE: 2 6 M IL L IO H M S ( 6 5 m V ) M A X @ 2 .5 A M P S . PERFORMANCE: P R O D U C T F A M IL Y T E S T E D TO AND PASSED THE PE RFO RMA NCE S P E C I F IC A T IO N S O F T A B L E V II O F M IL - D T L - 8 3 5 1 3 . . 1 2 6± . 0 1 0 3 . 2 0± 0 . 2 5 .1 2 5 3 .1 8 .1 0 2 2 .5 9 NOTE ORIENTATION REF: OMNETICS T H IR D A N G L E SSB -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S S L DW 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . D E L CHK 'D. AP P 'D. DATE 09-26 -02 DATE DATE T I T LE : (10) SOCKET FEMALE SINGLE ROW CONNECTOR W/ LATCH OMNETICS A 2 5 0 0 1 - 0 1 0 CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM CAG E CO DE DW G NO . 61873 SHEET 1 OF 1 REV S C A L E : 4 :1 D
A25001-010 价格&库存
很抱歉,暂时无法提供与“A25001-010”相匹配的价格&库存,您可以联系我们找货
A25001-010
  • 1+612.444761+79.23608
