A28050-065
A28050-065
    OMNETICS
    D-Sub 电缆组件 D 型,Nano-D 多股,单股 1.50'(457.20mm) 插头,公引脚 至 单条导线引线 无屏蔽
A28050-065 数据手册
PART NO . M A T E R I AL S & S P E C I F IC AT I O N S A CONTACT: B E R Y L L IU M C O P P E R P E R A S T M B 1 9 4 , C 17200, G O LD P LA TE D P E R A S TM B 488, ( H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 .2 7 34 DATE AP P 10 20 3 3 10- 2 7- 1 5 TLM .1 0 5 2 .6 7 .0 4 0 1 .0 2 .2 0 5 .1 A .0 1 2 5 0 .3 1 8 . 5 0 5± . 0 1 0 1 2 . 8 3± 0 . 2 5 65 S E C T IO N A - A N E M A H P 3 T Y P E E T , C O L O R C O D E D IA W M IL - S T D - 6 8 1 , S Y S T E M 1 , U S IN G T E N S O L ID R E P E A T IN G C O L O R S HARDWARE: 1 7 - 7 S T A IN L E S S S T E E L P IN # C U R R E NT R A T IN G : 1 A M P M A X P E R M IL - D T L - 3 2 1 3 9 1 .0 7 5 2 7 .3 1 C O N T A C T R ES I S T A N C E : 7 1 M IL L I O H M M A X ( 7 1 m V D R O P M A X ) @ 1 . 0 A M P S P E R M IL - D T L - 3 2 1 3 9 .1 3 8 3 .5 1 P E R F O R M AN C E : P R O D U C T F A M IL Y T E S T E D T O A N D PASSED TH E PER F O R M AN C E S P E C IF I C A T I O N S O F T A B L E V II I O F M I L D T L -3 2 1 3 9 2 X S P R IN G 2 X R E T A I N IN G P I N + .3 8 1 8 . 0 0- . 0 0 + 9 .7 4 5 7 .2 0 A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H M NPL S LD W D IM E N S IO N S IN [ ] A R E IN M IL L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R R EF ER EN C E O N LY EC O D 33 .8 6 0 2 1 .8 4 INSULAT OR: L IQ U I D C R Y S T A L P O L Y M E R ( L C P ) P E R A S TM D 5138 N O TE : RE V 1 .1 0 28 HO U S ING : A L U M IN U M 6 0 6 1 - T 6 , N IC K E L P L A T E P E R S A E -A M S -2 4 0 4 1 WIRE: A 2 8 0 5 0 -0 6 5 T H IR D A N G L E -T O L E R A N C E S D IM E N S IO N S I N I N C H E S O M N E T IC S C O NNE C T O R C O R P . T HIS D O C UM E NT M A Y NO T , IN W HO L E O R IN P A R T , B E D UP L IC A T E D , O R D I S C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S I O N F R O M O M N E T IC S C O N N E C T O R C O R P . 2 P L D E C 3 P L D E C 4 P L D E C AN G LE S .0 1 .0 0 5 .0 0 0 5 1 DF T M . J P F C H K 'D . A P P ' D. B LA C K 2, 12, 22, 32, 42, 52, 62 BROW N 3, 13, 23, 33, 43, 53, 63 R ED 4, 14, 24, 34, 44, 54, 64 O R A NG E 5, 15, 25, 35, 45, 55, 65 YELLOW 6, 16, 26, 36, 46, 56 G R EE N 7, 17, 27, 37, 47, 57 BL U E 8, 18, 28, 38, 48, 58 VIOLET 9, 19, 29, 39, 49, 59 GRAY 10, 20, 30, 40, 50, 60 WHITE IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E A 2 8 0 0 0 -0 6 5 3 0 A W G (7 -3 8 ) PTF E, C O LO R C O D ED T H I S D R A W I N G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y I N F O R M A T I O N W H IC H I S T H E P R O P E R T Y O F U N L E S S O T H E R W IS E N O T E D CO LO R 1, 11, 21, 31, 41, 51, 61 DA TE 01- 2 8- 0 8 DA TE DA TE TI T LE: (65) PIN MALE LATCHING Bi-Lobe® CONNECTOR OMNETICS CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.CO M CAG E CO DE DW G N O . 61873 A 2 8 0 5 0 -0 6 5 SHEET 1 O F 1 RE V S C A L E : 2 :1 D
A28050-065 价格&库存
很抱歉,暂时无法提供与“A28050-065”相匹配的价格&库存,您可以联系我们找货
