A28111-015
A28111-015
    OMNETICS
    D-Sub 电缆组件 D 型,Nano-D 蓝色,带状 1.50'(457.20mm) 插头,公引脚 至 单条导线引线 无屏蔽
A28111-015 数据手册
PART NO. M AT E RIAL S & S P E C IF ICAT IO N S REV ECO DATE AP P A 104304 03-07 -1 8 HV .5 0 0 1 2 .7 0 H O U S IN G & B AC K S H E L L : A L U M IN U M 6 0 6 1 , N IC K E L P L A T E D ( 5 0 0 M I C R O IN C H E S M IN IM U M ) P E R S A E -A M S 2404. .0 4 0 1 .0 2 .2 3 5 5 .9 7 1 INSULATOR: L I Q U ID C R Y S T A L P O L Y M E R (L C P ) P E R A S T M D 5 1 3 8 .0 5 7 5 1 .4 6 1 8 A .1 7 5 4 .4 5 .0 9 5 2 .4 1 .1 0 5 2 .6 7 3 0 A W G (7 -3 8 ) PTFE, C O LO R C O D ED .1 2 5 3 .1 8 CONTACT: B E R Y L L IU M C O P P E R P E R A S T M B194, C 17200, G O LD PLATED P E R A S T M B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 .2 7 WIRE: A 2 8 1 1 1 -0 1 5 A 9 15 .0 1 2 5 0 .3 1 8 2 X # 0 -8 0 U N F -2 A .2 1 0 5 .3 3 .8 1 2 0 .6 .3 4 5 8 .7 6 N EM A H P 3 TYP E E T, C O LO R C O D E D IA W M IL -S T D -6 8 1 , S Y S T E M 1 , U S I N G T E N S O L ID R E P E A T IN G C O L O R S S E C T IO N A - A HARDWARE: 3 0 3 S T A IN L E S S S T E E L P E R ASTM A582 .4 5 0 1 1 .4 3 .0 8 0 2 .0 3 C U R R E N T R AT IN G : 1 A M P M A X P E R M IL - D T L 32139 .2 2 5 CON TACT RE S IS TANCE : 7 1 M IL L IO H M M A X (7 1 m V 5 .7 2 D R O P M A X ) @ 1 .0 A M P S P E R M IL - D T L -3 2 1 3 9 PERFORMANCE: P R O D U C T F A M IL Y T E S T E D T O AND PASSED THE P E R F O R M A N C E S P E C I F IC A T IO N S O F T A B L E V III O F M IL -D T L 32139. .3 7 5 M A X 9 .5 3 M A X .2 0 5 5 .2 1 2 X .0 5 0 H E X P IN 1, 1 2, 1 3, 1 4, 1 5, 1 6 7 8 9 10 # 1 2 3 4 5 CO L O R BLA C K BROW N RE D ORANGE YELLOW GRE E N BLUE VIOLET GRAY WHITE IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E A 2 8 0 0 0 -0 1 5 + .3 8 1 8 . 0 0- . 0 0 + 9 .7 4 5 7 .2 0 A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H NOTE: M N P O S L DW D IM E N S IO N S IN [ ] A R E IN M I L L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R REFER EN CE ON LY T H IR D A N G L E -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 CAG E CO DE DW G NO . T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . H V CHK 'D. AP P 'D. DATE 03-02 -1 8 DATE DATE T I T LE : (15) PIN MALE Bi-Lobe® CONNECTOR W/BACKSHELL 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM 61873 A 2 8 1 1 1 -0 1 5 SHEET 1 OF 1 REV S C A L E : 3 :1 A
A28111-015 价格&库存
很抱歉,暂时无法提供与“A28111-015”相匹配的价格&库存,您可以联系我们找货
