A29050-065
A29050-065
    OMNETICS
    D-Sub 电缆组件 D 型,Nano-D 多股,单股 1.50'(457.20mm) 插座,母型插口 至 单条导线引线 无屏蔽
A29050-065 数据手册
PART NO . M A T E R I AL S & S P E C I F IC AT I O N S A 2 9 0 5 0 -0 6 5 RE V EC O DATE AP P B 96 328 11- 2 0- 0 9 T LM HO U S ING : A L U M IN U M 6 0 6 1 - T 6 , N IC K E L P L A T E P E R A M S -C -2 6 0 7 4 INSULAT OR: L IQ U I D C R Y S T A L P O L Y M E R ( L C P ) P E R A S TM D 5138 3 0 A W G (7 -3 8 ) PTF E, C O LO R C O D ED SO CKET # CONTACT: C O P P E R A L L O Y P E R M IL - D T L - 3 2 1 3 9 , G O L D P L A TE D P E R A S TM B 4 8 8 , (H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 . 2 7 WIRE: + .3 8 1 8 . 0 0- . 0 0 N E M A H P 3 T Y P E E T , C O L O R C O D E D IA W M IL - S T D - 6 8 1 , S Y S T E M 1 , U S IN G T E N S O L ID R E P E A T IN G C O L O R S CO LO R 1, 11, 21, 31, 41, 51, 61 B LA C K 2, 12, 22, 32, 42, 52, 62 BROW N 3, 13, 23, 33, 43, 53, 63 R ED 4, 14, 24, 34, 44, 54, 64 O R A NG E 5, 15, 25, 35, 45, 55, 65 YELLOW HARDWARE: 1 7 - 7 S T A IN L E S S S T E E L 6, 16, 26, 36, 46, 56 G R EE N 7, 17, 27, 37, 47, 57 BL U E C U R R E NT R A T IN G : 1 A M P M A X P E R M IL - D T L - 3 2 1 3 9 8, 18, 28, 38, 48, 58 VIOLET C O N T A C T R ES I S T A N C E : 7 1 M IL L I O H M M A X ( 7 1 m V D R O P M A X ) @ 1 . 0 A M P S P E R M IL - D T L - 3 2 1 3 9 9, 19, 29, 39, 49, 59 GRAY 10, 20, 30, 40, 50, 60 WHITE 1 .0 7 5 P E R F O R M AN C E : P R O D U C T F A M IL Y T E S T E D T O A N D PASSED TH E PER F O R M AN C E S P E C IF I C A T I O N S O F T A B L E V II I O F M I L D T L -3 2 1 3 9 .5 6 .8 6 3 IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E A 2 9 0 0 0 -0 6 5 34 65 A .0 7 0 ( T Y P ) .0 4 0 .2 0 M NSL A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H T H IR D A N G L E -T O L E R A N C E S U N L E S S O T H E R W IS E N O T E D D IM E N S IO N S I N I N C H E S S LD W 2 P L D E C 3 P L D E C 4 P L D E C AN G LE S .0 1 .0 0 5 .0 0 0 5 1 .1 1 0 A 1 .0 1 2 5 33 T H I S D R A W I N G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y I N F O R M A T I O N W H IC H I S T H E P R O P E R T Y O F O M N E T IC S C O NNE C T O R C O R P . T HIS D O C UM E NT M A Y NO T , IN W HO L E O R IN P A R T , B E D UP L IC A T E D , O R D I S C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S I O N F R O M O M N E T IC S C O N N E C T O R C O R P . DF T M . J P F C H K 'D . A P P ' D. DA TE 01- 2 8- 0 8 DA TE DA TE TI T LE: (65) SOCKET FEMALE LATCHING Bi-Lobe® CONNECTOR S E C T IO N A - A OMNETICS CAG E CO DE DW G N O . 61873 CONNECTOR CORPORATION A 2 9 0 5 0 - 0 6 5 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.CO M SHEET 1 O F 1 S C A L E : 2 :1 RE V B
A29050-065
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高速光耦器件,用于隔离数字信号传输,具有高传输速度和低功耗特性。
3. 引脚分配:EL817共有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作电压范围为3V-15V,传输速率可达100Mbps。
5. 功能详解:EL817通过内部发光二极管和光敏三极管实现信号隔离,适用于高速数字通信。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:EL817采用DIP-8封装,尺寸为10.16mm x 3.96mm。
A29050-065 价格&库存
很抱歉,暂时无法提供与“A29050-065”相匹配的价格&库存,您可以联系我们找货
