A29052-065
A29052-065
    OMNETICS
    SMD
    65 位 D 型,Nano-D 插座,母型插口 连接器
A29052-065 数据手册
PART NO. M A T E R IA L S & SPECIFICATIONS H O U S IN G : A L U M IN U M 6 0 6 1 -T 6 , N IC K E L P L A T E P E R S A E A M S -2 4 0 4 .9 7 0 2 4 .6 4 A 2 9 0 5 2 -0 6 5 ECO DATE AP P A 102580 05-11 -1 6 TLM 2 X # 0 -8 0 U N F -2 B .0 9 0 M IN INSULATOR: L I Q U ID C R Y S T A L P O L Y M E R (L C P ) P E R A S T M D 5 1 3 8 A C T U A L S IZ E .0 5 7 5 1 .4 6 1 CONTACTS: C O P P E R A L L O Y P E R M IL D T L -3 2 1 3 9 , G O L D PLATED PER ASTM B488, (H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 .2 7 .8 7 0 2 2 .1 0 . 0 1 0 (T Y P ) 0 .2 5 SO LD E R C O AT E D TERMINATION: S O L D E R C O A T E D W IT H SN63A P E R J -S T D -0 0 6 .0 3 0 0 .7 6 C U R R E N T R AT IN G : 1 A M P M A X P E R M IL D T L -3 2 1 3 9 .2 5 5 6 .4 8 CON TACT RE S IS TANCE : 7 1 M IL L IO H M M A X (7 1 m V D R O P M A X ) @ 1 .0 A M P S P E R M IL -D T L -3 2 1 3 9 1 .0 7 5 2 7 .3 1 PERFORMANCE: P R O D U C T F A M IL Y T E S T E D TO AND PASSED THE PE RFO RMA NCE S P E C I F IC A T IO N S O F T A B L E V III O F M IL - D T L - 3 2 1 3 9 .1 1 0 2 .7 9 .8 6 3 2 1 .9 2 34 . 0 7 0 (T Y P ) 1 .7 8 .0 4 0 1 .0 2 A 1 NOTE: M NSL T H IR D A N G L E -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S S L DW 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 S E C T IO N A - A CAG E CO DE DW G NO . T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . T L M CHK 'D. AP P 'D. . 1 6 5± . 0 1 0 4 . 1 9± 0 . 2 5 .0 9 8 2 .4 9 33 .0 1 2 5 0 .3 1 8 SEE SHEET 2 FOR PAD LAYOUT .0 2 0 0 .5 0 65 A .1 2 5 3 .1 8 D IM E N S IO N S IN [ ] A R E IN M I L L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R REFER EN CE ON LY REV DATE 05-10 -1 6 DATE DATE T I T LE : (65) SOCKET FEMALE LATCHING Bi-Lobe® CONNECTOR 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM 61873 A 2 9 0 5 2 -0 6 5 SHEET 1 OF 2 REV S C A L E : 3 :1 A PART NO. A 2 9 0 5 2 -0 6 5 REV ECO DATE AP P A 102580 05-11 -1 6 TLM .7 7 5 1 9 .6 9 . 0 1 7 (T Y P ) 0 .4 3 34 .0 1 5 0 .3 8 .0 8 8 2 .2 4 M IN 65 .0 1 5 0 .3 8 1 2X .0 7 8 1 .9 8 M IN 33 .0 7 0 1 .7 8 .8 0 0 2 0 .3 2 .0 8 5 2 .1 6 .9 7 0 2 4 .6 4 S U G G E S T E D P A D L A YO U T M NSL T H IR D A N G L E -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S S L DW 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 CAG E CO DE DW G NO . T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . T L M CHK 'D. AP P 'D. DATE 05-10 -1 6 DATE DATE T I T LE : (65) SOCKET FEMALE LATCHING Bi-Lobe® CONNECTOR 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM 61873 A 2 9 0 5 2 -0 6 5 SHEET 2 OF 2 REV S C A L E : 3 :1 A
A29052-065 价格&库存
很抱歉,暂时无法提供与“A29052-065”相匹配的价格&库存,您可以联系我们找货
