A29111-031
A29111-031
    OMNETICS
    D-Sub 电缆组件 D 型,Nano-D 蓝色,带状 1.50'(457.20mm) 插座,母型插口 至 单条导线引线 无屏蔽
A29111-031 数据手册
PART NO. A 2 9 1 1 1 -0 3 1 REV ECO DATE AP P B 106954 0 1 -0 6 -2 0 2 1 ARJ 3 0 A W G (7 -3 8 ) PTFE, C O LO R C O D ED + 1 8 . 0 0+ 4 5 7 .2 .3 8 .0 0 9 .7 0 2 X T O P R E V E N T D IS A S S E M B L Y O F B A C K S H E LL, E P O XY H A S B E E N A P P L IE D T O S C R E W THREADS & HEX HEAD. 2 X .0 5 0 H E X .2 0 5 5 .2 1 .3 7 5 9 .5 3 SOCKET # 1, 11, 21, 31 2, 12, 22 3, 13, 23 4, 14, 24 5, 15, 25 6, 16, 26 7, 17, 27 8, 18, 28 9, 19, 29 10, 20, 30 CO L O R BLA C K BROW N RE D ORANGE YELLOW GRE E N BLU E VIOLET GRAY WHITE A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E A 2 9 0 0 0 -0 3 1 .6 5 0 1 6 .5 1 .7 0 0 1 7 .7 8 .5 4 5 1 3 .8 4 .8 6 2 1 .7 .1 1 0 2 .7 9 .4 3 8 1 1 .1 3 2 X # 0 -8 0 U N F -2 B .0 5 7 5 1 .4 6 1 17 A 1 D IM E N S IO N S IN [ ] A R E IN M I L L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R REFER EN CE ON LY .0 4 0 1 .0 2 .1 7 5 4 .4 5 16 T H IR D A N G L E -T O L E R A N C E S U N L E S S O T H E R W IS E N O TE D D I M E N S IO N S IN IN C H E S 2 P L D E C 3 P L D E C 4 P L D E C ANG LES .0 1 .0 0 5 .0 0 0 5 1 . 0 7 0 (T Y P ) 1 .7 8 .1 2 5 3 .1 8 .0 9 8 2 .4 9 .0 1 2 5 0 .3 1 8 M N S O S L DW NOTE: 31 A .2 5 5 6 .4 8 S E C T IO N A - A T H I S D R A W IN G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y IN F O R M A T IO N W H I C H IS T H E P R O P E R T Y O F O M N E T I C S C O N N E C T O R C O R P . T H I S D O C U M E N T M A Y N O T , IN W H O L E O R I N P A R T , B E D U P L IC A T E D , O R D IS C L O S E D F O R A N Y P U R P O S E , W IT H O U T W R I T T E N P E R M IS S IO N F R O M O M N E T I C S C O N N E C T O R C O R P . DF T M . H V CHK 'D. AP P 'D. DATE 03-05 -1 8 DATE DATE CAG E CO DE DW G NO . T I T LE : (31) SOCKET FEMALE Bi-Lobe® CONNECTOR W/ BACKSHELL 7 2 6 0 C O M M E R C E C IR C L E E A S T M I N N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.COM 61873 A 2 9 1 1 1 -0 3 1 SHEET 1 OF 2 REV S C A L E : 3 :1 B
A29111-031
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚GND。
4. 参数特性:工作温度范围为-40至85度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装。
A29111-031 价格&库存
很抱歉,暂时无法提供与“A29111-031”相匹配的价格&库存,您可以联系我们找货
