A29650-151
A29650-151
    OMNETICS
    D-Sub 电缆组件 D 型,Nano-D 多股,单股 1.50'(457.20mm) 插座,母型插口 至 单条导线引线 无屏蔽
A29650-151 数据手册
PART NO . M ATE R IALS & S P E C IFIC AT IO N S A 2 9 6 5 0 -1 5 1 HO U S ING : A L U M IN U M 6 0 6 1 , N IC K E L P L A T E P E R ( 5 0 0 M IC R O IN C H E S M IN IM U M ) S A E - A M S - 2 4 0 4 . 3 0 A W G (7 -3 8 ) PTF E, C O LO R C O D ED CONTACT: C O P P E R A L L O Y P E R M IL - D T L 32139, G O LD P LATE D PE R AS TM B 4 8 8 , ( H A R D G O L D ) T Y P E II C O D E C C L A S S 1 .2 7 N E M A H P3 TYPE ET, C O LO R C O D E D IA W M IL - S T D - 6 8 1 , S Y S T E M 1 , U S I N G T E N S O L ID R E P E A TIN G C O L O R S DATE AP P 10 43 3 9 03- 2 3- 1 8 TLM 2, 12, 22, 32, 42 2 X R E T A I N IN G P I N + .3 8 1 8 .0 0 - .0 0 + 9 .7 4 5 7 .2 0 2 X # 0 -8 0 U N F .0 6 0 1 .5 2 .1 5 6 3 .9 7 .0 6 0 1 .5 2 HARDWARE: S C R E W : 1 8 - 8 S T A IN L E S S S T E E L EC O D SO CKET # CO LO R 1 , 1 1 , 2 1 , 3 1 , 4 1 , 5 1 B LA C K INSULAT OR: L I Q U ID C R Y S T A L P O L Y M E R ( L C P ) PER AS TM D 5138 WIRE: RE V R ED 4, 14, 24, 34, 44 O R A NG E 5, 15, 25, 35, 45 YELLO W 6, 16, 26, 36, 46 G R EE N 7, 17, 27, 37, 47 BL U E 8, 18, 28, 38, 48 VIOLET 9, 19, 29, 39, 49 GRAY 10, 20, 30, 40, 50 WHITE IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E A 2 9 0 0 0 -0 5 1 .0 1 0 X 4 5 ° [0 .2 5 ] R E T A IN IN G P IN : 1 7 - 7 S T A IN L E S S S T E E L , P A S S IV A T E P E R A S T M A967 BROW N 3, 13, 23, 33, 43 C U R R E NT R A T IN G : 1 A M P M A X P E R M IL - D T L - 3 2 1 3 9 1 .4 5 0 3 6 .8 3 1 .0 8 5 2 7 .5 6 .6 8 8 1 7 .4 8 C O N T A C T R ES I S T A N C E : 7 1 M IL L IO H M M A X ( 7 1 m V D R O P M A X ) @ 1 . 0 A M P S P E R M IL D T L -3 2 1 3 9 P E R F O R M AN C E : P R O D U C T F A M IL Y T E S T E D T O A N D PASSED TH E PER F O R M AN C E S P E C I F I C A T IO N S O F T A B L E V II I O F M IL - D T L - 3 2 1 3 9 . 27 1 26 .0 1 2 5 0 .3 1 8 4 X R. 0 4 0 1 .0 2 .2 0 0 5 .0 8 .0 9 8 2 .4 9 .2 0 0 5 .0 8 .2 5 0 6 .3 5 1 .2 4 0 3 1 .5 0 A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H M N S L P S LD W D IM E N S IO N S IN [ ] A R E IN M IL L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R R EF ER EN C E O N LY .0 7 0 1 .7 8 51 .3 0 0 7 .6 2 4 X R. 0 5 1 .3 N O TE : .1 1 0 2 .7 9 T H IR D A N G L E -T O L E R A N C E S D IM E N S IO N S I N I N C H E S 2 P L D E C 3 P L D E C 4 P L D E C AN G LE S .0 1 .0 0 5 .0 0 0 5 CAG E CO DE DW G N O . T H I S D R A W I N G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y I N F O R M A T I O N W H IC H I S T H E P R O P E R T Y O F O M N E T IC S C O NNE C T O R C O R P . T HIS D O C UM E NT M A Y NO T , IN W HO L E O R IN P A R T , B E D UP L IC A T E D , O R D I S C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S I O N F R O M O M N E T IC S C O N N E C T O R C O R P . U N L E S S O T H E R W IS E N O T E D DF T M . J P F C H K 'D . A P P ' D. DA TE 04- 0 8- 0 8 DA TE DA TE TI T LE: (51) SOCKET FEMALE LATCHING Bi-Lobe® CONNECTOR 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.CO M 61873 A 2 9 6 5 0 -1 5 1 SHEET 1 O F 1 RE V S C A L E : 2 :1 D
A29650-151 价格&库存
很抱歉,暂时无法提供与“A29650-151”相匹配的价格&库存,您可以联系我们找货
