A98150-512
A98150-512
    OMNETICS
    D-Sub 电缆组件 D 型,微型 D 多股,单股 1.50'(457.20mm) 插头,公引脚 至 单条导线引线 无屏蔽
A98150-512 数据手册
PART NO . MATERIALS A 9 8 1 5 0 -5 1 2 1 .9 1 4 8 .6 HO U S ING : A L U M I N U M 6 0 6 1 - T 6 , N IC K E L P L A T E P E R S A E -A M S -2 4 0 4 51 27 26 .0 5 0 1 .2 7 CONTACT: B E R Y L L IU M C O P P E R P E R ASTM B194, C 17200, G O LD PLATE D PE R A STM B 488, ( H A R D G O L D ) T Y P E II C O D E C , C L A S S 1 .2 7 WIRE: DATE AP P 10 03 8 7 03- 2 0- 1 4 TLM 1 .0 2 5 0 .6 4 (T Y P ) (T Y P ) A C T U A L S IZ E E X C L U D IN G W IR E L E N G T H 1 .8 2 5 4 6 .3 6 1 . 3 8 4 M AX 3 5 . 1 5 M AX N E M A H P 3 TYP E E, C O LO R C O D E D IA W M IL - S T D - 6 8 1 , S Y S T E M 1 , U S I N G T E N S O L ID . 1 8 3± . 0 0 3 R E P E A TIN G C O L O R S 4 . 6 5± 0 . 0 8 P IN # EC O C .0 4 3 1 .1 0 LATCH: S T A IN L E S S S T E E L , N IC K E L P L A T E P E R S A E -A M S -2 4 0 4 INSULAT OR: L IQ U ID C R Y S T A L P O L Y M E R (L C P ) P E R A S T M D 5 1 3 8 RE V .2 6 0 6 .6 0 .1 7 0 4 .3 2 CO LO R .6 0 1 1 5 .2 7 1 , 1 1 , 2 1 , 3 1 , 4 1 , 5 1 B LA C K 2, 12, 22, 32, 42 BROW N 3, 13, 23, 33, 43 R ED 4, 14, 24, 34, 44 O R A NG E 5, 15, 25, 35, 45 YELLOW 6, 16, 26, 36, 46 G R EE N 7, 17, 27, 37, 47 BL U E 8, 18, 28, 38, 48 VIOLET 9, 19, 29, 39, 49 GRAY 10, 20, 30, 40, 50 WHITE 2 X R E T A I N IN G P I N 2 X S P R IN G + .3 8 - .0 0 + 9 .7 4 5 7 .2 0 1 8 .0 0 2 6 A W G (7 -3 4 ) PTF E, C O LO R C O D ED IN T E R N A L U S E O N L Y U S E M F G L O A D IN G P R O C E D U R E M M D P -5 1 2 S LD W D IM E N S IO N S IN [ ] A R E IN M IL L IM E T E R S U N L E S S O T H E R W IS E N O T E D A N D A R E FO R R EF ER EN C E O N LY LM DP N O TE : T H IR D A N G L E -T O L E R A N C E S - T H I S D R A W I N G C O N T A I N S C O N F ID E N T I A L A N D P R O P R IE T A R Y I N F O R M A T I O N W H IC H I S T H E P R O P E R T Y O F O M N E T IC S C O NNE C T O R C O R P . T HIS D O C UM E NT M A Y NO T , IN W HO L E O R IN P A R T , B E D UP L IC A T E D , O R D I S C L O S E D F O R A N Y P U R P O S E , W I T H O U T W R IT T E N P E R M IS S I O N F R O M O M N E T IC S C O N N E C T O R C O R P . U N L E S S O T H E R W IS E N O T E D D IM E N S IO N S I N I N C H E S 2 P L D E C 3 P L D E C 4 P L D E C AN G LE S .0 1 .0 0 5 .0 0 0 5 1 DF T M . T LM C H K 'D . A P P ' D. DA TE 08- 1 0- 1 1 DA TE DA TE TI T LE: (51) PIN MALE MICRO-D CONNECTOR W/LATCHES OMNETICS CONNECTOR CORPORATION 7 2 6 0 C O M M E R C E C IR C L E E A S T M IN N E A P O L IS , M N 5 5 4 3 2 W W W .OMNETICS.CO M R oH S CAG E CO DE DW G N O . 61873 A 9 8 1 5 0 -5 1 2 SHEET 1 O F 1 RE V S C A L E : 2 :1 C
A98150-512 价格&库存
很抱歉,暂时无法提供与“A98150-512”相匹配的价格&库存,您可以联系我们找货
