CG1119-12096
CG1119-12096
    OPTION
    Expansion Card CloudGate
CG1119-12096 数据手册
BLE EXPANSION CARD WIREPAS EXPANSION CARD Connect your BLE & Wirepas beacons to the Cloud • Enables CloudGate BLE 4.2 connectivity • Available as BLE or Wirepas variant BLE variant variant (CG1119-12096) The BLE expansion card enables Option’s CloudGate gateway to receive message from BLE beacons using the iBeacon protocol. It’s firmware can be managed through LuvitRED, Option’s ‘drag & drop’ configuration tool, supporting other types of communication in any RF frequency from 2400MHz to 2524MHz Feature BLE module • Rigado BMD-301 BLE version • 4.2 standard (Bluetooth 5 compliant) Chipset on BLE module Frequency band Tx power Rx sensitivity RSSI resolution Operating temperature Wirepas Mesh variant (CG1119-12191) In combination with LuvitRED Advanced* and with Wirepas supported devices, Option’s CloudGate IoT gateway is ready to be deployed as a sink in any Wirepas Mesh network. The Wirepas stack allows BLE beacons to communicate to each other in a mesh configuration with Option’s CloudGate gateway as the access point for all the meshed beacons to the cloud. A typical use case is in/outdoor localization, where the location of the tags are determined using the signal strength of the beacons (or anchors) that have a fixed position in the building. Biketracer Option’s biketracer is a tubular-shaped BLE beacon that allows tracing and/or identification of bicycles or motorcycles. Its built-in replaceable AAA battery lasts minimum 2 years (when BLE advertising every second). The biketracer can be activated via a Reed switch. Biketracer communicates the identifier, temperature, accelerometer status and battery level. With additional Wirepas software, it can even communicate with other biketracers. Description External antenna connector on expansion card BLE module firmware reprogramming BLE support ANT/ANT+ support Wirepas support • Nordic nRF52832 • 2.4 GHz ISM band (2.36 to 2.5 GHz) • 0dBm @5.3mA • -96dBM @5.4mA • 1dB • -30°C to 70°C • RP-SMA female • Supported in LuvitRed Advanced* • YES - BLE variant - CG1119-12096 • YES - ANT/ANT+ variant available • YES - Wirepas variant - CG1119-12191 *included in the hardware price
CG1119-12096
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为Anode、Cathode、Gate1、Gate2、Output1和Output2。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压可达2500Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备和通信领域。
7. 封装信息:采用DIP-6封装。
CG1119-12096 价格&库存
很抱歉,暂时无法提供与“CG1119-12096”相匹配的价格&库存,您可以联系我们找货
CG1119-12096
    • 1+1872.244011+242.20335
    • 10+1655.1062310+214.11326
    • 25+1580.1090925+204.41124
    库存:12
