AMC1602AR-B-B6WTDW-I2C 数据手册
Specification for LCD
Revision O
A
MC
1602
AR
B
B
6
W
T
DW
I2C
Orient Display
Character Display
Character x Lines 16 x 2
Module Dimension 80.0x36.0x14.0mm
COB Type
STN Negative Blue
6 o’clock viewing angle
Top: -20~+70°C; Tstr: -30~+80°C
Transmissive
White LED Backlight
Controller AC780S Or Compatible
I2C Interface
DOCUMENT REVISION HISTORY:
DATE
PAGE
2013.2
AMC1602AR-B-B6WTDW-IIC
DESCRIPTION
First release
Page 2
Contents
1.Module Classification Information
2.Precautions in use of LCD Modules
3.General Specification
4.Absolute Maximum Ratings
5.Electrical Characteristics
6.Optical Characteristics
7.Interface Pin Function
8.Power Supply
9.Contour Drawing & Block Diagram
10.Function Description
11.Character Generator ROM Pattern
12.Instruction Table
13.Interface with MPU
14.Initializing of LCM
15.Quality Assurance
16.Reliability
Page 3
1 Brand:Orient Display
2 Display Type:C→ Character Type, G→ Graphic Type,
NONE→ Custom-made
3 Display Font:Characters X Lines / Rows X Columns /Others
4 Model serials no.
5 RoHS compliant: R→YES NONE→ NO
M→ SMT Type
6 IC Package Type:
7 LCD Mode:
8 Viewing direction
9 Temperature range
10 LCD Polarizer Type
11 Backlight Type
12 Backlight Color
B→ COB Type
T→ TAB Type
G→ COG Type
F→ COF Type
S→ Special
P→TN Positive
N→TN Negative
Y→ STN Positive, Yellow Green
B→ STN Negative, Blue
G→ STN Positive, Gray
W→ FSTN Positive
T→ FSTN Negative
F→ FFSTN Negative
S→ Special
6→ 6:00,12→12:00, S→Special
N → Normal Temperature
W→ Wide Temperature
S→ Special
R→ Reflective
T→ Transmissive
F→ Transflective
S→ Special
N→ None
D→ LED
E→ EL
F→ CCFL
S→ Special
Y→ Yellow-green
B→ Blue
A→ Amber
W→ White
G→ Green
R→ Red
S→ Special
Page 4
2. Precautions in use of LCD Modules
(1)Avoid applying excessive shocks to the module or making any alterations or modifications to
it.
(2)Don’t make extra holes on the printed circuit board, modify its shape or change the
components of LCD module.
(3)Don’t disassemble the LCM.
(4)Don’t operate it above the absolute maximum rating.
(5)Don’t drop, bend or twist LCM.
(6)Soldering: only to the I/O terminals.
(7)Storage: please storage in anti-static electricity container and clean environment.
3. General Specification
Item
Number of Characters
Dimension
Unit
16 characters x 2 Lines
Module dimension(With LED Backlight ) 80.0 x 36.0 x 12.0/14.0(MAX)
mm
View area
64.5 x 15.5
mm
Active area
56.20 x 11.50
mm
Dot size
0.55x 0.65
mm
Dot pitch
0.60 x 0.70
mm
Character size
2.95 x 5.55
mm
Character pitch
3.55 x 5.95
mm
LCD type
STN,BLUE,NEGATIVE,TRANSMISSIVE
Duty
1/16
View direction
6 o’clock
Backlight Type
WHITE LED backlight
Page 5
Item
Symbol
Min
Max
Unit
VI
-0.3
VDD+0.3
V
Supply Voltage For Logic
VDD-VSS
-0.3
5.5
V
Supply Voltage For LCD
VDD-V0
Vdd-7.0
Vdd+0.3
V
Input Voltage
Wide Temperature
Operating Temp.
Top
-20
70
LCM
Storage Temp.
Tstr
-30
80
5. Electrical Characteristics
Item
Symbol
Condition
Min
Typ
Max
Unit
VDD-VSS
4.5
5.0
5.5
V
VDD-V0
Ta=25℃
4.5
5.0
5.5
V
Input High Volt.
VIH
0.7 VDD
VDD
V
Input Low Volt.
VIL
VSS
0.3 VDD
V
Supply Current
IDD
VDD=5V
0.8
1.2
1.5
mA
3.8
4.1
4.3
V
Supply Voltage of White
backlight
Forward
current
=30 mA
VLED
Number of
LED die
1x2= 2
Page 6
6. Optical Characteristics
Item
View Angle
Symbol
Condition
Min
Typ
Max
Unit
(V)θ
CR≧2
-20
35
deg
(H)φ
CR≧2
-30
30
deg
CR
3
T rise
250
ms
T fall
250
ms
Contrast Ratio
Response Time
Definition of Operation Voltage (Vop)
Intensity
100%
Definition of Response Time ( Tr , Tf )
Non-selected
Conition
Selected Wave
Non-selected Wave
Selected Conition
Non-selected
Conition
Intensity
10%
Cr Max
Cr = Lon / Loff
90%
100%
Vop
Tr
Driving Voltage(V)
[positive type]
Tf
[positive type]
Conditions :
Operating Voltage : Vop
Viewing Angle(θ,φ) : 0°, 0°
Frame Frequency : 64 HZ
Driving Waveform : 1/N duty , 1/a bias
Definition of viewing angle(CR≧2)
θ f
θ l
θ b
φ = 180°
θ r
φ = 90°
φ = 270°
φ = 0°
Page 7
7. Interface Pin Function
Pin No. Symbol
Level
Description
1
LED(+)
Anode of LED Backlight
2
LED(-)
Cathode of LED Backlight
3
VSS
0V
4
VDD
5.0V
Supply Voltage for logic
5
SDA
H/L
Serial Data
6
SCL
H/L
Serial Clock
7
V0
(Variable) Operating voltage for LCD
8
NC
No Connection
9
NC
No Connection
10
NC
No Connection
Ground
Page 8
8. POWER SUPPLY
POWER SUPPLY AND CONNECTION WITH MCU
MCU
LCM
VCC
A
Rp
Rp
SDA
SCL
K
Vdd(+5.0V)
V0
Vss(0V)
Use Internal Options to Simplify the Circuits
Option 1: Use internal R7 for V0
Vdd(+5.0V)
Rbias
V0
R7
Vss(0V)
Option 2: Use internal jumpers for backlight power supply
Vdd(+5.0V)
A
RLBL
LBL
K
Vss(0V)
Option 3: Use internal resistors for pull up to Vdd
Vdd(+5.0V)
R16
R17
SDA
SCL
Vss(0V)
Page 9
Timing Diagram of VDD Against V0.
Power on sequence shall meet the requirement of Figure 4, the timing diagram of VDD against
V0.
Page 10
9. Contour Drawing &Block Diagram
80.0¡ À
0.5
2.5
70.5
P2.54x(10-1)=22.86
31.0
26.5
1
15.5(V.A.)
11.50(A.A.)
12.0(MAX.)
14.0(MAX.)
7.6¡ À
0.5
8.8¡ À
0.5
3.0(LBL)
3.0(LBL)
10 CL
CL
CL
CL
4- 2.5
56.20(A.A.)
64.5(V.A.)
SIDE LIT LED B/L
18.0
10- 1.0
18.5(LBL)
8.0
2.5
2.5
4.75
4.75
0.5
36.0¡ À
SIDE LIT LED B/L
LOW PROFILE VERSION
75.0
1.6¡ À
0.2
1.6¡ À
0.2
40.00
3.55
2.95
0.55
Vdd
V0
Vss
0.05
40
DRIVER
4
* RW1063
AC780S OR EQUIVALENT
5.55
40
0.65
LCD PANEL
16X2 CHARACTERS
16
5.95
SDA
CONTROLLER
SCL
0.05
Page 11
10. Function Description
The LCD display Module is built in a LSI controller, the controller has two 8-bit registers, an
instruction register (IR) and a data register (DR).
The IR stores instruction codes, such as display clear and cursor shift, and address information
for display data RAM (DDRAM) and character generator (CGRAM). The IR can only be written
from the MPU. The DR temporarily stores data to be written or read from DDRAM or
CGRAM. When address information is written into the IR, then data is stored into the DR from
DDRAM or CGRAM.
Address Counter (AC)
The address counter (AC) assigns addresses to both DDRAM and CGRAM
Display Data RAM (DDRAM)
This DDRAM is used to store the display data represented in 8-bit character codes. Its extended
capacity is 80×8 bits or 80 characters. Below figure is the relationships between DDRAM
addresses and positions on the liquid crystal display.
High bits
Low bits
Example: DDRAM addresses 4E
AC
(hexadecimal)
AC6 AC5 AC4 AC3 AC2 AC1 AC0
1
1
1
Display position DDRAM address
1 2
3
4
5
6
00 01 02 03 04 05
40 41 42 43 44 45
7
8
9 10 11 12 13 14 15 16
06 07 08 09 0A 0B 0C 0D 0E 0F
46 47 48 49 4A 4B 4C 4D 4E 4F
2-Line by 16-Character Display
Character Generator ROM (CGROM)
The CGROM generate 5×8 dot or 5×10 dot character patterns from 8-bit character codes. See
Table 2.
Page 12
Character Generator RAM (CGRAM)
In CGRAM, the user can rewrite character by program.
For 5×8 dots, eight character patterns
can be written, and for 5×10 dots, four character patterns can be written.
Write into DDRAM the character code at the addresses shown as the left column of table 1. To
show the character patterns stored in CGRAM.
Relationship between CGRAM Addresses, Character Codes (DDRAM) and Character
patterns
Table 1.
For 5 * 8 dot character patterns
Character Codes
( DDRAM data )
7 6 5 4 3 2 1 0
High
0 0 0 0
0 0 0 0
0 0 0 0
Low
* 0 0 0
* 0 0 1
* 1 1 1
CGRAM Address
5 4 3 2 1 0
Character Patterns
( CGRAM data )
7 6 5 4 3 2 1 0
High
Low
0 0
0 0
0 1
0 1
0 0 0 1 0
1 0
1 1
1 1
0 0
0 0
0 1
0 1
0 0 1 1 0
1 0
1 1
1 1
0 0
0 0
1 1 1 1
1
1
1
1
High
Low
0 0 0
Character
pattern( 1 )
0 0
Character
pattern( 2 )
0 0
0 0
0 0
0 0
0 0 0 0 0
Cursor pattern
Cursor pattern
For 5 * 10 dot character patterns
Character Codes
( DDRAM data )
7 6 5 4 3 2 1 0
High
0 0 0 0
Low
* 0 0 0
CGRAM Address
5 4 3 2 1 0
High
Character Patterns
( CGRAM data )
7 6 5 4 3 2 1 0
Low
1
1
1
1
1
1
1
High
Low
* 0 0 0 0 0
* 0 0 0 0 0
0 0 0
0 0 0
0 0 0 0
0 0 0 0
* 0 0 0 0 0
Character
pattern
Cursor pattern
: " High "
Page 13
11. Character Generator ROM Pattern
Page 14
12. Instruction Table
Instruction Code
Instruction
Execution time
(fosc=210Khz)
Description
RS R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0
Clear Display
Write “20H” to DDRAM and set
DDRAM address to “00H” from AC
1.98ms
1.98ms
Return Home
Set DDRAM address to “00H” from AC
and return cursor to its original position
if shifted. The contents of DDRAM are
not changed.
Entry Mode
Set
I/D
SH
Assign cursor moving direction and
enable the shift of entire display.
48μs
Display
ON/OFF
D
C
B
Set display (D), cursor (C), and blinking
of cursor (B) on/off control bit.
48μs
Cursor or
Display Shift
- control bit, and the direction, without
Function Set
Set CGRAM
Address
Set DDRAM
Address
Write Data to
RAM
Set cursor moving and display shift
S/C R/L
48μs
changing of DDRAM data.
Set interface data length
(DL:8-bit/4-bit), numbers of display line
(N:2-line/1-line)and, display font type
(F:5×11 dots/5×8 dots)
48μs
AC5 AC4 AC3 AC2 AC1 AC0 Set CGRAM address in address counter.
48μs
AC6 AC5 AC4 AC3 AC2 AC1 AC0 Set DDRAM address in address counter.
48μs
1
D7
D6
1
D5
DL
D4
N
D3
F
D2
D1
D0
Write data into internal RAM
(DDRAM/CGRAM).
48μs
* ”-”:don’t care
Page 15
13. Interface with MPU
Page 16
Page 17
Slave Address Option:
J7
J8
J9
short
J10
Address in Hex(without
R/W=0) using in
arduino
short
0X78(default
0X3C(default setting)
setting)
short
1
1
0X7A
0X7C
0X7E
short short
short
short
Address in
SA1 SA0
Hex(R/W=0)
short
0X3D
0X3E
0X3F
DB5(CSB)is connected to Vss by short J6.
Page 18
Page 19
Initial Code:
void WriteData(BYTE byData)
I2C_Start();
I2C_Send(0x78); //Chip select
I2C_Ack();
I2C_Send(0x40); //Data
I2C_Ack();
I2C_Send(byData);
I2C_Ack();
I2C_Stop();
void WriteInst(BYTE byInst)
I2C_Start();
I2C_Send(0x78); // Chip select
I2C_Ack();
I2C_Send(0x00); //Instruction
I2C_Ack();
I2C_Send(byInst);
I2C_Ack();
I2C_Stop();
void InitAC780S(void)
WriteInst (0x38); //DL=1: 8 bits; N=1: 2 line; F=0: 5 x 8dots
WriteInst (0x0c); // D=1, display on; C=B=0; cursor off; blinking off;
WriteInst (0x06); // I/D=1: Increment by 1; S=0: No shift
Page 20
Screen Cosmetic Criteria
Item
Defect
1
Spots
2
Bubbles in Polarizer
3
Scratch
4
Allowable Density
5
Coloration
Judgment Criterion
A)Clear
Acceptable Qty in active area
d ≦0.1
Disregard
0.1
AMC1602AR-B-B6WTDW-I2C 价格&库存
很抱歉,暂时无法提供与“AMC1602AR-B-B6WTDW-I2C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+102.916071+13.37658
- 10+79.4402810+10.32530
- 100+65.74536100+8.54530
- 500+59.78790500+7.77097
- 1000+57.855301000+7.51978
- 国内价格
- 1+107.80560
- 200+43.01640
