SPOT-4DUV
SPOT-4DUV
    OSI
    TO5-5
    光电二极管 950nm 10µs TO-5 变体,5 引线,透镜顶金属罐
SPOT-4DUV 数据手册
Segmented Photodiodes (SPOT Series) Position Sensing Detector (PSD) The SPOT Series are common substrate photodetectors segmented into either two (2) or four (4) separate active areas. They are available with either a 0.005" or 0.0004" well defined gap between the adjacent elements resulting in high response uniformity between the elements. The SPOT series are ideal for very accurate nulling or centering applications. Position information can be obtained when the light spot diameter is larger than the spacing between the cells. Spectral response range is from 350-1100nm. Notch or bandpass filters can be added to achieve specific spectral responses. These detectors exhibit excellent stability over time and temperature, fast response times necessary for high speed or pulse operation, and position resolutions of better than 0.1 µm. Maximum recommended power density is 10 mW / cm2 and typical uniformity of response for a 1 mm diameter spot is ±2%. The circuit on the opposite page represents a typical biasing and detection circuit set up for both bi-cells and quad-cells. For position calculations and further details, refer to “Photodiode Characteristics” section of the catalog. 44 FEATURES n APPLICATIONS n • Machine Tool Alignment • Position Measuring • Beam Centering • Surface Profiling • Targeting • Guidance Systems • High Accuracy • Excellent Resolution • High-Speed Response • Ultra Low Dark Current • Excellent Response Match • High Stability over Time and Temperature Segmented Photodiodes (SPOT Series) -10 V -10 V -10 V 970 nm min. typ. typ. typ. max. typ. max. Rise Time (ns) -10 V 780 nm 50 Ω typ. Temp Range (˚C) Storage 970 nm Reverse Voltage (V) -55 ~ +125 NEP (W/Hz) -55 ~ +125 Dark Current (nA) Operating Capacitance (pF) -40 ~ +100 Responsivity (A/W) -40 ~ +100 Element Gap (mm) Dimensions (mm) Active Area Per Element Area (mm2) Model Number Typical Electro-Optical Specifications at TA=23ºC Package Style ¶ Two-Element Series, Metal Package CD-25T 2.3 4.6 x 0.5 0.2 50@ -15V SPOT-2D 3.3 1.3 x 2.5 0.127 11 0.15 2.0 SPOT-2DMI 0.7 0.6 x 1.2 0.013 3 0.05 1.0 6.2 e-15 SPOT-3D 2.8 0.6 x 4.6 0.025 7 0.13 2.0 9.9 e-15 0.60 0.65 20@ -15V 300@ -15V 1.1 e-14 30 5 7 4 2 / TO-5 41 / TO-5 40 / TO-18 41 / TO-5 Four Element Series, Metal Package 1.61 1.3 sq 0.127 5 0.10 1.0 8.7 e-15 SPOT-4DMI 0.25 0.5 sq 0.013 1 0.01 0.5 2.8 e-15 SPOT-9D 19.6 SPOT-9DMI 19.6 60 0.50 10.0 1.9 e-14 Dimensions (mm) 0.60 0.102 0.65 0.010 Element Gap (mm) 10 φ ‡ Active Area Per Element Area (mm2) Model Number SPOT-4D Responsivity 257 nm Capacitance 0V A/W pF min. typ. typ. Shunt Resistance (MΩ) NEP (W/Hz) 30 Reverse Voltage (V) 3 41 / TO-5 43 / LoProf Rise Time 0 V, 257 nm µs min. max. typ. max. typ. 100 500 1.3 e-13 5 10 Package Style ¶ 1.61 1.3 sq 0.127 0.08 0.10 40 -20 ~ +70 SPOT-4DUV -10 ~ +60 UV-Enhanced Four Elements, Metal Package § 41 / TO-5 ‡ Overall Diameter (All four Quads) ¶ For mechanical drawings please refer to pages 58 thru 69. Chip centering within ±0.010". 45 1. Parameter Definitions: A a B c = = = = Distance from top of chip to top of glass. Photodiode Anode. Distance from top of glass to bottom of case. Photodiode Cathode (Note: cathode is common to case in metal package products unless otherwise noted). W = Window Diameter. F.O.V. = Filed of View (see definition below). 2. Dimensions are in inches (1 inch = 25.4 mm). 3. Pin diameters are 0.018 ± 0.002" unless otherwise specified. 4. Tolerances (unless otherwise noted) General: 0.XX ±0.01" 0.XXX ±0.005" Chip Centering: ±0.010" Dimension ‘A’: ±0.015" 5. Windows All ‘UV’ Enhanced products are provided with QUARTZ glass windows, 0.027 ± 0.002" thick. All ‘XUV’ products are provided with removable windows. All ‘DLS’ PSD products are provided with A/R coated glass windows. All ‘FIL’ photoconductive and photovoltaic products are epoxy filled instead of glass windows. For Further Assistance Please Call One of Our Experienced Sales and Applications Engineers 310-978-0516 - Or On the Internet at www.osioptoelectronics.com 57 Mechanical Specifications All units in inches. Pinouts are bottom view. PIN-020A PIN-040A PIN-040-DP/SB PIN-6DI PIN-6DPI PIN-44DI PIN-44DPI OSD35-0 OSD35-7Q PIN-5DI PIN-5DPI PIN-13DI PIN-13DPI PIN-5-YAG CD-25T PIN-6DI, PIN-6DPI PIN-44DI, PIN-44DPI, OSD35-0, OSD35-7Q P/N A B W PIN-020A 0.075 0.200 0.155 PIN-040A 0.075 0.200 0.155 P/N A B W All Others 0.094 0.180 0.240 CD-25T 0.050 0.130 0.23 P/N A A BPX-65R B B PIN-5D PIN-5DP PIN-5DP/SB PIN-13D PIN-13DP PIN-005E-550F UV-001 UV-005 UV-005D UV-005E UV-013D UV-013E UV-015 OSD-5-0 OSD15-0 OSD5-5T OSD15-5T OSD5.8-7Q OSD5.8-7U 0.115 PIN-44DI/44DPI 0.125 OSD35-0 0.130 OSD35-7Q PIN-2DI PIN-2DPI PIN-3CDP PIN-3CDPI BPX-65R A PIN-6DI/6DPI 0.130 Quartz Window PIN-6D PIN-6DP PIN-44D PIN-44DP UV-020 UV-035D UV-035E UV-035 All Others PIN-5D, PIN-5DP, PIN-5DP/SB, PIN-13D, PIN-13DP, PIN-005E-550F UV-005D, UV-005E, UV-013D, UV-013 15OSD-5-0, OSD15-0, OSD5-5T, OSD15-5T OSD5.8-7Q, OSD5.8-7U P/N A B BPX-65R 0.070 0.200 All Others 0.090 0.150 PIN-3CD PIN-3CDP BPX-65 OSD1-0 OSD1-5T OSD3-5T OSD1.2-7Q OSD1.2-7U P/N PIN-3CD / 3CDP A 0.087 BPX-65 0.075 0.200 OSD-Prefix Devices 0.080 0.200 Quartz Window: OSD1.2-7Q UV Transmissive Window: OSD1.2-7U 58 B 0.146 P/N A B OSD-Prefix Devices 0.050 0.130 All Others 0.102 0.180 Quartz Window: OSD5.8-7Q UV Transmissive Window: OSD5.8-7U UV-001, UV-005, UV-015 PIN-125DPL PIN-HR005 PIN-HR008 PIN-HR020 PIN-HR026 PIN-HR040 Mechanical Specifications All units in inches. Pinouts are bottom view. SC-4D SL3-1 SPOT-2D SPOT-3D SPOT-4D SPOT-4DMI SPOT-4DUV QD7-0 SPOT-2DMI QD7-0 0.050 0.130 SL5-1 0.230 QD7-0 SPOT-9D SPOT-9DMI 64 SC-10D SC-25D
SPOT-4DUV 价格&库存
很抱歉,暂时无法提供与“SPOT-4DUV”相匹配的价格&库存,您可以联系我们找货
