GT QSSPA1.13-LSLU-26-1-350-R18
    AMSOSRAM(艾迈斯半导体)
    发光二极管/LED 翠绿色 SMT
GT QSSPA1.13-LSLU-26-1-350-R18 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 GT QSSPA1.13   GT QSSPA1.13 OSCONIQ ® P 3030 The OSCONIQ P 3030 Colors family LED comes with well known superior robustness, high reliability, long lifetime, low thermal resistance. Compact and proven 3mm x 3mm package and established footprint. Perfectly addressing applications that demand for high efficiency and long lifetime. Applications ——Stage Lighting (LED & Laser) ——Accent (BAR) ——Architecture Features: ——Package: SMD epoxy package ——Typ. Radiation: 120° (Lambertian emitter) ——Corrosion Robustness Class: 3B ——Lumen maintenance: Test results according to IESNA LM-80 available ——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)  ——Luminous Flux: typ. 143 lm  ——Luminous Efficacy: typ. 151 lm/W 1 Version 1.0 | 2019-04-22 GT QSSPA1.13   Ordering Information  Type Luminous Flux 1) IF = 350 mA ΦV GT QSSPA1.13-LSLU-26-1 140.0 ... 224.0 lm   2 Version 1.0 | 2019-04-22 Ordering Code Q65112A8491 GT QSSPA1.13   Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 125 °C Storage Temperature Tstg min. max. -40 °C 125 °C Junction Temperature Tj max. 135 °C Forward current IF min. max. 100 mA 1300 mA Surge Current t ≤ 10 µs; D = 0.005 ; TJ = 25 °C IFS max. 2000 mA Reverse voltage 2) VR ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD   3 Version 1.0 | 2019-04-22 Values Not designed for reverse operation 8 kV GT QSSPA1.13   Characteristics IF = 350 mA; TJ = 25 °C Parameter Symbol Peak Wavelength λpeak typ. 521 nm Dominant Wavelength 3) IF = 350 mA λdom min. typ. max. 513 nm 528 nm 543 nm Spectral Bandwidth at 50% Irel,max ∆λ typ. 29 nm Viewing angle at 50% IV 2φ typ. 120 ° Forward Voltage 4) IF = 350 mA VF min. typ. max. 2.40 V 2.70 V 3.10 V Reverse current 2) IR Electrical thermal resistance junction/solderpoint with efficiency ηe = 31 % RthJS elec.   4 Version 1.0 | 2019-04-22 Values Not designed for reverse operation typ. 6.2 K / W GT QSSPA1.13   Brightness Groups  Group Luminous Flux 1) IF = 350 mA min. ΦV Luminous Flux 1) IF = 350 mA max. ΦV LS 140.0 lm 150.0 lm LT 150.0 lm 164.0 lm LU 164.0 lm 180.0 lm MP 180.0 lm 194.0 lm MQ 194.0 lm 210.0 lm MR 210.0 lm 224.0 lm Forward Voltage Groups  Group Forward Voltage 4) IF = 350 mA min. VF Forward Voltage 4) IF = 350 mA max. VF H1 2.40 V 2.50 V H2 2.50 V 2.60 V K1 2.60 V 2.70 V K2 2.70 V 2.80 V L1 2.80 V 2.90 V L2 2.90 V 3.00 V 3.00 V 3.10 V   M1 5 Version 1.0 | 2019-04-22 GT QSSPA1.13   Wavelength Groups  Group Dominant Wavelength 3) IF = 350 mA min. λdom Dominant Wavelength 3) IF = 350 mA max. λdom 2 513 nm 519 nm 3 519 nm 525 nm 4 525 nm 531 nm 5 531 nm 537 nm 6 537 nm 543 nm   6 Version 1.0 | 2019-04-22 GT QSSPA1.13   Group Name on Label  Example: LS-2-H1 Brightness Wavelength LS 2   7 Version 1.0 | 2019-04-22 Forward Voltage H1 GT QSSPA1.13   Relative Spectral Emission 5) Irel = f (λ); IF = 350 mA; TJ = 25 °C Irel GT QSSPA1.13 1,0 : Vλ : true green 0,8 0,6 0,4 0,2 0,0 350 400 Radiation Characteristics 450 500 550 600 650 700 750 800 λ / nm 5) Irel = f (ϕ); TJ = 25 °C GT QSSPA1.13 ϕ/°  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° 0,8 0,6 -60° -70° 0,4 0,2 -90° 0,0  -80° 8 Version 1.0 | 2019-04-22 Irel GT QSSPA1.13   Forward current Relative Luminous Flux 5) IF = f(VF); TJ = 25 °C IF / mA 5), 6) Φv/Φv(350 mA) = f(IF); TJ = 25 °C GT QSSPA1.13 1300 ΦV GT QSSPA1.13 2,5 ΦV(350mA) 1200 2,0 1000 800 1,5 600 1,0 400 0,5 Dominant Wavelength 3,2 VF / V 5) Δλdom = f(IF); TJ = 25 °C ∆λ dom / nm GT QSSPA1.13 10  5 0 -5 13 00 10 00 80 0 60 0 40 0 10 0 -10  IF / mA 9 Version 1.0 | 2019-04-22 13 00 3,0 80 0 10 00 2,8 60 0 2,6 40 0 100 2,4 10 0 200 IF / mA GT QSSPA1.13   Forward Voltage Relative Luminous Flux 5) ΔVF = VF - VF(25 °C) = f(Tj); IF = 350 mA GT QSSPA1.13 ∆VF / V 0,4 5) Φv/Φv(25 °C) = f(Tj); IF = 350 mA Φv 1,2 GT QSSPA1.13 Φv(25°C) 1,1 0,2 1,0 0,9 0,0 0,8 -0,2 -40 -20 0 20 40 60 80 100 120 Tj / °C Dominant Wavelength 5) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 350 mA ∆λ dom / nm 10 5 GT QSSPA1.13  0 -5 20 40 60 80 100 120 Tj / °C  -10 -40 -20 0 10 Version 1.0 | 2019-04-22 0,7 -40 -20 0 20 40 60 80 100 120 Tj / °C GT QSSPA1.13   Max. Permissible Forward Current IF = f(T) GT QSSPA1.13 IF / mA 1300 1200 1100 1000 900 800 700 600 500 400 300 200 100 0 Do not use below 100 mA 0 20 40 60   11 Version 1.0 | 2019-04-22 80 100 120 Ts / °C GT QSSPA1.13   Dimensional Drawing 7) Further Information Approximate Weight: 24.0 mg Package marking: Anode Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43) ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   12 Version 1.0 | 2019-04-22 GT QSSPA1.13   Recommended Solder Pad 7) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning.   13 Version 1.0 | 2019-04-22 GT QSSPA1.13   Taping 7)   14 Version 1.0 | 2019-04-22 GT QSSPA1.13   Tape and Reel 8) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   15 Version 1.0 | 2019-04-22 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 600 GT QSSPA1.13   Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 16 Version 1.0 | 2019-04-22 GT QSSPA1.13   Schematic Transportation Box 7) Barcode label N O : (Q )Q TY :2 00 0 (9 D ) D /C :0 (X ) Packing Sealing label Length 195 ± 5 mm 195 ± 5 mm   17 Version 1.0 | 2019-04-22 M Y DE -1 +Q -1 R 18 P OHA02044 Dimensions of Transportation Box Width RO UP : M RA OS PR O D 5 14 2 110 0 G 4 01 4 C: D/ (9 D) 20 00 (Q )Q TY : O TC P) (6 T LO (1 T) O D PR D EM Y 18 R -1 : Q + P -1 G R O U P: u L lt S iT Y O T6 P 7 L 6 M 14 4 (G ) E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R ditio 0 C R 07 PA 7 na RT l TE C KV XT AR Muster A o M n O d u p cto to rs R 34 ic N O : O S H 12 G BA TC H (1 T) LO T N O :1 (6 P) 23 em 8 2199 2100 5 14 2 110 0 (X ) O M O PT O M 998 NO : CThISTU SE S 21 2100 BA _ < s ur s ). Ho ururs s de Ho co 72 Ho ur te 48 e Ho 24 6 da 40 be tim e e ˚C or th r pr < ll tim ct ). 23 oo r wi nt tim e at l wi fa r Fl oo tim s at at le ˚C at e. ica l Fl th oo r th va ur nt Fl oo s ui be on if: read w ed l 4 5 Fl la m ide ce eq lo g, oc ve l vi is in en de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo ba Le ve tu re m % ba e al e Le r en re e ed re 10 ois stu ur e tim se fo al op se fo > , M oi r se st ur 3 is is ha se M oi st nk be k, oo . 03 rd g M oi in an in Fl RH g, r-p bla DM ba Ca po If bl th % kinr life is (if . ar ST f p. wi 10 ba to et Jel r th va Ye ar ks s m _ < cat m d, C ed 1 Ye ee ur ire Sh te w, te di at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re qu JE 2. bo ity is M or tim e e 16 re C/ : es id 2b r a) St tim mor is IP ed oo r tim e vic b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l e Le Ba te ur e Le ve Le Da oist stur e ur e M oi st ur M oi st M oi H 12 34 . RH 0% /6 ˚C : L e el selab . , H) nk de co (R bla r S S em R ic AM o n O d u p ct to o H rs NO If 23 G E V E ba ity id m hu e e d tiv re ag NO :1 L la re fra ck 30 Nns IVE RS in pa % k of ai IT TO to 90 ea d ntNS < ns UC or TIO te (p d , g itio ND U g coSE an bjec ˚C sin nd O 5 ˚C su es Ais baRE co IC ± y M oc (G ) M u L lt S iT Y O T6 P 7 L 6 E D Muster Bi Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Barcode label Height 30 ± 5 mm GT QSSPA1.13   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class low risk (exposure time 100 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. This device is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive). Change management for this component is aligned with the requirements of the lighting market. For further application related informations please visit www.osram-os.com/appnotes   18 Version 1.0 | 2019-04-22 GT QSSPA1.13   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case Buyer – or Customer supplied by Buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales Partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.   19 Version 1.0 | 2019-04-22 GT QSSPA1.13   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of +/- 7%. 2) Reverse Operation: Not designed for reverse operation. Continuous reverse operation can cause migration and damage of the device. 3) Wavelength: The wavelength is measured at a current pulse of typically 10 ms, with a tolerance of ± 0.5 nm. 4) Forward Voltage: The Forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05V . 5) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   20 Version 1.0 | 2019-04-22 GT QSSPA1.13   Revision History Version Date Change 1.0 2019-04-15 Initial Version   21 Version 1.0 | 2019-04-22 GT QSSPA1.13     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 22 Version 1.0 | 2019-04-22
GT QSSPA1.13-LSLU-26-1-350-R18 价格&库存
很抱歉,暂时无法提供与“GT QSSPA1.13-LSLU-26-1-350-R18”相匹配的价格&库存,您可以联系我们找货
