GW PSLM31.FM-GVH1-50S5-1-65-R18
    AMSOSRAM(艾迈斯半导体)
    发光二极管/LED 白色 SMT
GW PSLM31.FM-GVH1-50S5-1-65-R18 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 GW PSLM31.FM   GW PSLM31.FM DURIS ® S 5 Applications ——Horticulture Lighting Features: ——Package: white SMT package, colored diffused silicone resin ——Typ. Radiation: 120° (Lambertian emitter) ——CRI: 90 (min.) ——ESD: 4 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3A) ——Luminous Flux: typ. 25.6 lm @ 4000 K ——Luminous efficacy: 142 lm/W @ 4000 K   1 Version 1.0 | 2018-10-12 GW PSLM31.FM   Ordering Information  Type Luminous Flux 1) IF = 65 mA ΦV Ordering Code GW PSLM31.FM-G9GW-40S5-1 24.0 ... 28.5 lm Q65112A7175 GW PSLM31.FM-GVH1-50S5-1 25.5 ... 30.0 lm Q65112A7176   2 Version 1.0 | 2018-10-12 GW PSLM31.FM   Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 100 °C Storage Temperature Tstg min. max. -40 °C 100 °C Junction Temperature Tj max. 125 °C Forward Current TJ = 25 °C IF min. max. 10 mA 400 mA Surge Current t ≤ 10 µs; D = 0.005 ; TJ = 25 °C IFS max. 300 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3A) VESD   3 Version 1.0 | 2018-10-12 Values 4 kV GW PSLM31.FM   Characteristics IF = 65 mA; TJ = 25 °C Parameter Symbol Viewing angle at 50 % IV 2φ typ. 120 ° Forward Voltage 2) VF min. typ. max. 2.60 V 2.77 V 3.00 V Color Rendering Index 3) (4000K, 5000K)  CRI min. 90 Electrical thermal resistance junction/solderpoint with efficiency ηe = 49.2 % RthJS elec. typ. 7.2 K / W   4 Version 1.0 | 2018-10-12 Values GW PSLM31.FM   Brightness Groups  Group min. ΦV G9 GV GW H1 lm lm lm lm 24.0 25.5 27.0 28.5 PPF * PPF * PPF * BPF ** BPF ** BPF ** min. Φp max. Φp typ. W min. Φp,b max. Φp,b typ. W 25.5 0.385 µmol/s 0.409 µmol/s 2.2 µmol/J 0.413 µmol/s 0.439 µmol/s 2.36 µmol/J 27.0 0.409 µmol/s 0.433 µmol/s 2.33 µmol/J 0.439 µmol/s 0.465 µmol/s 2.5 µmol/J 28.5 0.433 µmol/s 0.457 µmol/s 2.46 µmol/J 0.465 µmol/s 0.491 µmol/s 2.65 µmol/J 30.0 0.457 µmol/s 0.481 µmol/s 2.6 µmol/J 0.491 µmol/s 0.517 µmol/s 2.79 µmol/J max. ΦV lm lm lm lm Note: [1] Includes wavelengths between 400 and 700 nm Note: [2] Includes wavelengths between 280 and 800 nm Forward Voltage Groups  Group Forward Voltage 2) min. VF Forward Voltage 2) max. VF K1 2.60 V 2.70 V K2 2.70 V 2.80 V L1 2.80 V 2.90 V L2 2.90 V 3.00 V   5 Version 1.0 | 2018-10-12 GW PSLM31.FM   Chromaticity Coordinate Groups 4) Color Chromaticity Groups CCT Center Cx Center Cy a Ø b 40S5 K 0.3818 0.3796 0.0157 0.0068 53.4 45S3 K 0.3613 0.3669 0.0089 0.0038 57 50S3 K 0.3446 0.3551 0.0081 0.0035 59.8 50S5 K 0.3446 0.3551 0.0135 0.0059 59.8   6 Version 1.0 | 2018-10-12 GW PSLM31.FM   Group Name on Label  Example: G9-40S3-K1 Brightness Color Chromaticity G9 40S3   7 Version 1.0 | 2018-10-12 Forward Voltage K1 GW PSLM31.FM   Relative Spectral Emission 5) Irel = f (λ); IF = 65 mA; TJ = 25 °C Irel GW PSLM31.FM 1,0 : Vλ : 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 5) Irel = f (ϕ); TJ = 25 °C GW PSLM31.FM ϕ [°]  -40° -50° -20° -30° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 : 0° 0,8 0,6 -60° -70° -80° -90°  -100° 8 Version 1.0 | 2018-10-12 0,4 0,2 0,0 Irel GW PSLM31.FM   Forward current Relative Luminous Flux 5), 6) IF = f(VF); TJ = 25 °C IF [mA] 5), 6) Φv/Φv(65 mA) = f(IF); TJ = 25 °C GW PSLM31.FM 400 ΦV GW PSLM31.FM 6 ΦV(65mA) 350 5 300 4 250 3 200 150 2 100 1 50 VF [V] Chromaticity Coordinate Shift 5) ΔCx, ΔCy = f(IF); TJ = 25 °C ∆Cx ∆Cy GW PSLM31.FM 0,02 : ∆ Cx : ∆ Cy  0,01 0,00 -0,01 40 0 35 0 30 0 25 0 20 0 15 0 10 0 50 10 -0,02  IF [mA] 9 Version 1.0 | 2018-10-12 40 0 35 0 30 0 25 0 20 0 3,35 15 0 3,2 10 0 3,0 50 2,8 10 0 10 2,6 IF [mA] GW PSLM31.FM   Forward Voltage Relative Luminous Flux 5) ΔVF = VF - VF(25 °C) = f(Tj); IF = 65 mA Φv/Φv(25 °C) = f(Tj); IF = 65 mA GW PSLM31.FM ∆VF [V] 5) Φv GW PSLM31.FM 1,2 Φv(25°C) 0,2 1,0 0,1 0,8 0,6 0,0 0,4 -0,1 0,2 -0,2 -40 -20 0 20 40 60 80 100 120 Tj [°C] Chromaticity Coordinate Shift 5) ΔCx, ΔCy = f(Tj); IF = 65 mA ∆Cx ∆Cy GW PSLM31.FM 0,03 : ∆ Cx : ∆ Cy  0,02 0,01 0,00 -0,01 -0,02 -0,03 -40 -20 0 20 40 60 80 100 120  Tj [°C] 10 Version 1.0 | 2018-10-12 0,0 -40 -20 0 20 40 60 80 100 120 Tj [°C] GW PSLM31.FM   Max. Permissible Forward Current IF = f(T) IF [mA] GW PSLM31.FM 450 400 350 300 250 200 150 100 50 0 0 20 40 60 80 100 Ts [°C]   11 Version 1.0 | 2018-10-12 GW PSLM31.FM   Dimensional Drawing 7) Approximate Weight: 20.0 mg Package marking: Cathode ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   12 Version 1.0 | 2018-10-12 GW PSLM31.FM   Recommended Solder Pad 7) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning.   13 Version 1.0 | 2018-10-12 GW PSLM31.FM   Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 14 Version 1.0 | 2018-10-12 °C 480 s K/s s GW PSLM31.FM   Dimensional Drawing   15 Version 1.0 | 2018-10-12 7) GW PSLM31.FM   Tape and Reel 8) Reel dimensions [mm] A 180 mm W Nmin 12 + 0.3 / - 0.1   16 Version 1.0 | 2018-10-12 W1 60 W2 max 12.4 + 2 18.4 Pieces per PU GW PSLM31.FM   Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 17 Version 1.0 | 2018-10-12 GW PSLM31.FM   Transportation Packing and Materials 7) Barcode label N O : (Q )Q TY :2 00 0 (9 D ) D /C :0 (X ) Packing Sealing label Length 195 ± 5 mm 195 ± 5 mm   18 Version 1.0 | 2018-10-12 M Y DE -1 +Q -1 R 18 P OHA02044 Dimensions of transportation box in mm Width RO UP : M RA OS PR O D 5 14 2 110 0 G 4 01 4 C: D/ (9 D) 20 00 (Q )Q TY : O TC P) (6 T LO (1 T) O D PR D EM Y 18 R -1 : Q + P -1 G R O U P: u L lt S iT Y O T6 P 7 L 6 M 14 4 (G ) E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R ditio 0 C R 07 PA 7 na RT l TE C KV XT AR Muster A o M n O d u p cto to rs R 34 ic N O : O S H 12 G BA TC H (1 T) LO T N O :1 (6 P) 23 em 8 2199 2100 5 14 2 110 0 (X ) O M O PT O M 998 NO : CThISTU SE S 21 2100 BA _ < s ur s ). Ho ururs s de Ho co 72 Ho ur te 48 e Ho 24 6 da 40 be tim e e ˚C or th r pr < ll tim ct ). 23 oo r wi nt tim e at l wi fa r Fl oo tim s at at le ˚C at e. ica l Fl th oo r th va ur nt Fl oo s ui be on if: read w ed l 4 5 Fl la m ide ce eq lo g, oc ve l vi is in en de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo ba Le ve tu re m % ba e al e Le r en re e ed re 10 ois stu ur e tim se fo al op se fo > , M oi r se st ur 3 is is ha se M oi st nk be k, oo . 03 rd g M oi in an in Fl RH g, r-p bla DM ba Ca po If bl th % kinr life is (if . ar ST f p. wi 10 ba to et Jel r th va Ye ar ks s m _ < cat m d, C ed 1 Ye ee ur ire Sh te w, te di at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re qu JE 2. bo ity is M or tim e e 16 re C/ : es id 2b r a) St tim mor is IP ed oo r tim e vic b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l e Le Ba te ur e Le ve Le Da oist stur e ur e M oi st ur M oi st M oi H 12 34 . RH 0% /6 ˚C : L e el selab . , H) nk de co (R bla r S S em R ic AM o n O d u p ct to o H rs NO If 23 G E V E ba ity id m hu e e d tiv re ag NO :1 L la re fra ck 30 Nns IVE RS in pa % k of ai IT TO to 90 ea d ntNS < ns UC or TIO te (p d , g itio ND U g coSE an bjec ˚C sin nd O 5 ˚C su es Ais baRE co IC ± y M oc (G ) M u L lt S iT Y O T6 P 7 L 6 E D Muster Bi Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Barcode label Height 30 ± 5 mm GW PSLM31.FM   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related informations please visit www.osram-os.com/appnotes   19 Version 1.0 | 2018-10-12 GW PSLM31.FM   Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the OSRAM OS Webside. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.   20 Version 1.0 | 2018-10-12 GW PSLM31.FM   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of +/- 7%. 2) Forward Voltage: The Forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05V . 3) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 10 ms and with a tolerance of ±2. 4) Chromaticity coordinate groups: Chromaticity coordinate groups are measured during a current pulse duration of typically 10ms with a tolerance of ±0.005. 5) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   21 Version 1.0 | 2018-10-12 GW PSLM31.FM     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 22 Version 1.0 | 2018-10-12
GW PSLM31.FM-GVH1-50S5-1-65-R18 价格&库存
很抱歉,暂时无法提供与“GW PSLM31.FM-GVH1-50S5-1-65-R18”相匹配的价格&库存,您可以联系我们找货
    • 1+1.63080
    • 10+1.58760
    • 30+1.56600
    • 100+1.54440
    库存:223
    • 4500+2.226034500+0.28883
    • 9000+2.119999000+0.27507
    • 13500+2.0656313500+0.26802
    • 22500+2.0043022500+0.26006
    • 31500+1.9678631500+0.25533
    • 45000+1.9323245000+0.25072
    库存:387
    • 1+6.431651+0.83450
    • 10+4.4648910+0.57932
    • 100+3.24937100+0.42161
    • 500+2.70479500+0.35095
    • 1000+2.526301000+0.32779
    • 2000+2.374582000+0.30810
    库存:387
