KRTBAELPS1.32-V1A4-JW+B4B6-D8S6U2-7Z-S
    AMSOSRAM(艾迈斯半导体)
    发光二极管/LED SMT
KRTBAELPS1.32-V1A4-JW+B4B6-D8S6U2-7Z-S 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 KRTB AELPS1.32   KRTB AELPS1.32 OSIRE ® E5515 The OSRAM OSIRE KRTB AELPS1.32 RGB sidelooker device is specifically designed for automotive interior applications. It offers individually addressable LED chips for a maximum of flexibility in terms of color point, driver selection and interconnection. Due to the low profile, the OSIRE KRTB AELPS1.32 is ideally suited for coupling into thin lightguides and enables ultra compact designs. Applications ——Interior Illumination (e.g. Ambient Map) Features: ——Package: white SMT package, colorless clear silicone resin ——Chip technology: Thinfilm / UX:3 ——Typ. Radiation: 120° (Lambertian emitter) ——Color: λdom = 625 nm (● red); λdom = 528 nm (● true green); λdom = 465 nm (● blue)  ——Corrosion Robustness Class: 2B  ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) 1 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Ordering Information  Type Brightness 1) Ordering Code KRTBAELPS1.32-V1A4-JW+B4B6-D8+S6U2-7Z Q65112A6747 ● red ● Iv = 710 ... 1590 mcd (IF = 20 mA) Q65112A6747 ● true green ● Iv = 2010 ... 3200 mcd (IF = 20 mA) Q65112A6747 ● blue ● Iv = 250 ... 710 mcd (IF = 20 mA) Q65112A6747   2 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Maximum Ratings  Parameter Symbol Values ● red Values ● true green Values ● blue Operating Temperature  Top min. max. -40 °C 110 °C -40 °C 110 °C -40 °C 110 °C Storage Temperature  Tstg min. max. -40 °C 110 °C -40 °C 110 °C -40 °C 110 °C Junction Temperature  Tj max. 125 °C 125 °C 125 °C Forward Current  TS = 25 °C IF min. max. 5 mA 50 mA 5 mA 50 mA 5 mA 50 mA Surge Current  t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 100 mA 300 mA 300 mA Reverse voltage 2) TS = 25 °C VR max. 12 V 5V 5V ESD withstand voltage  acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD 2 kV 2 kV 2 kV   3 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Characteristics  IF = 20 mA; TS = 25 °C Parameter Symbol Values ● red Values ● true green Values ● blue Peak Wavelength  λpeak typ. 632 nm 523 nm 455 nm Dominant Wavelength 3) λdom min. typ. max. 620 nm 625 nm 632 nm 519 nm 528 nm 546 nm 447 nm 465 nm 476 nm Spectral bandwidth at 50% Irel,max  ∆λ typ. 18 nm 33 nm 25 nm Viewing angle at 50% IV  2φ typ. 120 ° 120 ° 120 ° Forward Voltage  VF typ. 1.95 V 2.60 V 2.85 V Reverse current 2) VR = 5 V (blue / true green); 12 V (red)  IR typ. max. 0.01 µA 10 µA 0.01 µA 10 µA 0.01 µA 10 µA Real thermal resistance junction/solderpoint 5) RthJS real typ. max. 53 K / W 78 K / W 38 K / W 52 K / W 30 K / W 48 K / W 4)   4 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Brightness Groups  Color of emission Group ● red V1 710 mcd 900 mcd ● red V4 800 mcd 1000 mcd ● red V2 900 mcd 1120 mcd ● red V6 1000 mcd 1250 mcd ● red AA 1120 mcd 1400 mcd ● red A4 1250 mcd 1590 mcd ● true green B4 2010 mcd 2500 mcd ● true green BB 2240 mcd 2800 mcd ● true green B6 2500 mcd 3200 mcd ● blue S6 250 mcd 320 mcd ● blue T1 280 mcd 355 mcd ● blue T4 315 mcd 400 mcd ● blue T2 355 mcd 450 mcd ● blue T6 400 mcd 500 mcd ● blue U1 450 mcd 560 mcd ● blue U4 500 mcd 630 mcd ● blue U2 560 mcd 710 mcd   5 Version 1.0 | 2019-11-20 Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity 1) IF = 20 mA max. Iv KRTB AELPS1.32   Wavelength Groups ● red Group Dominant Wavelength 3) min. λdom Dominant Wavelength 3) max. λdom JP 620 nm 625 nm MT 623 nm 629 nm RW 627 nm 632 nm Wavelength Groups ● true green Group Dominant Wavelength 3) min. λdom Dominant Wavelength 3) max. λdom DJ 519 nm 524 nm FL 521 nm 526 nm JP 524 nm 529 nm LR 526 nm 531 nm PU 529 nm 534 nm RW 531 nm 536 nm U3 534 nm 541 nm 18 539 nm 546 nm   6 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Wavelength Groups ● blue Group Dominant Wavelength 3) min. λdom Dominant Wavelength 3) max. λdom 73 447 nm 451 nm 51 449 nm 453 nm 3C 451 nm 456 nm AF 454 nm 459 nm DH 457 nm 461 nm FK 459 nm 463 nm HM 461 nm 465 nm KP 463 nm 467 nm MS 465 nm 470 nm QV 468 nm 473 nm TZ 471 nm 476 nm   7 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Chromaticity Coordinate Groups KRTB AELPS1.32 Cy 0, 8 550 nm 0, 6 500 nm 0, 4 600 nm  0, 2 700 750 nm 400 380nm 0, 0  0, 0 8 Version 1.0 | 2019-11-20 0, 2 0, 4 0, 6 0, 8 Cx KRTB AELPS1.32   Chromaticity Coordinate Groups  ● red Group Cx Cy JP 0.6879 0.3086 0.6915 0.3083 0.7006 0.2993 0.6969 0.2996 0.6936 0.3030 0.6972 0.3027 0.7066 0.2934 0.7028 0.2938 0.7000 0.2966 0.7037 0.2962 0.7105 0.2895 0.7067 0.2899 MT RW   9 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Chromaticity Coordinate Groups  ● true green Group Cx Cy 18 0.2362 0.7067 0.2288 0.7353 0.2752 0.7042 0.2776 0.6881 0.1401 0.6951 0.1201 0.7325 0.1415 0.7518 0.1606 0.7102 0.1486 0.7014 0.1273 0.7439 0.1517 0.7547 0.1698 0.7127 0.1606 0.7102 0.1415 0.7518 0.1679 0.7565 0.1831 0.7174 0.1694 0.7136 0.1517 0.7547 0.1794 0.7549 0.1933 0.7170 0.1831 0.7174 0.1678 0.7565 0.1973 0.7500 0.2091 0.7142 0.1932 0.7170 0.1794 0.7549 0.2098 0.7449 0.2196 0.7122 0.2091 0.7142 0.1974 0.7500 0.2419 0.7273 0.2474 0.7029 DJ FL JP LR PU  RW  U3 10 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Chromaticity Coordinate Groups  ● blue Group Cx Cy 3C 0.1588 0.0243 0.1556 0.0186 0.1500 0.0246 0.1543 0.0317 0.1606 0.0222 0.1576 0.0168 0.1534 0.0206 0.1570 0.0268 0.1622 0.0203 0.1595 0.0152 0.1556 0.0186 0.1588 0.0243 0.1562 0.0285 0.1524 0.0219 0.1462 0.0293 0.1509 0.0370 0.1532 0.0332 0.1489 0.0262 0.1436 0.0332 0.1487 0.0414 0.1509 0.0370 0.1462 0.0293 0.1407 0.0376 0.1463 0.0463 0.1487 0.0414 0.1436 0.0332 0.1375 0.0428 0.1436 0.0519 0.1463 0.0463 0.1407 0.0376 0.1338 0.0493 0.1404 0.0588 51 73 AF DH FK  HM  KP 11 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Chromaticity Coordinate Groups  ● blue Group Cx Cy MS 0.1436 0.0519 0.1375 0.0428 0.1272 0.0620 0.1354 0.0727 0.1389 0.0631 0.1317 0.0532 0.1199 0.0785 0.1295 0.0899 0.1335 0.0779 0.1251 0.0672 0.1115 0.1000 0.1231 0.1122 QV TZ   12 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Relative Spectral Emission 6) Irel = f (λ); IF = 20 mA; TS = 25 °C Irel KRTB AELPS1.32 EN 1.0 : Vλ : red : true green : blue 0.8 0.6 0.4 0.2 0.0 350 400 Radiation Characteristics 450 500 550 600 650 700 750 800 λ / nm 6) Irel = f (ϕ); TS = 25 °C KRTB AELPS1.32 EN ϕ/°  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 -30° 0.8 0.6 -60° -70° 0.4 -80° 0.2 -90° 0.0  -100° 13 Version 1.0 | 2019-11-20 Irel KRTB AELPS1.32   Forward current Forward current 6) IF = f(VF); TS = 25 °C IF / mA IF = f(VF); TS = 25 °C KRTB AELPS1.32 EN 50 IF / mA : red 30 30 20 20 10 10 1.8 1.9 2.0 2.1 2.2 VF / V 6) IF = f(VF); TS = 25 °C KRTB AELPS1.32 EN 50 : blue  40 30 20 10 2.7 2.8  5 2.6 14 Version 1.0 | 2019-11-20 2.9 3.0 3.1 3.2 VF / V KRTB AELPS1.32 EN : true green 40 Forward current IF / mA 50 40 5 1.7 6) 5 2.3 2.4 2.6 2.8 3.0 3.1 VF / V KRTB AELPS1.32   Relative Luminous Intensity Relative Luminous Intensity 6) Iv/Iv(20 mA) = f(IF); TS = 25 °C IV(20mA) Iv/Iv(20 mA) = f(IF); TS = 25 °C KRTB AELPS1.32 EN IV 2.5 6) IV : red KRTB AELPS1.32 EN 2.0 IV(20mA) : true green 1.5 2.0 1.5 1.0 1.0 0.5 0.5 IF / mA Relative Luminous Intensity 6) Iv/Iv(20 mA) = f(IF); TS = 25 °C KRTB AELPS1.32 EN IV IV(20mA) : blue 2.0  1.5 1.0 0.5 50 40 45 30 35 20 25 5 10 15 0.0  IF / mA 15 Version 1.0 | 2019-11-20 50 35 40 45 20 25 30 5 10 15 50 40 45 30 35 20 25 5 0.0 10 15 0.0 IF / mA KRTB AELPS1.32   Dominant Wavelength Dominant Wavelength 6) Δλdom = f(IF); TS = 25 °C ∆λ dom / nm Δλdom = f(IF); TS = 25 °C KRTB AELPS1.32 KRTB AELPS1.32 10 6) ∆λ dom / nm : true green 6 : blue 4 5 2 0 0 -2 -5 -4 -6   16 Version 1.0 | 2019-11-20 50 35 40 45 5 20 25 30 IF / mA 10 15 50 40 45 30 35 20 25 5 10 15 -10 IF / mA KRTB AELPS1.32   Forward Voltage Forward Voltage 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF / V ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA KRTB AELPS1.32 EN 0.3 6) KRTB AELPS1.32 EN ∆VF / V : red : true green 0.4 0.2 0.1 0.2 0.0 0.0 -0.1 -0.2 -0.2 -0.3 -40 -20 0 Forward Voltage 20 40 60 80 100 120 Tj / °C 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF / V 0.3 KRTB AELPS1.32 EN : blue 0.2 0.1  0.0 -0.1 -0.2 20 40 60 80 100 120 Tj / °C  -0.3 -40 -20 0 17 Version 1.0 | 2019-11-20 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS1.32   Relative Luminous Intensity 6) Iv/Iv(25 °C) = f(Tj); IF = 20 mA Iv 1.6 Relative Luminous Intensity 6) Iv/Iv(25 °C) = f(Tj); IF = 20 mA KRTB AELPS1.32 EN Iv(25°C) Iv : red 1.4 1.2 KRTB AELPS1.32 EN Iv(25°C) : true green 1.0 1.2 0.8 1.0 0.8 0.6 0.6 0.4 0.4 0.2 0.2 0.0 -40 -20 0 20 40 60 80 100 120 Tj / °C Relative Luminous Intensity 6) Iv/Iv(25 °C) = f(Tj); IF = 20 mA Iv 1.2 Iv(25°C) KRTB AELPS1.32 EN : blue 1.0 0.8  0.6 0.4 0.2 20 40 60 80 100 120 Tj / °C  0.0 -40 -20 0 18 Version 1.0 | 2019-11-20 0.0 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS1.32   Dominant Wavelength 6) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA Dominant Wavelength Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA KRTB AELPS1.32 ∆λ dom / nm 8 ∆λ dom / nm : red KRTB AELPS1.32 10 8 6 6) : true green 6 4 4 2 2 0 0 -2 -2 -4 -4 -6 -6 -8 -40 -20 0 20 40 60 80 100 120 Tj / °C Dominant Wavelength 6) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA KRTB AELPS1.32 ∆λ dom / nm 8 : blue 6 4  2 0 -2 -4 -6 20 40 60 80 100 120 Tj / °C  -40 -20 0 19 Version 1.0 | 2019-11-20 -8 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS1.32   Max. Permissible Forward Current Max. Permissible Forward Current IF = f(T); ● red IF = f(T); ● true green one chip on IF / mA 50 45 45 40 40 35 35 30 : Ts 25 15 15 10 10 5 5 20 40 60 80 100 Max. Permissible Forward Current IF = f(T); ● blue one chip on KRTB AELPS1.32 55 50  45 40 35 30 : Ts 25 20 15 10 5 0 0 20 40 60 80 100  Ts / °C 20 Version 1.0 | 2019-11-20 : Ts 25 20 Ts / °C blue 30 20 0 KRTB AELPS1.32 55 50 0 IF / mA one chip on KRTB AELPS1.32 55 true green red IF / mA 0 0 20 40 60 80 100 Ts / °C KRTB AELPS1.32   Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● red IF = f(tp); D: Duty cycle; TS = 25 °C; ● true green KRTB AELPS1.32 KRTB AELPS1.32 TS = 0°C ... 110°C IF / A TS = 0°C ... 110°C IF / A 0.12 0.3 0.10 0.08 true green red : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0.06 0.2 0.1 10-6 10-5 10-4 10-3 0.01 0.1 1 10-6 10 / Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● blue KRTB AELPS1.32 TS = 0°C ... 110°C IF / A  0.3 blue : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0.2 0.1 10-6 10-5 10-4 10-3 0.01 0.1 1 10  / 21 Version 1.0 | 2019-11-20 10-5 10-4 10-3 0.01 0.1 1 10 / KRTB AELPS1.32   Dimensional Drawing 7) Further Information: Approximate Weight: 26.0 mg Corrosion test: Class: 2B Test condition: 25°C / 75 % RH / 10 ppm H2S / 21 days (IEC 60068-2-43)   22 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Electrical Internal Circuit   23 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Recommended Solder Pad 7) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for any kind of wet cleaning or ultrasonic cleaning.   24 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 25 Version 1.0 | 2019-11-20 °C 480 s K/s s KRTB AELPS1.32   Taping 7)   26 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Tape and Reel 8) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   27 Version 1.0 | 2019-11-20 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 2000 KRTB AELPS1.32   Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 28 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Schematic Transportation Box 7) Barcode label N O : (Q )Q TY :2 00 0 (9 D ) D /C :0 (X ) Packing Sealing label Length 195 ± 5 mm 195 ± 5 mm   29 Version 1.0 | 2019-11-20 M Y DE -1 +Q -1 R 18 P OHA02044 Dimensions of Transportation Box Width RO UP : M RA OS PR O D 5 14 2 110 0 G 4 01 4 C: D/ (9 D) 20 00 (Q )Q TY : O TC P) (6 T LO (1 T) O D PR D EM Y 18 R -1 : Q + P -1 G R O U P: u L lt S iT Y O T6 P 7 L 6 M 14 4 (G ) E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R ditio 0 C R 07 PA 7 na RT l TE C KV XT AR Muster A o M n O d u p cto to rs R 34 ic N O : O S H 12 G BA TC H (1 T) LO T N O :1 (6 P) 23 em 8 2199 2100 5 14 2 110 0 (X ) O M O PT O M 998 NO : CThISTU SE S 21 2100 BA _ < s ur s ). Ho ururs s de Ho co 72 Ho ur te 48 e Ho 24 6 da 40 be tim e e ˚C or th r pr < ll tim ct ). 23 oo r wi nt tim e at l wi fa r Fl oo tim s at at le ˚C at e. ica l Fl th oo r th va ur nt Fl oo s ui be on if: read w ed l 4 5 Fl la m ide ce eq lo g, oc ve l vi is in en de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo ba Le ve tu re m % ba e al e Le r en re e ed re 10 ois stu ur e tim se fo al op se fo > , M oi r se st ur 3 is is ha se M oi st nk be k, oo . 03 rd g M oi in an in Fl RH g, r-p bla DM ba Ca po If bl th % kinr life is (if . ar ST f p. wi 10 ba to et Jel r th va Ye ar ks s m _ < cat m d, C ed 1 Ye ee ur ire Sh te w, te di at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re qu JE 2. bo ity is M or tim e e 16 re C/ : es id 2b r a) St tim mor is IP ed oo r tim e vic b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l e Le Ba te ur e Le ve Le Da oist stur e ur e M oi st ur M oi st M oi H 12 34 . RH 0% /6 ˚C : L e el selab . , H) nk de co (R bla r S S em R ic AM o n O d u p ct to o H rs NO If 23 G E V E ba ity id m hu e e d tiv re ag NO :1 L la re fra ck 30 Nns IVE RS in pa % k of ai IT TO to 90 ea d ntNS < ns UC or TIO te (p d , g itio ND U g coSE an bjec ˚C sin nd O 5 ˚C su es Ais baRE co IC ± y M oc (G ) M u L lt S iT Y O T6 P 7 L 6 E D Muster Bi Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Barcode label Height 30 ± 5 mm KRTB AELPS1.32   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   30 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   31 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed. 3) Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k = 3). 4) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 5) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   32 Version 1.0 | 2019-11-20 KRTB AELPS1.32   Revision History Version Date Change 1.0 2019-11-20 Initial Version   33 Version 1.0 | 2019-11-20 KRTB AELPS1.32     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 34 Version 1.0 | 2019-11-20
KRTBAELPS1.32-V1A4-JW+B4B6-D8S6U2-7Z-S 价格&库存
很抱歉,暂时无法提供与“KRTBAELPS1.32-V1A4-JW+B4B6-D8S6U2-7Z-S”相匹配的价格&库存,您可以联系我们找货
  • 1+7.67880
  • 10+6.41520
  • 30+5.72400
  • 100+4.94640
  • 500+4.60080
  • 1000+4.43880
库存:918
KRTBAELPS1.32-V1A4-JW+B4B6-D8+S6U2-7Z-S
  • 1+7.47360
  • 10+6.22080
  • 30+5.51880
  • 100+4.74120
  • 500+4.39560
  • 1000+4.23360
库存:2598
  • 1+6.604161+0.85710
  • 10+4.5803010+0.59444
  • 100+3.33670100+0.43305
  • 500+2.78052500+0.36086
  • 1000+2.597921000+0.33717
库存:82164
