KW2 CFLNM3.TK-D5T2-4L07M0-SC6B
    AMSOSRAM(艾迈斯半导体)
    SIP4
    发光二极管/LED 白色 SMT
KW2 CFLNM3.TK-D5T2-4L07M0-SC6B 数据手册
www.osram-os.com K W2 CFLNM3.TK DATASHEET KW2 CFLNM3.TK Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.0 | 2022-11-04 1 rights K W2 CFLNM3.TK DATASHEET OSLON® Compact PL KW2 CFLNM3.TK Compact light source with isolated thermal pad for improved heat dissipation and small z-tolerance (+/- 35 µm). The OSLON Compact PL product family meets both excellent brightness in combination with outstanding luminance. Applications - Dynamic Forward Lighting - Static Forward Lighting Features - Package: Ceramic package - Chip technology: UX:3  - Typ. Radiation: 120° (Lambertian emitter) - Color: Cx = 0.325, Cy = 0.345 acc. to CIE 1931 (● white) - Corrosion Robustness Class: 3A - Qualifications: AEC-Q102 Qualified - ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)  - Color over angle: Better than passus 3.7.2.1 of supplement proposal 7 to ECE reg. 128 2 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Ordering Information  Type Luminous Flux 1) IF = 1000 mA ΦV KW2 CFLNM3.TK-D5T2-4L07M0-SC6B   3 | Version 1.0 | 2022-11-04 790 ... 1100 lm Ordering Code Q65113A4038 K W2 CFLNM3.TK DATASHEET Maximum Ratings Parameter Symbol Operating Temperature 2) Top min. max. -40 °C 135 °C Storage Temperature Tstg min. max. -40 °C 135 °C Junction Temperature Tj max. 150 °C Junction Temperature for short time applications* Tj max. 175 °C Forward current TS = 25 °C IF min. max. 50 mA 1500 mA Forward current pulsed D = 0.005 ; TS = 25 °C IF pulse max. 1500 mA Surge current t ≤ 50 μs; D = 0.025; TJ = 150 °C  IFS max. 2000 mA Surge current t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 2500 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD Reverse current 3) IR * The median lifetime (L70/B50) for Tj = 175°C is 100h.   4 | Version 1.0 | 2022-11-04 Values 8 kV max. 200 mA K W2 CFLNM3.TK DATASHEET Characteristics IF = 1000 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 4) Cx Cy typ. typ. 0.325 0.345 Viewing angle at 50% IV 2φ typ. 120 ° Forward Voltage 5) IF = 1000 mA VF min. typ. max. 5.60 V 6.32 V 6.75 V Reverse voltage (ESD device) VR ESD min. 45 V Reverse voltage  IR = 20 mA VR max. 1.2 V Real thermal resistance junction/solderpoint 6) RthJS real typ. max. 3.3 K / W 3.9 K / W Electrical thermal resistance junction/solderpoint 6) with efficiency ηe = 39 % RthJS elec. typ. max. 2.0 K / W 2.4 K / W 3)   5 | Version 1.0 | 2022-11-04 Values K W2 CFLNM3.TK DATASHEET Brightness Groups  Group Luminous Flux 1) IF = 1000 mA min. ΦV Luminous Flux 1) IF = 1000 mA max. ΦV D5 790 lm 825 lm D6 825 lm 860 lm D7 860 lm 900 lm D8 900 lm 940 lm D9 940 lm 980 lm T0 980 lm 1020 lm T1 1020 lm 1060 lm T2 1060 lm 1100 lm Forward Voltage Groups  Group Forward Voltage 5) IF = 1000 mA min. VF Forward Voltage 5) IF = 1000 mA max. VF SC 5.60 V 6.20 V 6B 6.20 V 6.75 V   6 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Chromaticity Coordinate Groups   550 nm 500 nm 600 nm 700 750 nm 400 380 nm 7M0  7L0 6M0  6L0 5M0 5L0 4M0 4L0   7 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Chromaticity Coordinate Groups 4) Group Cx Cy Group Cx Cy Group Cx Cy 4L0 0.3100 0.3065 5M0 0.3160 0.3261 7L0 0.3281 0.3428 0.3100 0.3185 0.3160 0.3391 0.3281 0.3548 0.3160 0.3306 0.3221 0.3512 0.3317 0.3620 0.3160 0.3186 0.3221 0.3382 0.3342 0.3635 0.3100 0.3140 0.3221 0.3307 0.3342 0.3549 0.3100 0.3270 0.3221 0.3427 0.3281 0.3503 0.3160 0.3391 0.3281 0.3548 0.3281 0.3597 0.3160 0.3261 0.3281 0.3428 0.3342 0.3635 0.3160 0.3186 0.3221 0.3382 0.3342 0.3624 0.3160 0.3306 0.3221 0.3512 0.3221 0.3427 0.3254 0.3578 0.3221 0.3307 0.3281 0.3597 0.3281 0.3503 4M0 5L0   8 | Version 1.0 | 2022-11-04 6L0 6M0 7M0 K W2 CFLNM3.TK DATASHEET Group Name on Label  Example: D5-4L0-6B Brightness Color Chromaticity D5 4L0   9 | Version 1.0 | 2022-11-04 Forward Voltage 6B K W2 CFLNM3.TK DATASHEET Relative Spectral Emission 7) Φrel = f (λ); IF = 1000 mA; TJ = 25 °C Φ KW2 CFLNM3.TK 1.0 : Vλ : white 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 800 λ/ Radiation Characteristics 7) Irel = f (ϕ); TJ = 25 °C KW2 CFLNM3.TK ϕ/  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 -30° 0.8 0.6 -60° -70° -80° -90°  -100° 10 | Version 1.0 | 2022-11-04 0.4 0.2 0.0 I K W2 CFLNM3.TK DATASHEET Forward current Relative Luminous Flux 7) IF = f(VF); TJ = 25 °C IF / mA 7), 8) Φv/Φv(1000 mA) = f(IF); TJ = 25 °C KW2 CFLNM3.TK ΦV KW2 CFLNM3.TK 1500 ΦV(1000mA) 1.4 1400 1.2 1200 1.0 1000 0.8 800 0.6 600 0.4 400 0.2 200 6.6 6.8 VF / V Chromaticity Coordinate Shift 7) Cx, Cy = f(IF); TJ = 25 °C KW2 CFLNM3.TK Cx Cy : Cx : Cy 0.340  0.335 0.330 0.325 0.320 15 00 10 00 12 00 80 0 60 0 40 0 50 20 0 0.315  IF / mA 11 | Version 1.0 | 2022-11-04 15 00 6.4 10 00 12 00 6.2 80 0 6.0 60 0 5.8 40 0 5.6 50 20 0 0.0 50 5.3 IF / mA K W2 CFLNM3.TK DATASHEET Forward Voltage Relative Luminous Flux 7) ΔVF = VF - VF(25 °C) = f(Tj); IF = 1000 mA ∆VF / V Φv/Φv(25 °C) = f(Tj); IF = 1000 mA KW2 CFLNM3.TK 0.8 7) Φv KW2 CFLNM3.TK 1.2 Φv(25°C) 0.6 1.0 0.4 0.8 0.2 0.6 0.0 0.4 -0.2 0.2 -0.4 -40 -20 0 20 40 60 80 100 120 140 Tj / °C Chromaticity Coordinate Shift 7) Cx, Cy = f(Tj); IF = 1000 mA KW2 CFLNM3.TK Cx Cy 0.335 : Cx : Cy  0.330 0.325 0.320 0.315 0.310 -40 -20 0 20 40 60 80 100 120 140  Tj / °C 12 | Version 1.0 | 2022-11-04 0.0 -40 -20 0 20 40 60 80 100 120 140 Tj / °C K W2 CFLNM3.TK DATASHEET IF / mA 1600 1500 1400 1300 1200 1100 1000 900 800 : Ts 700 600 500 400 300 200 100 0 0 20 40 60 80 100 120 140 T / °C   13 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Dimensional Drawing 9) Further Information: Approximate Weight: 19.4 mg Corrosion test: Class: 3A Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43) ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   14 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Electrical Internal Circuit   15 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Recommended Solder Pad 9) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. To ensure a high solder joint reliability and to minimize the risk of solder joint cracks, the customer is responsible to evaluate the combination of PCB board and solder paste material for his application.   16 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 17 | Version 1.0 | 2022-11-04 °C 480 s K/s s K W2 CFLNM3.TK DATASHEET Taping 9)   18 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Tape and Reel 10) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   19 | Version 1.0 | 2022-11-04 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 4000 K W2 CFLNM3.TK DATASHEET Barcode-Product-Label (BPL) Dry Packing Process and Materials 9) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 20 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers avoid device exposure to aggressive substances during storage, production, and use. For further application related information please visit www.osram-os.com/appnotes   21 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on our website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications Our components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. Our products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using our components in product safety devices/ applications or medical devices/applications, buyer and/or customer has to inform our local sales partner immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request between us and buyer and/or customer.   22 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Operating Temperature: The Operating Temperatur Top is referenced to the Solderpoint Ts of this device. Proper current derating must be observed to maintain junction temperature below the maximum. 3) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 4) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 5) Forward Voltage: The forward voltage is measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 6) Thermal Resistance: Rth max is based on statistic values (6σ). 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   23 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET Revision History Version Date Change 1.0 2022-11-04 Initial Version   24 | Version 1.0 | 2022-11-04 K W2 CFLNM3.TK DATASHEET   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All rights reserved 25 | Version 1.0 | 2022-11-04
KW2 CFLNM3.TK-D5T2-4L07M0-SC6B 价格&库存
很抱歉,暂时无法提供与“KW2 CFLNM3.TK-D5T2-4L07M0-SC6B”相匹配的价格&库存,您可以联系我们找货
    • 1+15.72480
    • 10+15.37920
    • 30+15.15240
    库存:10
