KW3 HNL631.TK-7TTC-6L07M0-JCAB
    AMSOSRAM(艾迈斯半导体)
    模块
    LED 照明 OSLON® Black Flat X 白色 9.61V 1A 120° 模块
KW3 HNL631.TK-7TTC-6L07M0-JCAB 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 KW3 HNL631.TK   KW3 HNL631.TK OSLON ® Black Flat X The OSLON Black Flat X product family offers LED devices with the highest efficiency in the Osram portfolio. This feature makes it the perfect light source for standard forward lighting applications with a high focus on system cost. The SMT device is very stable, durable and can be used with standard processes. The pad geometry of the widely used OSLON Black Flat product platform was further optimized to allow for excellent thermal conditions, while the already known, outstanding contrast of the package concept is kept on the familiar level. Applications —Headlamps, LED & Laser & Night Vision Features: —Package: SMD epoxy package —Chip technology: UX:3  —Typ. Radiation: 120° (Lambertian emitter) —Color: Cx = 0.321, Cy = 0.339 acc. to CIE 1931 (● ultra white) —Corrosion Robustness Class: 3B —Qualifications: AEC-Q102 Qualified —ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)  —Color over angle: Better than passus 3.7.2.1 of supplement proposal 7 to ECE reg. 128 1 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Ordering Information  Type Luminous Flux 1) IF = 1000 mA ΦV Ordering Code KW3 HNL631.TK-6TTB-4L05M0-JCAB 1230 ... 1535 lm Q65113A1249 KW3 HNL631.TK-7TTC-6L07M0-JCAB 1275 ... 1595 lm Q65113A1297 During ramp up a smaller amount of pcs are taped on one reel.   2 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Maximum Ratings Parameter Symbol Operating Temperature 2) Top min. max. -40 °C 135 °C Storage Temperature Tstg min. max. -40 °C 135 °C Junction Temperature Tj max. 150 °C Junction Temperature for short time applications* Tj max. 175 °C Forward current TS = 25 °C IF min. max. 50 mA 1500 mA Forward current pulsed D = 0.005 ; TS = 25 °C IF pulse max. 1500 mA Surge current t ≤ 50 μs; D = 0.025; TJ = 150 °C  IFS max. 2000 mA Surge current t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 2500 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD Reverse current 3) IR * The median lifetime (L70/B50) for Tj = 175°C is 100h.   3 Version 1.1 | 2022-01-17 Values 8 kV max. 200 mA KW3 HNL631.TK   Characteristics IF = 1000 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 4) Cx Cy typ. typ. 0.321 0.339 Viewing angle at 50% IV 2φ typ. 120 ° Radiating surface Acolor typ. 3,3 mm² Forward Voltage 5) IF = 1000 mA VF min. typ. max. 8.40 V 9.61 V 10.15 V Reverse voltage (ESD device) VR ESD min. 45 V Reverse voltage 3) IR = 20 mA VR max. 1.2 V Real thermal resistance junction/solderpoint 6) RthJS real typ. max. 1.35 K / W 1.64 K / W Electrical thermal resistance junction/solderpoint 6) with efficiency ηe = 39 % RthJS elec. typ. max. 0.82 K / W 1.00 K / W   4 Version 1.1 | 2022-01-17 Values KW3 HNL631.TK   Brightness Groups  Group Luminous Flux 1) IF = 1000 mA min. ΦV Luminous Flux 1) IF = 1000 mA max. ΦV 6T 1230 lm 1275 lm 7T 1275 lm 1325 lm T8 1325 lm 1375 lm T9 1375 lm 1425 lm TA 1425 lm 1480 lm TB 1480 lm 1535 lm TC 1535 lm 1595 lm Forward Voltage Groups  Group Forward Voltage 5) IF = 1000 mA min. VF Forward Voltage 5) IF = 1000 mA max. VF JC 8.40 V 9.00 V WC 9.00 V 9.60 V AB 9.60 V 10.15 V   5 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Chromaticity Coordinate Groups   550 nm 500 nm 600 nm 700 750 nm 400 380 nm 7M0  7L0 6M0  6L0 5M0 5L0 4M0 4L0   6 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Chromaticity Coordinate Groups  4) Group Cx Cy Group Cx Cy Group Cx Cy 4L0 0.3100 0.3065 5M0 0.3160 0.3261 7L0 0.3281 0.3428 0.3100 0.3185 0.3160 0.3391 0.3281 0.3548 0.3160 0.3306 0.3221 0.3512 0.3317 0.3620 0.3160 0.3186 0.3221 0.3382 0.3342 0.3635 0.3100 0.3140 0.3221 0.3307 0.3342 0.3549 0.3100 0.3270 0.3221 0.3427 0.3281 0.3503 0.3160 0.3391 0.3281 0.3548 0.3281 0.3597 0.3160 0.3261 0.3281 0.3428 0.3342 0.3635 0.3160 0.3186 0.3221 0.3382 0.3342 0.3624 0.3160 0.3306 0.3221 0.3512 0.3221 0.3427 0.3254 0.3578 0.3221 0.3307 0.3281 0.3597 0.3281 0.3503 4M0 5L0   7 Version 1.1 | 2022-01-17 6L0 6M0 7M0 KW3 HNL631.TK   Group Name on Label  Example: 6T-4L0-AB Brightness Color Chromaticity 6T 4L0   8 Version 1.1 | 2022-01-17 Forward Voltage AB KW3 HNL631.TK   Relative Spectral Emission 7) Φrel = f (λ); IF = 1000 mA; TJ = 25 °C Φrel KW3 HNL631.TK 1.0 : Vλ : white 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 Note: Percentage of red: >5% acc. to ECE regulation Percentage of UV: 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 18 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   19 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   20 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Operating Temperature: The Operating Temperatur Top is referenced to the Solderpoint Ts of this device. Proper current derating must be observed to maintain junction temperature below the maximum. 3) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 4) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 5) Forward Voltage: The forward voltage is measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 6) Thermal Resistance: Rth max is based on statistic values (6σ). 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   21 Version 1.1 | 2022-01-17 KW3 HNL631.TK   Revision History Version Date Change 1.0 2021-12-02 Initial Version 1.1 2022-01-17 Product Image Dimensional Drawing Taping   22 Version 1.1 | 2022-01-17 KW3 HNL631.TK     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 23 Version 1.1 | 2022-01-17
KW3 HNL631.TK-7TTC-6L07M0-JCAB 价格&库存
很抱歉,暂时无法提供与“KW3 HNL631.TK-7TTC-6L07M0-JCAB”相匹配的价格&库存,您可以联系我们找货
