KW DELPS2.RA-QISI-FK0PM0-U515-2-S
    AMSOSRAM(艾迈斯半导体)
    SMD2
    发光二极管/LED 白色 SMT
KW DELPS2.RA-QISI-FK0PM0-U515-2-S 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 KW DELPS2.RA specified at 2mA   KW DELPS2.RA specified at 2mA TOPLED ® E1608 The TOPLED E1608 expands OSRAM Opto Semiconductors’ low power portfolio by offering one of the smallest LED Industry standard footprints in a highly reliable and well proved package concept. Its outstanding performance is suitable for a huge variety of applications especially automotive interior where a small package design with excellent reliability is needed. The TOPLED E1608 is available in different colors and brightness levels. Applications ——Cluster, Button Backlighting ——Interior Illumination (e.g. Ambient Map) ——Electronic Equipment Features: ——Package: white SMT package, colored diffused silicone resin ——Chip technology: InGaN on Sapphire  ——Typ. Radiation: 120° (Lambertian emitter) ——Color: Cx = 0.33, Cy = 0.33 acc. to CIE 1931 (● white) ——Corrosion Robustness Class: 1B Preliminary datasheet version ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) 1 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Ordering Information  Type Luminous Intensity 1) IF = 2 mA Iv KW DELPS2.RA-QGSI-FK0PM0-U515 Preliminary datasheet version  2 Version 0.1 | 2018-11-07 71 ... 280 mcd Ordering Code Q65112A6351 KW DELPS2.RA specified at 2mA   Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 110 °C Storage Temperature Tstg min. max. -40 °C 110 °C Junction Temperature Tj max. 125 °C Forward Current TS = 25 °C IF min. max. 1 mA 20 mA Surge Current t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 40 mA Reverse voltage 2) TS = 25 °C VR max. 5V ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD Preliminary datasheet version  3 Version 0.1 | 2018-11-07 Values 2 kV KW DELPS2.RA specified at 2mA   Characteristics IF = 2 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 3) Cx Cy typ. typ. 0.33 0.33 Viewing angle at 50 % IV 2φ typ. 120 ° Forward Voltage 4) IF = 2 mA VF min. typ. max. 2.50 V 2.70 V 3.00 V Reverse current 2) VR = 5 V IR typ. max. 0.01 µA 10 µA Real thermal resistance junction/solderpoint 5) RthJS real typ. max. 120 K / W 210 K / W Preliminary datasheet version  4 Version 0.1 | 2018-11-07 Values KW DELPS2.RA specified at 2mA   Brightness Groups  Group Luminous Intensity 1) IF = 2 mA min. Iv Luminous Intensity 1) IF = 2 mA max. Iv Luminous Flux 6) IF = 2 mA typ. ΦV QG 71 mcd 82 mcd 230 mlm QH 82 mcd 97 mcd 270 mlm QI 97 mcd 112 mcd 310 mlm RG 112 mcd 130 mcd 360 mlm RH 130 mcd 150 mcd 420 mlm RI 150 mcd 180 mcd 500 mlm SG 180 mcd 210 mcd 590 mlm SH 210 mcd 240 mcd 680 mlm SI 240 mcd 280 mcd 780 mlm Forward Voltage Groups  Group Forward Voltage 4) IF = 2 mA min. VF Forward Voltage 4) IF = 2 mA max. VF U5 2.50 V 2.75 V 15 2.75 V 3.00 V Preliminary datasheet version  5 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Chromaticity Coordinate Groups 3) 0,45 Cy 0,90 Cy 0,43 520 0,41 525 515 0,80 530 0,39 540 510 0,70 PM0 0,37 550 505 NM0 0,35 560 MM0 0,60 0,33 570 500 LM0 0,31 0,50 KM0 580 KL0 495 IM0 HM0 0,25 620 630 650 700 HL0 HK0 GL0 GK0 FM0 FL0 0,21 480 FK0 0,19 475 Cx 0,40 0,38 0,36 0,34 0,32 0,30 0,28 0,26 0,24 0,22 0,15 0,90 0,80 0,70 0,60 0,50 0,40 0,30 0,20 0,10 Cx 0,20 0,17 470 465 460 455 450 400 0,00 0,00 IK0 GM0 0,23 485 0,10 JK0 IL0 610 0,20 LK0 KK0 0,27 600 490 NK0 MK0 JL0 0,40 0,30 PK0 JM0 0,29 590 LL0 ML0 NL0 PL0 Color Chromaticity Groups  3) Group Cx Cy Group Cx Cy Group Cx Cy FK0 0.2498 0.2053 GL0 0.2509 0.2264 HM0 0.2520 0.2527 0.2597 0.2204 0.2624 0.2431 0.2646 0.2700 0.2682 0.2146 0.2700 0.2361 0.2733 0.2590 0.2589 0.2000 0.2597 0.2204 0.2624 0.2431 0.2402 0.2108 0.2388 0.2348 0.2797 0.2509 0.2509 0.2264 0.2520 0.2527 0.2898 0.2664 0.2597 0.2204 0.2624 0.2431 0.2950 0.2568 0.2498 0.2053 0.2509 0.2264 0.2861 0.2427 0.2269 0.2185 0.2700 0.2361 0.2733 0.2590 0.2388 0.2348 0.2797 0.2509 0.2848 0.2757 0.2509 0.2264 0.2861 0.2427 0.2898 0.2664 0.2402 0.2108 0.2775 0.2292 0.2797 0.2509 0.2597 0.2204 0.2624 0.2431 0.2646 0.2700 0.2700 0.2361 0.2733 0.2590 0.2780 0.2883 0.2775 0.2292 0.2797 0.2509 0.2848 0.2757 0.2682 0.2146 0.2700 0.2361 0.2733 0.2590 FL0 Preliminary datasheet version FM0 GK0  6 Version 0.1 | 2018-11-07 GM0 HK0 HL0 IK0 IL0 IM0 KW DELPS2.RA specified at 2mA   Group Cx Cy Group Cx Cy Group Cx Cy JK0 0.2898 0.2664 LK0 0.3113 0.2992 NK0 0.3339 0.3336 0.3007 0.2830 0.3219 0.3154 0.3465 0.3530 0.3045 0.2717 0.3231 0.3008 0.3447 0.3347 0.2950 0.2568 0.3138 0.2862 0.3335 0.3172 0.2848 0.2757 0.3090 0.3108 0.3341 0.3472 0.2971 0.2935 0.3209 0.3281 0.3479 0.3673 0.3007 0.2830 0.3219 0.3154 0.3465 0.3530 0.2898 0.2664 0.3113 0.2992 0.3339 0.3336 0.2780 0.2883 0.3060 0.3266 0.3345 0.3654 0.2922 0.3077 0.3196 0.3451 0.3498 0.3863 0.2971 0.2935 0.3209 0.3281 0.3479 0.3673 0.2848 0.2757 0.3090 0.3108 0.3341 0.3472 0.3007 0.2830 0.3219 0.3154 0.3465 0.3530 0.3113 0.2992 0.3339 0.3336 0.3599 0.3735 0.3138 0.2862 0.3335 0.3172 0.3567 0.3535 0.3045 0.2717 0.3231 0.3008 0.3447 0.3347 0.2971 0.2935 0.3209 0.3281 0.3479 0.3673 0.3090 0.3108 0.3341 0.3472 0.3623 0.3882 0.3113 0.2992 0.3339 0.3336 0.3599 0.3735 0.3007 0.2830 0.3219 0.3154 0.3465 0.3530 0.2922 0.3077 0.3196 0.3451 0.3498 0.3863 0.3060 0.3266 0.3345 0.3654 0.3655 0.4079 0.3090 0.3108 0.3341 0.3472 0.3623 0.3882 0.2971 0.2935 0.3209 0.3281 0.3479 0.3673 JL0 JM0 KK0 KL0  Preliminary datasheet version KM0 7 Version 0.1 | 2018-11-07 LL0 LM0 MK0 ML0 MM0 NL0 NM0 PK0 PL0 PM0 KW DELPS2.RA specified at 2mA   Group Name on Label  Example: QG-FK0-15 Brightness Color Chromaticity QG FK0 Preliminary datasheet version  8 Version 0.1 | 2018-11-07 Forward Voltage 15 KW DELPS2.RA specified at 2mA   Relative Spectral Emission 6) Irel = f (λ); IF = 2 mA; TS = 25 °C Irel KW DELPS2.RA 1,0 : Vλ : HK0 : ML0 : PK0 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 6) Irel = f (ϕ); TS = 25 °C KW DELPS2.RA ϕ [°]  -40 -50 -20 -30 -10 0 10 20 30 40 50 60 70 80 90 1,0 : 0° : 90° 0,8 0,6 -60 Preliminary datasheet version -70 -80 -90 -100 9 Version 0.1 | 2018-11-07 0,4 0,2 0,0 Irel KW DELPS2.RA specified at 2mA   Forward current Relative Luminous Intensity 6) IF = f(VF); TS = 25 °C IF [mA] 6), 7) Iv/Iv(2 mA) = f(IF); TS = 25 °C IV KW DELPS2.RA 20 IV(2mA) : HK0 : ML0 : PK0 8 18 16 6 14 12 10 4 8 6 2 4 2 VF [V] Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(IF); TS = 25 °C ∆Cx ∆Cy 0,005 : ∆ Cx - HK0 : ∆ Cy - HK0 : ∆ Cx - ML0 : ∆ Cy - ML0 : ∆ Cx - PK0 : ∆ Cy - PK0  0,000 -0,005 -0,015 18 20 16 12 14 10 6 8 4 -0,020 1 Preliminary datasheet version -0,010 IF [mA] 10 Version 0.1 | 2018-11-07 18 20 14 16 3,2 10 3,1 12 3,0 6 2,9 8 2,8 4 0 2,7 1 1 2,6 IF [mA] KW DELPS2.RA specified at 2mA   Forward Voltage Relative Luminous Intensity 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 2 mA ∆VF [V] Iv/Iv(25 °C) = f(Tj); IF = 2 mA KW DELPS2.RA 0,3 6) Iv KW DELPS2.RA 1,2 Iv(25°C) 0,2 : HK0 : ML0 : PK0 1,1 0,1 1,0 0,0 0,9 -0,1 0,8 -0,2 -0,3 -40 -20 0 20 40 60 80 100 120 Tj [°C] Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(Tj); IF = 2 mA ∆Cx ∆Cy KW DELPS2.RA 0,015 : ∆ Cx - HK0 : ∆ Cy - HK0 : ∆ Cx - ML0 : ∆ Cy - ML0 : ∆ Cx - PK0 : ∆ Cy - PK0  0,010 0,005 0,000 Preliminary datasheet version -0,005 -0,010 -0,015 -40 -20 0 20 40 60 80 100 120 Tj [°C] 11 Version 0.1 | 2018-11-07 0,7 -40 -20 0 20 40 60 80 100 120 Tj [°C] KW DELPS2.RA specified at 2mA   Max. Permissible Forward Current IF = f(T) IF [mA] KW DELPS2.RA 22 20 18 16 14 12 : Ts 10 8 6 4 2 0 0 20 40 60 80 100 Ts [°C] Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle KW DELPS2.RA IF [A] 0,05 TS = 0°C ... 110°C  0,04 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 Preliminary datasheet version 0,03 0,02 10 -6 10-5 10 -4 10 -3 0,01 0,1 1 10 Pulse time [s] 12 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Dimensional Drawing 8) Approximate Weight: 2.0 mg Package marking: Anode Corrosion test: Class: 1B Test condition: 25°C / 75 % RH / 200ppb SO2, 200ppb NO2, 10ppb H2S, 10ppb Cl2 / 21 days (EN 60068-2-60 (Method 4)) Preliminary datasheet version  13 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Recommended Solder Pad 8) All products are packed in a dry pack bag (Moisture Barrier Bag, MBB) according MIL-PRF-81705, after opening the MBB the products should go to reflow soldering process. Unused remaining LEDs should be protected from environment due to silver plated soldering terminal. In order to maintain solderability it is recommended to protect the silver plated solder terminals from corrosive environment before soldering. For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Preliminary datasheet version  14 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Preliminary datasheet version Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 15 Version 0.1 | 2018-11-07 °C 480 s K/s s KW DELPS2.RA specified at 2mA   Taping 8) Preliminary datasheet version  16 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Tape and Reel 9) Reel dimensions [mm] A 180 mm W Nmin 8 + 0.3 / - 0.1 Preliminary datasheet version  17 Version 0.1 | 2018-11-07 W1 60 W2 max 8.4 + 2 14.4 Pieces per PU 2000 KW DELPS2.RA specified at 2mA   Barcode-Product-Label (BPL) Dry Packing Process and Materials 8) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Preliminary datasheet version Barcode label Desiccant AM OSR OHA00539 Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 18 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Transportation Packing and Materials 8) Barcode label N O : (Q )Q TY :2 00 0 (9 D ) D /C :0 (X ) Packing Sealing label Length 200 ± 5 mm 195 ± 5 mm Preliminary datasheet version  19 Version 0.1 | 2018-11-07 M Y DE -1 +Q -1 R 18 P OHA02044 Dimensions of transportation box in mm Width RO UP : M RA OS PR O D 5 14 2 110 0 G 4 01 4 C: D/ (9 D) 20 00 (Q )Q TY : O TC P) (6 T LO (1 T) O D PR D EM Y 18 R -1 : Q + P -1 G R O U P: u L lt S iT Y O T6 P 7 L 6 M 14 4 (G ) E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R ditio 0 C R 07 PA 7 na RT l TE C KV XT AR Muster A o M n O d u p cto to rs R 34 ic N O : O S H 12 G BA TC H (1 T) LO T N O :1 (6 P) 23 em 8 2199 2100 5 14 2 110 0 (X ) O M O PT O M 998 NO : CThISTU SE S 21 2100 BA _ < s ur s ). Ho ururs s de Ho co 72 Ho ur te 48 e Ho 24 6 da 40 be tim e e ˚C or th r pr < ll tim ct ). 23 oo r wi nt tim e at l wi fa r Fl oo tim s at at le ˚C at e. ica l Fl th oo r th va ur nt Fl oo s ui be on if: read w ed l 4 5 Fl la m ide ce eq lo g, oc ve l vi is in en de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo ba Le ve tu re m % ba e al e Le r en re e ed re 10 ois stu ur e tim se fo al op se fo > , M oi r se st ur 3 is is ha se M oi st nk be k, oo . 03 rd g M oi in an in Fl RH g, r-p bla DM ba Ca po If bl th % kinr life is (if . ar ST f p. wi 10 ba to et Jel r th va Ye ar ks s m _ < cat m d, C ed 1 Ye ee ur ire Sh te w, te di at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re qu JE 2. bo ity is M or tim e e 16 re C/ : es id 2b r a) St tim mor is IP ed oo r tim e vic b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l e Le Ba te ur e Le ve Le Da oist stur e ur e M oi st ur M oi st M oi H 12 34 . RH 0% /6 ˚C : L e el selab . , H) nk de co (R bla r S S em R ic AM o n O d u p ct to o H rs NO If 23 G E V E ba ity id m hu e e d tiv re ag NO :1 L la re fra ck 30 Nns IVE RS in pa % k of ai IT TO to 90 ea d ntNS < ns UC or TIO te (p d , g itio ND U g coSE an bjec ˚C sin nd O 5 ˚C su es Ais baRE co IC ± y M oc (G ) M u L lt S iT Y O T6 P 7 L 6 E D Muster Bi Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Barcode label Height 30 ± 5 mm KW DELPS2.RA specified at 2mA   Type Designation System Emission Color O: orange (606 nm) Y: yellow (587 nm) P: pure green (560 nm) T: true green (528 nm) S: super red (633 nm) K: Automotive and Industry Product K Color coordinates according CIE 1931/Emission color: W: white D: O Package Type Top emitting device Leadframe based White reflector package D E Lead / Package Properties TOPlooker: E: 1608 Sidelooker: E: 5515 Ceramic packages: E: 1915  Preliminary datasheet version Encapsulant Type / Lens Properties L: No lens (Lambertian) Chip Technology: P: Standard power class Elevated power class Q: M: Medium performance 20 Version 0.1 | 2018-11-07 Technology Concept S: Silicone encapsulation (casted) Platform: pre-molded L Product version P S 1 . 2 Special Characteristic 1: InGaN saturated colors 2: INGaAlP or AlGaAs saturated colors F: Full conversion (color depending on color description) R: standard cold white Binning Information: 2: mcd A: Automotive interior binning: FKPL P: COD Puregreen 2 KW DELPS2.RA specified at 2mA   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related informations please visit www.osram-os.com/appnotes Preliminary datasheet version  21 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time. Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS webside. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer. Preliminary datasheet version  22 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed. 3) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 4) Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 5) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 9) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm. Preliminary datasheet version  23 Version 0.1 | 2018-11-07 KW DELPS2.RA specified at 2mA   Preliminary datasheet version  Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 24 Version 0.1 | 2018-11-07
KW DELPS2.RA-QISI-FK0PM0-U515-2-S 价格&库存
很抱歉,暂时无法提供与“KW DELPS2.RA-QISI-FK0PM0-U515-2-S”相匹配的价格&库存,您可以联系我们找货
  • 1+2.207831+0.28701
  • 10+1.4996210+0.19495
  • 100+1.05230100+0.13680
  • 500+0.84551500+0.10992
  • 1000+0.776971000+0.10101
  • 2000+0.718542000+0.09341
库存:16560
  • 5000+0.654415000+0.08507
  • 10000+0.6142610000+0.07986
  • 15000+0.5936515000+0.07718
  • 25000+0.5703725000+0.07415
  • 35000+0.5565235000+0.07235
  • 50000+0.5429950000+0.07059
库存:16560
