KW DPLS31.KB-65H5J-G4P7-UV-24A4-120-S
    AMSOSRAM(艾迈斯半导体)
    1606(4014Metric)
    发光二极管/LED 白色 SMT
KW DPLS31.KB-65H5J-G4P7-UV-24A4-120-S 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 KW DPLS31.KB   KW DPLS31.KB SYNIOS ® E4014 This compact LED offers an extremely low-profile and compact design of 4.0 x 1.4 x 0.65 mm, uniform distribution of light and rugged plastic housing. Applications —Displays (Backlighting) Features: —Package: SMD epoxy package, colored silicone resin —Chip technology: InGaN on Sapphire —Typ. Radiation: 120° (Lambertian emitter) —Color: Cx = 0.28, Cy = 0.26 acc. to CIE 1931 (● white) —Optical efficacy: 110 lm/W —Corrosion Robustness Class: 1B —Qualifications: The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification for Automotive Grade Discrete Semiconductors. —ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)   1 Version 1.2 | 2021-10-15 KW DPLS31.KB   Ordering Information  Type Luminous Flux 1) IF = 120 mA ΦV KW DPLS31.KB-65H5J-G4P7-UV-24A4   2 Version 1.2 | 2021-10-15 34.0 ... 50.0 lm Ordering Code Q65112A3770 KW DPLS31.KB   Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 100 °C Storage Temperature Tstg min. max. -40 °C 100 °C Junction Temperature Tj max. 125 °C Forward Current TS = 25 °C IF min. max. 10 mA 180 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD Reverse voltage 2) VR   3 Version 1.2 | 2021-10-15 Values 2 kV Not designed for reverse operation KW DPLS31.KB   Characteristics IF = 120 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 3) Cx Cy typ. typ. Peak Wavelength IF = 120 mA λpeak min. max. Viewing angle at 50% IV 2φ typ. 120 ° Forward Voltage 4) IF = 120 mA VF min. typ. max. 2.80 V 3.10 V 3.40 V Reverse current 2) IR Real thermal resistance junction/solderpoint 5) RthJS real typ. max. 19 K / W 25 K / W Electrical thermal resistance junction/solderpoint 5) with efficiency ηe = 42 % RthJS elec. typ. max. 11 K / W 15 K / W   4 Version 1.2 | 2021-10-15 Values 0.28 0.26 446 nm 454 nm Not designed for reverse operation KW DPLS31.KB   Brightness Groups  Group Luminous Flux 1) IF = 120 mA min. ΦV Luminous Flux 1) IF = 120 mA max. ΦV Luminous Intensity 6) IF = 120 mA typ. Iv 65H 34.0 lm 35.5 lm 11.9 cd 7H 35.5 lm 40.0 lm 12.9 cd 8H 40.0 lm 45.0 lm 14.5 cd 5J 45.0 lm 50.0 lm 16.2 cd Forward Voltage Groups  Group Forward Voltage 4) IF = 120 mA min. VF Forward Voltage 4) IF = 120 mA max. VF 24 2.80 V 3.00 V 64 3.00 V 3.20 V A4 3.20 V 3.40 V Wavelength Groups  Group U   V Peak Wavelength IF = 120 mA min. λpeak 5 Version 1.2 | 2021-10-15 Peak Wavelength IF = 120 mA max. λpeak 446 nm 451 nm 448 nm 454 nm KW DPLS31.KB   Chromaticity Coordinate Groups Cx Cy 550 nm 500 nm 600 nm 700 750 nm 400 380 nm Cy P4  N4 M4 L4 K4 J4 I4 H4 G4 H5 G5 I7 H7 G7  M7 L7 K7 J7 Cx 6 Version 1.2 | 2021-10-15 M6 K6 I6 P6 N6 L6 J6 H6 G6 M5 K5 I5 N5 L5 J5 P5 N7 P7 KW DPLS31.KB   Chromaticity Coordinate Groups  Group Cx Cy Group Cx Cy Group Cx Cy G4 0.2358 0.2118 I4 0.2446 0.2291 K4 0.2541 0.2477 0.2358 0.2118 0.2446 0.2291 0.2541 0.2477 0.2443 0.2104 0.2533 0.2275 0.2631 0.2459 0.2487 0.2188 0.2581 0.2365 0.2683 0.2557 0.2443 0.2104 0.2533 0.2275 0.2631 0.2459 0.2443 0.2104 0.2533 0.2275 0.2631 0.2459 0.2526 0.2090 0.2620 0.2259 0.2720 0.2442 0.2572 0.2173 0.2669 0.2349 0.2773 0.2538 0.2526 0.2090 0.2620 0.2259 0.2720 0.2442 0.2526 0.2090 0.2620 0.2259 0.2720 0.2442 0.2609 0.2076 0.2705 0.2244 0.2807 0.2424 0.2656 0.2159 0.2755 0.2332 0.2862 0.2520 0.2609 0.2076 0.2705 0.2244 0.2807 0.2424 0.2609 0.2076 0.2705 0.2244 0.2807 0.2424 0.2691 0.2063 0.2789 0.2229 0.2894 0.2407 0.2739 0.2144 0.2840 0.2316 0.2949 0.2502 0.2401 0.2203 0.2493 0.2382 0.2591 0.2576 0.2401 0.2203 0.2493 0.2382 0.2591 0.2576 0.2487 0.2188 0.2581 0.2365 0.2683 0.2557 0.2533 0.2275 0.2631 0.2459 0.2737 0.2658 0.2487 0.2188 0.2581 0.2365 0.2683 0.2557 0.2487 0.2188 0.2581 0.2365 0.2683 0.2557 0.2572 0.2173 0.2669 0.2349 0.2773 0.2538 0.2620 0.2259 0.2720 0.2442 0.2828 0.2638 0.2572 0.2173 0.2669 0.2349 0.2773 0.2538 0.2572 0.2173 0.2669 0.2349 0.2773 0.2538 0.2656 0.2159 0.2755 0.2332 0.2862 0.2520 0.2705 0.2244 0.2807 0.2424 0.2918 0.2619 0.2656 0.2159 0.2755 0.2332 0.2862 0.2520 0.2656 0.2159 0.2755 0.2332 0.2862 0.2520 0.2739 0.2144 0.2840 0.2316 0.2949 0.2502 0.2789 0.2229 0.2894 0.2407 0.3007 0.2600 G5 G6 G7 H4 H5 H6  H7  7 Version 1.2 | 2021-10-15 I5 I6 I7 J4 J5 J6 J7 K5 K6 K7 L4 L5 L6 L7 KW DPLS31.KB   Group Cx Cy Group Cx Cy Group Cx Cy M4 0.2644 0.2678 N4 0.2698 0.2785 P4 0.2755 0.2897 0.2644 0.2678 0.2698 0.2785 0.2755 0.2897 0.2737 0.2658 0.2793 0.2764 0.2851 0.2874 0.2793 0.2764 0.2851 0.2874 0.2912 0.2989 0.2737 0.2658 0.2793 0.2764 0.2851 0.2874 0.2737 0.2658 0.2793 0.2764 0.2851 0.2874 0.2828 0.2638 0.2886 0.2743 0.2946 0.2852 0.2886 0.2743 0.2946 0.2852 0.3008 0.2965 0.2828 0.2638 0.2886 0.2743 0.2946 0.2852 0.2828 0.2638 0.2886 0.2743 0.2946 0.2852 0.2918 0.2619 0.2977 0.2722 0.3039 0.2830 0.2977 0.2722 0.3039 0.2830 0.3102 0.2942 0.2918 0.2619 0.2977 0.2722 0.3039 0.2830 0.2918 0.2619 0.2977 0.2722 0.3039 0.2830 0.3007 0.2600 0.3068 0.2702 0.3130 0.2808 0.3068 0.2702 0.3130 0.2808 0.3195 0.2919 M5 M6 M7   8 Version 1.2 | 2021-10-15 N5 N6 N7 P5 P6 P7 KW DPLS31.KB   Group Name on Label  Example: 5J-G4-U-24 Brightness Color Chromaticity Wavelength Groups 5J U G4   9 Version 1.2 | 2021-10-15 Forward Voltage 24 KW DPLS31.KB   Relative Spectral Emission 6) Φrel = f (λ); IF = 120 mA; TS = 25 °C Φ KW DPLS31.KB 1.0 : Vλ : white 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 800 λ/ Radiation Characteristics 6) Irel = f (ϕ); TS = 25 °C KW DPLS31.KB ϕ/  -40° -50° -20° -30° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 : 0° : 90° 0.8 0.6 -60° -70° -80° -90°  -100° 10 Version 1.2 | 2021-10-15 0.4 0.2 0.0 I KW DPLS31.KB   Forward current Relative Luminous Flux 6) IF = f(VF); TS = 25 °C IF / mA 6), 7) Φv/Φv(120 mA) = f(IF); TS = 25 °C KW DPLS31.KB ΦV KW DPLS31.KB 180 ΦV(120mA) 1.4 160 1.2 140 1.0 120 0.8 100 80 0.6 60 0.4 40 0.2 20 VF / V Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(IF); TS = 25 °C ∆Cx ∆Cy KW DPLS31.KB 0.03  0.02 0.01 : ∆ Cx : ∆ Cy 0.00 -0.01 -0.02 10 0 12 0 14 0 16 0 18 0 80 60 40 10 -0.03  IF / mA 11 Version 1.2 | 2021-10-15 10 0 12 0 14 0 16 0 18 0 3.3 80 3.2 60 3.0 40 2.8 10 0.0 10 2.6 IF / mA KW DPLS31.KB   Forward Voltage Relative Luminous Flux 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 120 mA ∆VF / V Φv/Φv(25 °C) = f(Tj); IF = 120 mA KW DPLS31.KB 0.3 Φv KW DPLS31.KB 1.2 Φv(25°C) 0.2 1.0 0.1 0.8 0.0 0.6 -0.1 0.4 -0.2 0.2 -0.3 -40 -20 0 20 40 60 80 100 120 Tj / °C Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(Tj); IF = 120 mA ∆Cx ∆Cy 6) KW DPLS31.KB 0.03 : ∆ Cx : ∆ Cy  0.02 0.01 0.00 -0.01 -0.02 -0.03 -40 -20 0 20 40 60 80 100 120  Tj / °C 12 Version 1.2 | 2021-10-15 0.0 -40 -20 0 20 40 60 80 100 120 Tj / °C KW DPLS31.KB   Max. Permissible Forward Current IF = f(T) IF / mA KW DPLS31.KB 190 180 170 160 150 140 130 120 110 100 : Ts 90 80 70 60 50 40 30 20 10 0 0 20 40 60 80 100 T / °C Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle KW DPLS31.KB TS = 0°C ... 100°C IF / A 0.22  : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0.20 0.18 10-6 10-5 10-4 10-3 0.01 0.1 1 10  / 13 Version 1.2 | 2021-10-15 KW DPLS31.KB   Dimensional Drawing 8) Further Information: Approximate Weight: 10.0 mg Package marking: Cathode Corrosion test: Class: 1B Test condition: 25°C / 75 % RH / 200ppb SO2, 200ppb NO2, 10ppb H2S, 10ppb Cl2 / 21 days (EN 60068-2-60 (Method 4))   14 Version 1.2 | 2021-10-15 KW DPLS31.KB   Electrical Internal Circuit   15 Version 1.2 | 2021-10-15 KW DPLS31.KB   Recommended Solder Pad 8) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning.   16 Version 1.2 | 2021-10-15 KW DPLS31.KB   Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 17 Version 1.2 | 2021-10-15 °C 480 s K/s s KW DPLS31.KB   Taping 8)   18 Version 1.2 | 2021-10-15 KW DPLS31.KB   Tape and Reel 9) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   19 Version 1.2 | 2021-10-15 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 4500 KW DPLS31.KB   Barcode-Product-Label (BPL) Dry Packing Process and Materials 8) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 20 Version 1.2 | 2021-10-15 KW DPLS31.KB   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   21 Version 1.2 | 2021-10-15 KW DPLS31.KB   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   22 Version 1.2 | 2021-10-15 KW DPLS31.KB   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 60 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Reverse Operation: Not designed for reverse operation. Continuous reverse operation can cause migration and damage of the device. 3) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 60 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 4) Forward Voltage: The forward voltage is measured during a current pulse of typically 43 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 5) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 9) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   23 Version 1.2 | 2021-10-15 KW DPLS31.KB   Revision History Version Date Change 1.0 2019-04-24 Initial Version 1.1 2020-09-16 Features Schematic Transportation Box Dimensions of Transportation Box 1.2 2021-10-15 Features Reel Dimensions   24 Version 1.2 | 2021-10-15 KW DPLS31.KB     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 25 Version 1.2 | 2021-10-15
KW DPLS31.KB-65H5J-G4P7-UV-24A4-120-S 价格&库存
很抱歉,暂时无法提供与“KW DPLS31.KB-65H5J-G4P7-UV-24A4-120-S”相匹配的价格&库存,您可以联系我们找货
  • 1+5.83200
  • 200+2.25720
  • 500+2.18160
  • 1000+2.13840
