www.osram-os.com
Produktdatenblatt | Version 1.1
PLT5 522EA_Q
PLT5 522EA_Q
Metal Can ® TO56
Green Laser Diode in TO56 Package
Applications
—Architecture / Garden Lighting (LED & Laser)
—Measurement Levelling
—Area Lights
—Mood Lighting
—Downlights/Spotlights
—Street, Tunnel and Outdoor
—Industry
Features
—Optical output power (continuous wave): 20 mW (TC = 25°C)
—Typical emission wavelength: 520 nm
—Efficient radiation source for cw and pulsed operation
—Single mode semiconductor laser
—High modulation bandwidth
—TO56 package with photo diode
—Cathode is electrically connected to the case
Ordering Information
Type
Preliminary datasheet version
PLT5 522EA_Q
1 Version 0.1 | 2022-01-31
Peak output power
typ.
Popt
20 mW
Ordering Code
Q65113A2666
PLT5 522EA_Q
Maximum Ratings
TC = 25 °C
Parameter
Symbol
Values
Operating temperature
Top
min.
max.
-20 °C
70 °C
Storage temperature
Tstg
min.
max.
-40 °C
85 °C
Junction temperature
Tj
max.
120 °C
Operating current 1)
(Tc = -20 °C)
Iop
max.
100 mA
Forward current 1)
IF
max.
200 mA
Reverse voltage 2)
VR
max.
2V
Soldering temperature
tmax = 10 sec
TS
max.
260 °C
Operation outside these conditions may damage the device. Operation at maximum ratings may influence lifetime.
2 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Characteristics
Popt = 20 mW; Tcase = 25 °C
Parameter
Symbol
Iop
typ.
max.
68 mA
82 mA
Operating voltage 3)
Vop
typ.
max.
5.5 V
6.3 V
Peak wavelength 4)
λpeak
min.
typ.
max.
510 nm
520 nm
530 nm
Spectral bandwidth (FWHM)
∆λ
typ.
2 nm
Beam divergence (FWHM) parallel to pn-junction
Θ‖
min.
typ.
max.
6°
7.5 °
10 °
Beam divergence (FWHM) perpendicular to pn-junction
Θ┴
min.
typ.
max.
19 °
22 °
25 °
Beam pointing accuracy 5)
∆θ∥, ∆θ⊥
min.
max.
-3 °
3°
Slope efficiency
η
min.
max.
0.4 W / A
0.85 W / A
Threshold current
Ith
typ.
max.
30 mA
50 mA
TE polarization
PTE
typ.
100:1
Modulation frequency
f
min.
100 MHz
Im
max.
min.
360 µA
70 µA
RthJC
typ.
Monitor current
VR = 5 V
Thermal resistance junction case real
3 Version 0.1 | 2022-01-31
Values
34 K / W
PLT5 522EA_Q
Wavelength Groups
Group
Peak wavelength 6)
min.
λpeak
Peak wavelength 6)
max.
λpeak
B1
510 nm
515 nm
B2
515 nm
520 nm
B3
520 nm
530 nm
Relative Spectral Emission
Ie,rel = f (λ); IF = 65 mA; Popt = 20 mW
4 Version 0.1 | 2022-01-31
7), 8)
PLT5 522EA_Q
Beam Divergence
7), 8)
Popt = f (Θ)
Optical Output Power
Popt = f (IF)
7), 8)
Opt. Power / Forward Voltage
VF = f (IF)
5 Version 0.1 | 2022-01-31
7), 8)
PLT5 522EA_Q
Threshold Current
Ith = f(TC)
6 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Dimensional Drawing
9)
Further Information:
Approximate Weight:
310.0 mg
ESD advice:
ATTENTION – Observe Precautions For Handling – Electrostatic Sensitive
Device
7 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Electrical Internal Circuit
Pin
Description
PIN1
LD Anode
PIN 2
LD Cathode, PD Anode (case)
PIN 3
PD Cathode
8 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Tray
9)
200 pieces per tray
Barcode-Product-Label (BPL)
9 Version 0.1 | 2022-01-31
(X
PR
OD
NO
(1
T)
LO
T
Width
Length
215 ± 5 mm
265 ± 5 mm
10 Version 0.1 | 2022-01-31
P)
: 12
(6
BA
O
(9
D)
D/
C:
01
44
8
5
14 2
110 0
(Q
)Q
00
M
(G
GR
OU
ul LS
ti Y
TO
T6
P 76
LE
P:
P
-1
+Q
18
-1
R
DE
MY
D Bi Bin1
Bi n2 : Pn3 : Q- 1ML : 1- 20
Te
2a
22 mp
3
24 0 ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Muster
2199
12
2100
TY
H
S S
em R
ic AM
on
du O
ct pto
or
H
NO
s
TC
3G
Schematic Transportation Box
NO
PLT5 522EA_Q
9)
Box
Barcode label
Original packing label
OHA02886
Dimensions of Transportation Box
Height
95 ± 5 mm
PLT5 522EA_Q
Notes
Depending on the mode of operation, these devices emit highly concentrated visible and non visible light
which can be hazardous to the human eye. Products which incorporate these devices have to follow the
safety precautions given in IEC 60825-1.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
11 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Disclaimer
OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may
e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
12 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Glossary
1)
Operating/Forward current: IF is measured with an internal reproducibility of ±7 % (acc. to GUM with a
coverage factor of k = 3).
2)
Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any reverse bias shall be avoided.
3)
Operating/Forward voltage: VF is measured with an internal reproducibility of ±0.05 V (acc. to GUM
with a coverage factor of k = 3).
4)
Wavelength: λpeak is measured with an internal reproducibility of ±0.3 nm (acc. to GUM with a coverage factor of k = 3).
5)
Beam pointing accuracy: The values may contain measurement deviations.
6)
Wavelength: The wavelengths are measured with a tolerance of ±1 nm.
7)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
8)
Testing temperature: TA = 25°C (unless otherwise specified)
9)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
13 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Revision History
Version
Date
Change
0.0
2021-10-20
Characteristics
Maximum Ratings
Derating (Diagrams)
0.1
2022-01-31
Features
Maximum Ratings
Derating (Diagrams)
Glossary
14 Version 0.1 | 2022-01-31
PLT5 522EA_Q
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
15 Version 0.1 | 2022-01-31
很抱歉,暂时无法提供与“PLT5 522EA_Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+83.57315200+10.84355
