SFH 4718A
SFH 4718A
    AMSOSRAM(艾迈斯半导体)
    SMD3
    红外(IR) 发射器 860nm 1.75V 1A 400mW/sr @ 1A 40° 3-SMD,无引线
SFH 4718A 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 SFH 4718A   SFH 4718A OSLON ® Black OSLON Black Series (850 nm) - 40° Applications ——3D Capturing ——Gaming, Amusement, Gambling ——Access Control (IRIS/Vein Scan, Face Recognition) ——Safety and Security, CCTV ——CCTV Surveillance ——VMS Features: ——Package: diffuse silicone ——Corrosion Robustness Class: 3B ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) ——IR lightsource with high efficiency ——Low thermal resistance (Max. 16 K/W) ——Centroid wavelength 850 nm  Ordering Information  Type Radiant intensity  1) Preliminary datasheet version IF = 1 A; tp = 10 ms Ie SFH 4718A 400 ... 1000 mW/sr 1 Version 0.1 | 2018-07-04 Radiant intensity 1) typ. IF = 1 A; tp = 10 ms Ie 730 mW/sr Ordering Code Q65112A1520 SFH 4718A   Maximum Ratings TA = 25 °C Parameter Symbol Operating temperature Top min. max. -40 °C 125 °C Storage temperature Tstg min. max. -40 °C 125 °C Junction temperature Tj max. 145 °C Reverse voltage 2) VR max. 12 V Forward current IF max. 1000 mA Surge current D ≤ 1  IFSM max. 1A Power consumption Ptot max. 2.3 W ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV For the forward current and power consumption please see “maximum permissible forward current” diagram Preliminary datasheet version  2 Version 0.1 | 2018-07-04 Values SFH 4718A   Characteristics IF = 1000 mA; tp = 10 ms; TA = 25 °C Parameter Symbol Peak wavelength λpeak typ. 860 nm Centroid wavelength λcentroid typ. 850 nm Spectral bandwidth at 50% Irel,max ∆λ typ. 34 nm Half angle φ typ. 20 ° Dimensions of active chip area LxW typ. 0.75 x 0.75 mm x mm Rise time (10% / 90%) IF = 1 A; RL = 50 Ω tr typ. 11 ns Fall time (10% / 90%) IF = 1 A; RL = 50 Ω tf typ. 15 ns Forward voltage VF typ. max. 1.75 V 2.3 V Reverse current 2) VR = 5 V IR max. typ. 10 µA 0.01 µA Total radiant flux 3) IF = 1 A; tp = 100 μs  Φe typ. 665 mW Temperature coefficient of brightness TCI typ. -0.3 % / K Temperature coefficient of voltage TCV typ. -1 mV / K TCλ typ. 0.3 nm / K RthJS max. Temperature coefficient of wavelength Thermal resistance junction solder point real  4) Brightness Groups  TA = 25 °C Preliminary datasheet version Group Values  Radiant intensity IF = 1000 mA; tp = 10 ms min. Ie Radiant intensity IF = 1000 mA; tp = 10 ms max. Ie DA 400 mW/sr 630 mW/sr DB 500 mW/sr 800 mW/sr EA 630 mW/sr 1000 mW/sr Only one group in one packing unit (variation lower 1.6:1). 3 Version 0.1 | 2018-07-04 16 K / W SFH 4718A   Relative Spectral Emission 5), 6) Irel = f (λ); IF = 1000 mA; tp = 10 ms OHF04132 100 I rel % 80 60 40 20 0 700 750 800 850 nm 950 λ Radiation Characteristics 5), 6) Irel = f (φ) φ[ ] -20°  -30° -40° -50° Preliminary datasheet version -60° -70° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 -80° 0.2 0.1 -90° 4 Version 0.1 | 2018-07-04 0.0 SFH 4718A   Forward current Relative Total Radiant Flux 5), 6) IF = f (VF); single pulse; tp = 100 µs IF Φe/Φe(1000mA) = f (IF); single pulse; tp = 100 µs OHF05620 100 A 5), 6) OHF05626 100 Φe Φe (1 A) 5 10-1 5 10 -1 5 10-2 5 10-2 1 1.2 1.4 1.6 1.8 V 2 VF Max. Permissible Forward Current IF,max = f (TS); RthJS = 16 K / W  [ ] 1000  800 600 Preliminary datasheet version 400 200 0 0 20 40 60 80 5 Version 0.1 | 2018-07-04 100 120 [ ] 10-3 -2 10 5 10-1 5 A 10 0 IF SFH 4718A   Dimensional Drawing 7) Approximate Weight: 31.0 mg Package marking: Cathode Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter then IEC 60068-2-43) Preliminary datasheet version  6 Version 0.1 | 2018-07-04 SFH 4718A   Recommended Solder Pad 7) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C  tP 217 ˚C 200 tL 150 tS Preliminary datasheet version 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t 7 Version 0.1 | 2018-07-04 SFH 4718A   Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax 60 Ramp-up rate to peak*) TSmax to TP 2 3 100 120 2 3 Unit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Taping °C 7) Preliminary datasheet version  8 Version 0.1 | 2018-07-04 s K/s s SFH 4718A   Tape and Reel 8) W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Reel dimensions [mm] A W Nmin W1 W2 max Pieces per PU 180 mm 12 + 0.3 / - 0.1 60 12.4 + 2 18.4 600 Preliminary datasheet version  9 Version 0.1 | 2018-07-04 SFH 4718A   Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print Barcode label L VE LE see lab e If nk, bla cod bar hu ve y el . H) (R dit mi e ed ag % . RH /60 ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe or TIO d , cte itio an bje ing U g coSEND ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < ll pro tor SE ati _ < ). urs urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt l wi or fac ˚C Flo s tim at or ca at re. Flo tha ale el d or nth nti Flo du uiv if: rea es l 4 5 Flo mo lab ce ide eq low g, l ve vic 5a is or be 24 de tin en pro ve l 6 Le de , e te co g: , un wh Le ve l ke r se da ba ed low ure Le ve mo % ba e ba al d ure Le ist en ref e e 10 for tim se ist ure ale op se for > , Mo se 3 ure is or . , se is ha Mo istist nk be g nk -03 rd Mo in n Flo r-p RH g, bla Mo ba TD po If blathi life s % kin Ca (if ar t. wi J-S 10 ba tor thi, va p. elf Ye ar ks _ < e icat me , C 1 tem ted Ye ee urs Sh ter at ed low uir > 1 W Ho un Af Ind no uir DE 1. dy d e 4 ref 8 y is req JE 2. bo e Mo ore tim req 16 : C/ e es dit2b a) St tim or is IP mior ed vic tim e b) g e or Hu en Flo tim or De 2a kin nc te Flo op a) or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a ve Le 3 g an ve l Le Ba te ure Le ve ure ist Le Da ure ist Mo ist ure Mo Mo ist Mo MO TO OP  M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR Preliminary datasheet version OHA00539 Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 10 Version 0.1 | 2018-07-04 SFH 4718A   Transportation Packing and Materials 7) DE R 18 -1 -1 +Q P OU P: 44 01 C: 99 8 D/ 20 00 (9 D) 210 021 : 34 O H 12 (Q )Q TY : S S em R ic AM o nd O uc p to to H rs NO TC BA 3G 5 14 2 (6 P) NO : 12 T 11 00 LO (1 T) NO : OD M Y DE -1 18 P -1 + Q R G RO UP : (G ) 44 01 D/ C: (9 D) 0 AM 00 TY :2 )Q O SR 34 NO : (X ) PR O D 5 14 2 110 0 (Q A R ic NO : O S em S (1 T) LO T NO (6 P) : 12 3G BA TC H H 12 o M n O d u p ct to o rs M Muster u L lt S iT Y O T6 P 76 L E Bi D Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: (X ) PR < 8 2199 2100 GR L el at (G ) M u L lt S iT Y O T67 P L 6 Muster E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or d Ho ururs s , de cteg itio Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da 40 be oc ry tim e e ˚C th r pr ll tim cto ). 23 oo r wi nt tim e l wi fa r ˚C Fl oo tim s at at ale e. at ica Fl th oo r th ur el nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low oc ve l vic is ingen de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou% se da ed ba flo ba Le ve tu re m ba e al d Le r en re re e re 10 ois tu tim se fo tu re ale op se fo > , M ois r se 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba Ca po If blath % kin life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re ty is qu JE 2. bo M or tim e e 16 re C/ : es idi 2b r a) St tim mor is IP e ed r oo vic tim b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op re 3. b) Fl oo da ba e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l Le re Ba te Le ve tu re Le Da ois tu re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE OI M TO OP M Y Barcode label E Bi D n1 Bi Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label Packing Sealing label Dimensions of transportation box in mm Width Length Height 195 ± 5 mm 195 ± 5 mm 30 ± 5 mm Preliminary datasheet version  11 Version 0.1 | 2018-07-04 OHA02044 SFH 4718A   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the LED specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this LED contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize LED exposure to aggressive substances during storage, production, and use. LEDs that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related informations please visit www.osram-os.com/appnotes Preliminary datasheet version  12 Version 0.1 | 2018-07-04 SFH 4718A   Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time. Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the OSRAM OS Webside. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer. Preliminary datasheet version  13 Version 0.1 | 2018-07-04 SFH 4718A   Glossary 1) Radiant intensity: Measured at a solid angle of Ω = 0.01 sr 2) Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed. 3) Total radiant flux: Measured with integrating sphere. 4) Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g. metal block) 5) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Testing temperature: TA = 25°C 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm. Preliminary datasheet version  14 Version 0.1 | 2018-07-04 SFH 4718A   Preliminary datasheet version  Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 15 Version 0.1 | 2018-07-04
SFH 4718A 价格&库存
很抱歉,暂时无法提供与“SFH 4718A”相匹配的价格&库存,您可以联系我们找货
SFH 4718A
    • 1+6.91200
    • 10+6.76080
    • 30+6.65280
    • 100+6.55560
    库存:376
    SFH 4718A
    • 1+16.670711+2.16714
    • 10+11.9244110+1.55014
    • 100+9.05391100+1.17698
    库存:4800
    SFH 4718A
    • 600+7.67087600+0.99719
    • 1200+7.274931200+0.94572
    • 1800+7.071951800+0.91933
    • 3000+6.842813000+0.88955
    • 4200+6.706574200+0.87184
    • 6000+6.573696000+0.85456
    库存:4800
    SFH 4718A
      • 5+13.88165
      • 150+13.66712
      • 300+13.36304
      库存:55
