SPL S1L90A_3 A01
SPL S1L90A_3 A01
    AMSOSRAM(艾迈斯半导体)
    SIP4
    激光二极管 908nm 240mW 11V 40A 4-SMD,无引线
SPL S1L90A_3 A01 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 SPL S1L90A_3 A01   SPL S1L90A_3 A01 SMT Laser 1 Channel SMT Laser in QFN package Applications ——3D Sensing ——LIDAR, Pre-Crash, ACC ——CCTV Surveillance ——Measurement Levelling ——Industrial Automation (Machine Controls, Light Barriers, Vision Controls) Features: ——Qualifications: The product qualification test plan is based on the guidelines of AEC-Q102, failure mechanism based Stress Test Qualification for Discrete Optoelectronic Semiconductors in Automotive applications. ——Laser wavelength 905 nm ——1 channel pulsed laser module ——Suited for short laser pulses from 1 to 100 ns ——SMT device  Ordering Information  Type Preliminary datasheet version SPL S1L90A_3 A01 1 Version 0.0 | 2019-09-27 Peak output power  typ. Popt 120 W Ordering Code Q65112A6166 SPL S1L90A_3 A01   Maximum Ratings TS = 25 °C Parameter Symbol Operating temperature Top min. max. -40 °C 105 °C Storage temperature Tstg min. max. -40 °C 125 °C Junction temperature Tj max. 125 °C Output power Popt max. 0.24 W Forward current dc = 0.2 %  IF max. 40 A Pulse width (FWHM) tP max. 100 ns Duty cycle dc max. 0.2 % Reverse voltage 1) VR max. 45 V Preliminary datasheet version  2 Version 0.0 | 2019-09-27 Values SPL S1L90A_3 A01   Characteristics IF = 40 A; tp = 100 ns; D = 0.01 %; TS = 25 °C Parameter Symbol Number of channels N typ. 1 Operating voltage Vop typ. 11 V Centroid wavelength λcentroid min. typ. max. 895 nm 905 nm 915 nm Spectral bandwidth (FWHM) ∆λ min. typ. max. 3 nm 7 nm 12 nm Peak output power Popt min. typ. max. 105 W 125 W 145 W Beam divergence (FWHM) parallel to pn-junction Θ‖ min. typ. max. 3° 10 ° 13 ° Beam divergence (FWHM) perpendicular to pn-junction Θ┴ min. typ. max. 20 ° 25 ° 30 ° Beam divergence (1/e²) parallel to pn-junction Θ‖ min. typ. max. 10 ° 13 ° 16 ° Beam divergence (1/e²) perpendicular to pn-junction Θ┴ min. typ. max. 35 ° 40 ° 50 ° Ith typ. 0.6 A Laser aperture (FWHM) parallel to pn-junction W|| typ. 220 µm Laser aperture (FWHM) perpendicular to pn-junction W┴ typ. 10 µm Thermal resistance junction solder point real 2) RthJS real typ. max.  Preliminary datasheet version Threshold current 3 Version 0.0 | 2019-09-27 Values 31 K / W 36 K / W SPL S1L90A_3 A01   Relative Spectral Emission 3), 4) Irel = f (ʎ); IF = 40A; Popt = 125W; tp = 100ns; D = 0.01% OHF00565 1.00 Ι rel 0.75 0.50 0.25 0 880 890 900 910 nm λ Far-Field Distribution Perpendicular to pn-Junction 930 3), 4) Irel = f (Θ⊥); Popt = 125W; tp = 100ns; D = 0.01% 1.00  OHL00756 Irel 0.75 Preliminary datasheet version 0.50 0.25 0 -40 -30 -20 -10 0 4 Version 0.0 | 2019-09-27 10 20 Deg 40 θ SPL S1L90A_3 A01   Far-Field Distribution Parallel to pn-Junction 3), 4) Irel = f (ΘII); Popt = 125W; tp = 100ns; D = 0.01% OHF03755 1.00 Irel 0.75 0.50 0.25 0 -30 -20 -10 0 10 Near-Field Distribution Parallel to pn-Junction Irel = f (ΘII); Popt = 125W; tp = 100ns; D = 0.01% Preliminary datasheet version  5 Version 0.0 | 2019-09-27 Deg 30 θ 3), 4) SPL S1L90A_3 A01   Near-Field Distribution Perpendicular to pn-Junction Irel = f (Θ⊥); Popt = 125W; tp = 100ns; D = 0.01% Optical Output Power Popt = f (IF) Preliminary datasheet version  6 Version 0.0 | 2019-09-27 3), 4) 3), 4) SPL S1L90A_3 A01   Centroid Wavelength 3) Centroid Wavelength 3) ʎcentroid = f (TJ); IF = 40A; tp = 100ns; D = 0.01% ʎcentroid = f (TJ); IF = 40A; tp = 100ns; D = 0.01% Centroid Wavelength Centroid Wavelength 3) λcentroid = f(TS); IF = 40A; tp = 100ns; D = 0.01% Preliminary datasheet version  7 Version 0.0 | 2019-09-27 3) λcentroid = f(TS); IF = 40A; tp = 100ns; D = 0.01% SPL S1L90A_3 A01   Peak Output Power Peak Output Power Popt = f (TJ); IF = 40A; tp = 100ns; D = 0.01% Popt = f(TS); IF = 40A; tp = 100ns; D = 0.01% Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f (tp); D = parameter; Popt, typ; Rthjs, typ; TS = 85°C (typ)  IF = f (tp); D = parameter; Popt, min; Rthjs, max; TS = 85°C  Preliminary datasheet version  8 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f (tp); D = parameter; Popt, typ; Rthjs, typ; TS = 105°C  IF = f (tp); D = parameter; Popt, min; Rthjs, max; TS = 105°C  Preliminary datasheet version  9 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Dimensional Drawing 5) Further Information: 8.0 mg Approximate Weight: Preliminary datasheet version  10 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Recommended Solder Pad Preliminary datasheet version  11 Version 0.0 | 2019-09-27 5) SPL S1L90A_3 A01   Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Preliminary datasheet version Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 12 Version 0.0 | 2019-09-27 °C 480 s K/s s SPL S1L90A_3 A01   Taping 5) Preliminary datasheet version  13 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Tape and Reel 6) W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm Preliminary datasheet version  14 Version 0.0 | 2019-09-27 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 500 SPL S1L90A_3 A01   Barcode-Product-Label (BPL) Dry Packing Process and Materials 5) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Preliminary datasheet version Barcode label Desiccant AM OSR OHA00539 Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 15 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Schematic Transportation Box 5) Barcode label N O : (Q )Q TY :2 00 0 (9 D ) D /C :0 (X ) Packing Sealing label Length 195 ± 5 mm 195 ± 5 mm Preliminary datasheet version  16 Version 0.0 | 2019-09-27 M Y DE -1 +Q -1 R 18 P OHA02044 Dimensions of Transportation Box Width RO UP : M RA OS PR O D 5 14 2 110 0 G 4 01 4 C: D/ (9 D) 20 00 (Q )Q TY : O TC P) (6 T LO (1 T) O D PR D EM Y 18 R -1 : Q + P -1 G R O U P: u L lt S iT Y O T6 P 7 L 6 M 14 4 (G ) E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R ditio 0 C R 07 PA 7 na RT l TE C KV XT AR Muster A o M n O d u p cto to rs R 34 ic N O : O S H 12 G BA TC H (1 T) LO T N O :1 (6 P) 23 em 8 2199 2100 5 14 2 110 0 (X ) O M O PT O M 998 NO : CThISTU SE S 21 2100 BA _ < s ur s ). Ho ururs s de Ho co 72 Ho ur te 48 e Ho 24 6 da 40 be tim e e ˚C or th r pr < ll tim ct ). 23 oo r wi nt tim e at l wi fa r Fl oo tim s at at le ˚C at e. ica l Fl th oo r th va ur nt Fl oo s ui be on if: read w ed l 4 5 Fl la m ide ce eq lo g, oc ve l vi is in en de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo ba Le ve tu re m % ba e al e Le r en re e ed re 10 ois stu ur e tim se fo al op se fo > , M oi r se st ur 3 is is ha se M oi st nk be k, oo . 03 rd g M oi in an in Fl RH g, r-p bla DM ba Ca po If bl th % kinr life is (if . ar ST f p. wi 10 ba to et Jel r th va Ye ar ks s m _ < cat m d, C ed 1 Ye ee ur ire Sh te w, te di at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re qu JE 2. bo ity is M or tim e e 16 re C/ : es id 2b r a) St tim mor is IP ed oo r tim e vic b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l e Le Ba te ur e Le ve Le Da oist stur e ur e M oi st ur M oi st M oi H 12 34 . RH 0% /6 ˚C : L e el selab . , H) nk de co (R bla r S S em R ic AM o n O d u p ct to o H rs NO If 23 G E V E ba ity id m hu e e d tiv re ag NO :1 L la re fra ck 30 Nns IVE RS in pa % k of ai IT TO to 90 ea d ntNS < ns UC or TIO te (p d , g itio ND U g coSE an bjec ˚C sin nd O 5 ˚C su es Ais baRE co IC ± y M oc (G ) M u L lt S iT Y O T6 P 7 L 6 E D Muster Bi Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Barcode label Height 30 ± 5 mm SPL S1L90A_3 A01   Notes Depending on the mode of operation, these devices emit highly concentrated visible and non visible light which can be hazardous to the human eye. Products which incorporate these devices have to follow the safety precautions given in IEC 60825-1. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. Tape and Reel: Packing unit can vary 2 % from the stated value. For further application related information please visit www.osram-os.com/appnotes Preliminary datasheet version  17 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer. Preliminary datasheet version  18 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Glossary 1) Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed. 2) Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g. metal block) 3) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 4) Testing temperature: TA = 25°C (unless otherwise specified) 5) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 6) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm. Preliminary datasheet version  19 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Revision History Version Date Change 0.0 2019-07-19 Initial Version 0.0 2019-09-27 Initial Version Preliminary datasheet version  20 Version 0.0 | 2019-09-27 SPL S1L90A_3 A01   Preliminary datasheet version  Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 21 Version 0.0 | 2019-09-27
SPL S1L90A_3 A01 价格&库存
很抱歉,暂时无法提供与“SPL S1L90A_3 A01”相匹配的价格&库存,您可以联系我们找货
SPL S1L90A_3 A01
库存:3
SPL S1L90A_3 A01
  • 500+149.95575500+19.45664
库存:1109
SPL S1L90A_3 A01
库存:2
SPL S1L90A_3 A01
    • 1+210.80520
    • 10+205.84800
    SPL S1L90A_3 A01
    • 1+234.985811+30.48922
    • 10+188.5064610+24.45856
    • 100+165.41286100+21.46218
    库存:1109
