SU CZHEF1.VC-U1U2-L0-V2-250-R18 数据手册
www.osram-os.com
SU CZHEF1.VC
DATASHEET
SU CZHEF1.VC
Datasheet
Published by ams-OSRAM AG
Tobelbader Strasse 30, 8141 Premstaetten, Austria
Phone +43 3136 500-0
ams-osram.com
© All
reserved
| Version
1.2 | 2022-08-18
1 rights
SU CZHEF1.VC
DATASHEET
OSLON® UV 6060
SU CZHEF1.VC
This compact UV-C LED is part of the OSLON UV Series. It
offers high efficiency in high power class. It allows a flexible
design for any application which requires UV-C radiation.
Applications
- Agriculture & Horticulture
- UV-C Treatment
Features
- Package: Ceramic package with lens
- Chip technology: AlGaN based flip chip
- Typ. Radiation: 150°
- Color: λpeak = 265 nm (● ultraviolet (UV-C))
- ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)
- Radiant Flux: typ. 100 mW
- Radiant Efficiency: typ. 5.7 %
2 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Ordering Information
Type
Total radiant flux 1)
IF = 250 mA
ΦE
90.0 ... 130.0 mW
Ordering Code
Q65113A4719
3 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
10 °C
60 °C
Storage Temperature
Tstg
min.
max.
-30 °C
75 °C
Junction Temperature
Tj
max.
75 °C
Forward current
TS = 25 °C
IF
min.
max.
100 mA
350 mA
Surge Current
TS = 25 °C
IFS
max.
500 mA
ESD withstand voltage
VESD
4 | Version 1.2 | 2022-08-18
Values
2 kV
SU CZHEF1.VC
DATASHEET
Characteristics
IF = 250 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength 2)
λpeak
min.
typ.
max.
Viewing angle at 50% IV
2φ
typ.
150 °
Forward Voltage
VF
min.
typ.
max.
6.50 V
7.00 V
7.50 V
Real thermal resistance junction/solderpoint 4)
RthJS real
typ.
4.4 K / W
Electrical thermal resistance junction/solderpoint
with efficiency ηe = 5.7 %
RthJS elec.
typ.
4.1 K / W
3)
Note :
typical optical output at 250mA = 100 mW
typical optical output at 350mA = 142 mW
5 | Version 1.2 | 2022-08-18
Values
260 nm
265 nm
270 nm
SU CZHEF1.VC
DATASHEET
Brightness Groups
Group
IF = 250 mA
min.
ΦE
IF = 250 mA
max.
ΦE
U1
90.0 mW
110.0 mW
U2
110.0 mW
130.0 mW
Wavelength Groups
Group
L0
Peak Wavelength 2)
min.
λpeak
260 nm
Peak Wavelength 2)
max.
λpeak
270 nm
Forward Voltage Groups
Group
Forward Voltage 3)
IF = 250 mA
min.
VF
Forward Voltage 3)
IF = 250 mA
max.
VF
6.50 V
7.50 V
V2
6 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Group Name on Label
Example: U1-L0-V2
Brightness
Wavelength
Forward Voltage
U1
L0
V2
7 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Relative Spectral Emission
5)
Irel = f (λ); IF = 250 mA; TS = 25 °C
Irel
SU CZHEF1.VC
1,0
: ultra violet
0,8
0,6
0,4
0,2
0,0
200 210 220 230 240 250 260 270 280 290 300 310 320 330 340 350
λ / nm
Radiation Characteristics
5)
Irel = f (ϕ); TS = 25 °C
SU CZHEF1.VC
ϕ/°
-40°
-50°
-20°
-10°
0° 10° 20° 30° 40° 50° 60° 70° 80° 90°
1,0
-30°
0,8
0,6
-60°
-70°
0,4
-80°
0,2
-90°
0,0
-100°
8 | Version 1.2 | 2022-08-18
Irel
SU CZHEF1.VC
DATASHEET
Forward current
Relative Radiant Power
5)
IF = f(VF); TS = 25 °C
IF / mA
5),
6)
ΦE/ΦE(250 mA) = f(IF); TS = 25 °C
SU CZHEF1.VC
Φe
SU CZHEF1.VC
350
Φe(250mA) 1,4
300
1,2
250
1,0
0,8
200
0,6
150
Peak Wavelength
7,6 7,8
VF / V
5)
λpeak = f(Tj); IF = 250 mA
SU CZHEF1.VC
∆λ peak / nm
4
2
35
IF / mA
9 | Version 1.2 | 2022-08-18
35
30
25
15
6,6
10
IF / mA
SU CZHEF1.VC
DATASHEET
Forward Voltage
5)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 250 mA
SU CZHEF1.VC
ΦE/ΦE(25 °C) = f(Tj); IF = 250 mA
Φe
∆VF / V
5)
SU CZHEF1.VC
1,2
Φe (25°C)
0,4
1,0
0,2
0,8
0,6
0,0
0,4
-0,2
0,2
-0,4
10
Peak Wavelength
30
40
50
60
Tj / °C
5)
∆λ peak / nm
SU CZHEF1.VC
6
4
2
-4
10
10 | Version 1.2 | 2022-08-18
40
50
60
Tj / °C
0,0
10
40
50
60
Tj / °C
SU CZHEF1.VC
DATASHEET
Max. Permissible Forward Current
IF = f(T)
SU CZHEF1.VC
IF / mA
350
300
250
200
150
100
50
40
11 | Version 1.2 | 2022-08-18
50
60
Ts / °C
SU CZHEF1.VC
DATASHEET
Dimensional Drawing
7)
Further Information:
Approximate Weight:
75.0 mg
Package marking:
Cathode
12 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Electrical Internal Circuit
13 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Recommended Solder Pad
7)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Further information can be found in our Application Note: “Handling and Processing Details for Ceramic LEDs”. Package not suitable for any
kind of wet cleaning or ultrasonic cleaning.
14 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Reflow Soldering Profile
Symbol
Profile Feature
Low Melting (Sn42Bi57Ag)
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 130 °C
Time tS
TSmin to TSmax (90 °C to 130 °C)
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
tS
30
TL
2
3
100
120
2
3
140
Unit
°C/s
s
°C/s
°C
Time above liquidus temperature
tL
30
60
100
s
Peak temperature
TP
160
165
175
°C
3
6
Time within 5 °C of the specified peak
temperature TP - 5 K
Ramp-down rate*
TP to 100 °C
tP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
One time reflow soldering only.
15 | Version 1.2 | 2022-08-18
s
°C/s
SU CZHEF1.VC
DATASHEET
Taping
7)
16 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Tape and Reel
8)
Reel Dimensions
A
180 mm
W
Nmin
16 + 0.3 / - 0.1 mm
17 | Version 1.2 | 2022-08-18
60/100 mm
W1
W2 max
16.4 + 2 mm
22.4 mm
Pieces per PU
500
SU CZHEF1.VC
DATASHEET
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
7)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
18 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Cautions:
Refer to JEDEC Moisture Sensitivity Level 5 in JEDEC-STD-033 for storage and packaging
requirement.
LEDs should be stored at or below 30°C and at an RH of 60% or lower. This LED has a floor life
of 48 hours, once opened from its original packaging
If only a partial reel is used, the reel should be packaged, with silica-gel desiccants, and sealed
within an hour of opening the bag.
Baking of LEDs is required per JEDEC J-STD-033 prior to soldering if LEDs are left open,
exceeding floor life mentioned above.
If LED packages exceed the storage limiting time since opened, recommend baking the LED
according to JEDEC J-STD-033 prior to soldering.
Packing materials, including Tapes, Reels, Trays, and Tubes, can only withstand temperatures
up to 50°C. Exceeding this temperature limit can cause them to deform.
19 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into high risk group – RG 3. WARNING - UV emitted from this product. Avoid eye and skin
contact to unshielded product.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
20 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on our website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
Our components are not developed, constructed or tested for the application as safety relevant component
or for the application in medical devices.
Our products are not qualified at module and system level for such application.
An entire (100%) testing shall be performed after assembly of our product to the final product. Our products
are not qualified at module and system level for such application. Customer is fully responsible and accountable for detection capability in case of sudden changes in electro-optical characteristics at component level.
In case buyer – or customer supplied by buyer – considers using our components in product safety devices/
applications or medical devices/applications, buyer and/or customer has to inform our local sales partner
immediately and we and buyer and/or customer will analyze and coordinate the customer-specific request
between us and buyer and/or customer.
Please carefully read the below instructions.
WARNING: Each user bears full responsibility for making their own determination as to the suitability of our
products, recommendations or advice for its own end use. Each user must identify and perform all tests and
analyses necessary to ensure that its finished application incorporating our products will be safe and suitable for use under end-use conditions. We make no warranty or guarantee, express or implied, as to results
obtained in end-use, nor of any design incorporating its products, recommendations or advice.
WARNING: High intensity ultraviolet-C (UV-C) radiation is emitted from this product, which is harmful to skin
and eyes. Take appropriate protective measures to avoid any exposure to direct or reflected UV-C radiation.
WARNING: During operating lifetime of our UV-C product different aging mechanisms can cause failures.
This may lead to a significant deviation of the function in the final product and application. Please contact us
in advance for further information.
21 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Glossary
1)
Brightness: Brightness groups are tested at a current pulse duration of 10 ms and a tolerance of
±10 %.
2)
Peak Wavelength: Wavelengths are tested at a current pulse duration of 10 ms and a tolerance of
±3 nm.
3)
Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of
±3 %.
4)
Thermal Resistance: Rth max is based on statistic values (6σ).
5)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
6)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
7)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
8)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
22 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
Revision History
Version
Date
Change
1.0
2022-05-10
Initial Version
1.1
2022-05-23
Characteristics
Taping
1.2
2022-08-18
Applications
23 | Version 1.2 | 2022-08-18
SU CZHEF1.VC
DATASHEET
ams-osram.com
© All rights reserved
24 | Version 1.2 | 2022-08-18
