0151-09SD
0151-09SD
    GREENLEECOMMUNICATIONS(格林利)
    PLIERS FLAT NOSE 9.38"
0151-09SD 数据手册
PLIERS,SIDE CUT 9" DIP STRPER High Leverage Side-cutting Pliers W/Stripping Hole 9 IN dipped grip Cat No: 0151-09SD UPC No: 783310892618 Description • • Stripping hole allows for easy and convenient wire stripping of #12 AWG wire (0151-09SM& 015109SD only) The wire looping hole perfectly forms wire for threaded connections (0151-09SM & 0151-09SD only Specifications • • • • • • • • Grip Length : 9.000 IN Grip Type : Dipped Handle Type : Double Layered Vinyl Material : Chrome Vanadium Steel Overall Length : 9-3/8 IN (23.800 CM) Standard : ASME/ANSI Type : High Leverage Weight : 1.130 LB (0.510 KG)
0151-09SD 价格&库存
很抱歉,暂时无法提供与“0151-09SD”相匹配的价格&库存,您可以联系我们找货
