0153-11C
0153-11C
    GREENLEECOMMUNICATIONS(格林利)
    SCREWDRIVER SLOTTED 1/4" 8.34"
0153-11C 数据手册
SCREWDRIVER,FLAT-KEY 1/4X4" Heavy Duty Keystone Tip - Square Shank 1/4 x 4 Flat Blade Screwdriver Cat No: 0153-11C UPC No: 783310546443 Description • • • • • • • • • Square shank allows use of wrench or pliers for added torque Handle marked for easy identification of screwdriver size, type and length Rugged keystone tip for additional strength Precision-machined tips for accurate fastener contact Strong, durable black phosphate tips prevent chipping ofplating Soft, cushioned grip for extra comfort and torque Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • • • • Finish : Black Phosphate Plated Tip Handle Type : Soft, Cushioned Grip Overall Length : 8-11/32 IN (21.200 CM) Shank Length : 4.000 IN Shank Shape : Square Standard : ASME/ANSI Tip Size : 1/4 IN Tip Type : Keystone Type : Heavy Duty, Flat Blade Weight : 0.250 LB (0.110 KG)
0153-11C 价格&库存
很抱歉,暂时无法提供与“0153-11C”相匹配的价格&库存,您可以联系我们找货
