0154-12D
0154-12D
    GREENLEECOMMUNICATIONS(格林利)
    可调式 扳手 12.36"(314.0mm) 长
0154-12D 数据手册
WRENCH,ADJUSTABLE 12" DIPPED Adjustable Wrench Dipped Handle 12 Cat No: 0154-12D UPC No: 783310892939 Description • • • • • • • • • Heavy-duty construction to handle any size job Double-dipped vinyl handlefor user comfort and slip resistance Precision-machined to tight tolerances for professional feel and smooth operation Wide capacity jaw design provides extra versatility Measuring scale on head for easy sizing Corrosion - resistant finish Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • Construction : Heavy Duty Finish : Corrosion Resistant Handle Type : Double Dipped Vinyl Overall Length : 12-3/8 IN (31.400 CM) Size : 12.000 IN Standard : ASME/ANSI Weight : 1.900 LB (0.860 KG)
0154-12D 价格&库存
很抱歉,暂时无法提供与“0154-12D”相匹配的价格&库存,您可以联系我们找货
