0159-23
0159-23
    GREENLEECOMMUNICATIONS(格林利)
    JOURNEYMANS KIT 21PC-METRIC
0159-23 数据手册
JOURNEYMANS KIT 21PC-METRIC Journeymans Tool Kit, Metric 21pc Cat No: 0159-23 UPC No: 783310892380 Description • • Perfect kit for the journeyman electrician Kit Includes: High Leverage Side-cutting pliers 9 IN molded grip, High Leverage Diagonal Cutting Pliers 8 IN molded grip, High Leverage Long Nose Pliers/Side Cutting 8 IN molded grip, Pump Pliers 10 IN molded grip,Dual NM Cable Ripper, Heavy Duty Keystone Tip, Square Shank1/4 IN x 4 IN Flat Blade Screwdriver,Heavy Duty Cabinet Tip, Round Shank 3/16 IN x 6 IN Flat Blade Screwdriver, Heavy Duty Phillips Tip #1 - 3/16 IN x 3 IN Screwdriver, Heavy DutyPhillips Tip#2 1/4 IN x 4 IN Screwdriver, 7.5m/25' Tape measure, 18 oz. Electrician's Hammer, 20 Pocket Tool Caddy, Voltage tester (for kits only),Pro Plus Wire Stripper 10-18 AWG, Stripping/Crimping Combination Tool, Cable Cutter,Torpedo Level, 4 pc Squaredrive (Robertson) Set, Square Tip Driver #0X4 IN,Square Tip Driver #1X4 IN, Square Tip Driver #2X4 IN, Square Tip Driver #3X4 IN Specifications • • Application : For The Journeyman Electrician Consists Of : ƕ 8.000 IN Molded Grip High Leverage Diagonal Cutting Pliers ƕ 8.000 In Molded Grip Side Cutting/High Leverage Long Nose Pliers ƕ Pump Pliers 10.000 IN Molded Grip ƕ Dual NM Cable Ripper ƕ High Leverage Side-CuttingPliers 9.000 IN Molded Grip ƕ 20 Pocket Tool Caddy ƕ Voltage Tester (For Kits Only) ƕ Pro Plus Wire Stripper 10 - 18 AWG ƕ Stripping/Crimping Combination Tool ƕ Number Of Pieces : 21 ƕ Type : Journeyman's, Metric ƕ Weight : 13.700 LB (6.210 KG)
0159-23 价格&库存
很抱歉,暂时无法提供与“0159-23”相匹配的价格&库存,您可以联系我们找货
