0159-24
0159-24
    GREENLEECOMMUNICATIONS(格林利)
    ELECTRICIANS KIT 16PC-METRIC
0159-24 数据手册
ELECTRICIANS KIT 16PC-METRIC Electricians Tool Kit - Metric, 16 pc Cat No: 0159-24 UPC No: 783310892397 Description • • Perfect kit for the professional or apprentice electrician Kit Includes: High Leverage Side-cutting pliers 9 IN molded grip, High Leverage Diagonal Cutting Pliers 8 IN molded grip, High Leverage Long Nose Pliers/Side Cutting 8 IN molded grip, Pump Pliers 10 IN molded grip, Heavy Duty Keystone Tip, Square Shank 1/4 IN x 4 INFlat Blade Screwdriver, HeavyDuty Cabinet Tip, Round Shank3/16 IN x 6 IN Flat Blade Screwdriver, Heavy Duty Phillips Tip #1 - 3/16 IN x 3 IN Screwdriver, Heavy Duty Phillips Tip#2 -1/4 IN x 4 IN Screwdriver, 7.5m/25' Tape measure, HeavyDuty 8 Pocket Leather Pouch, Heavy Duty Leather Tool Belt, Pro Plus Wire Stripper 10-18 AWG, 4 pc Squaredrive (Robertson) Set, Square Tip Driver #0X4IN, Square Tip Driver #1X4 IN, Square Tip Driver #2X4 IN, Square Tip Driver #3X4 Specifications • • • • • Application : For The Professional Or Apprentice Electrician Consists Of : ƕ 8.000 IN Molded Grip High Leverage Diagonal Cutting Pliers ƕ 8.000 In Molded Grip Side Cutting/High Leverage Long Nose Pliers ƕ Pump Pliers 10.000 IN Molded Grip ƕ Heavy Duty Keystone Tip ƕ High Leverage Side-CuttingPliers 9.000 IN Molded Grip ƕ Pro Plus Wire Stripper 10 - 18 AWG ƕ 4 PC Squaredrive (Robertson) Set ƕ Square Tip Driver #0 X 4.000 IN ƕ Square Tip Driver #1 X 4.000 IN10~ Square Tip Driver #2 X 4.000 IN11~ Square Tip Driver #3 X 4.000 IN12~ Square Shank 1/4 IN X 4.000 IN Flat Blade Screwdriver13~ Heavy Duty Cabinet Tip14~ Round Shank 3/16 IN X 6.000 IN Flat Blade Screwdriver15~ Heavy Duty Phillips Tip #1 - 3/16 IN X 3.000 IN Screwdriver16~ Heavy Duty Phillips Tip #2 - 1/4 IN X 4.000 IN Screwdriver17~ 7.500 MR/25.000 FT Tape measure18~ Heavy Duty 8 Pocket Leather Pouch19~ Heavy Duty Leather Tool Belt Number Of Pieces : 16 Type : Electrician's, Metric Weight : 16.500 LB (7.500 KG)
0159-24 价格&库存
很抱歉,暂时无法提供与“0159-24”相匹配的价格&库存,您可以联系我们找货
  • 1+3334.553141+432.65552
