0253-02C
0253-02C
    GREENLEECOMMUNICATIONS(格林利)
    NUT DRIVER SET HEX SOCKET 7PC
0253-02C 数据手册
NUT DRIVERS,SET, 7 PC-METRIC 7-Piece Nut Driver Set (75mm Shank): Sizes 5mm,5.5mm, 6mm, 7mm, 8mm, 9mm & 10mm Cat No: 0253-02C UPC No: 783310892250 Description • • • • • • • • Rugged hollow shaft for screw clearance Heavy-duty construction for longer life Handle and shaft marked for easy identification of nut driver size Precision 6-point sockets for accurate fastener fit High-grade, rust resistant, chrome-plated finish Soft, cushioned grip for extra comfort and torque Exceeds ASME/ANSI specifications. Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • • Finish : Chrome Plated Includes : Sizes 5 MM, 5.5 MM, 6 MM, 7 MM, 8 MM, 9 MM And 10 MM Number Of Pieces : 7 Shank Length : 75.000 MM Shank Type : Hollow Standard : ASME/ANSI Type : Metric, Heavy Duty Weight : 1.650 LB (0.750 KG)
0253-02C 价格&库存
很抱歉,暂时无法提供与“0253-02C”相匹配的价格&库存,您可以联系我们找货
