0253-06NH-6
0253-06NH-6
    GREENLEECOMMUNICATIONS(格林利)
    NUT DRIVER SET HEX SOCKET 2PC
0253-06NH-6 数据手册
NUT DRIVERS,NH,SET,6",2 PC 2-Piece Nut Holding Driver Set (6 Shank):Sizes 1/4 & 5/16 Cat No: 0253-06NH-6 UPC No: 783310106296 Description • • • • • • • • • Precision tapered socket holds nut for one-handed operation Patent pending non-magnetic design will not pick up metal chips Rugged hollow shaft for screw clearance Handles color-coded and marked for easy identification Cushioned grip for extra comfort and torque High-grade rust resistant,chrome-plated finish Heavy-duty construction for longer life Designed to exceed ASME/ANSI torque requirements Lifetime Limited Warranty10~ Note: This is not an insulated tool Specifications • • • • • • • • • Finish : Chrome Plated Includes : Sizes 1/4 IN And 5/16 IN Number Of Pieces : 2 Overall Length : 10-1/4 IN (260.000 MM) Shank Length : 6.000 IN Shank Type : Hollow Standard : ASME/ANSI Type : Holding Weight : 0.290 LB (0.130 KG)
0253-06NH-6 价格&库存
很抱歉,暂时无法提供与“0253-06NH-6”相匹配的价格&库存,您可以联系我们找货
