0253-34C
0253-34C
    GREENLEECOMMUNICATIONS(格林利)
    NUT DRIVER HEX SCKT 5.5MM 7.32"
0253-34C 数据手册
NUT DRIVERS,5.5mmX75mm Heavy-Duty Nut Driver 5.5mm x75mm Cat No: 0253-34C UPC No: 783310892298 Description • • • • • • • • • Rugged hollow shaft for bolt clearance Heavy-duty construction for longer life Handle color marked for easy identification of nut driver size Precision 6-point sockets for accurate fastener fit High-grade, rust resistant, chrome-plated finish Soft, cushioned grip for extra comfort and torque Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • • Drive Size : 5.500 MM Finish : Chrome Plated Overall Length : 7-5/16 IN (18.600 CM) Shank Length : 75.000 MM Shank Type : Hollow Standard : ASME/ANSI Type : Metric, Heavy Duty Weight : 0.200 LB (0.090 KG)
0253-34C 价格&库存
很抱歉,暂时无法提供与“0253-34C”相匹配的价格&库存,您可以联系我们找货
