0253-36C
0253-36C
    GREENLEECOMMUNICATIONS(格林利)
    NUT DRIVER HEX SOCKET 7MM 7.32"
0253-36C 数据手册
NUT DRIVERS,7mmX75mm Heavy-Duty Nut Driver 7.0mm x75mm Cat No: 0253-36C UPC No: 783310892311 Description • • • • • • • • • Rugged hollow shaft for bolt clearance Heavy-duty construction for longer life Handle color marked for easy identification of nut driver size Precision 6-point sockets for accurate fastener fit High-grade, rust resistant, chrome-plated finish Soft, cushioned grip for extra comfort and torque Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • • Drive Size : 7.000 MM Finish : Chrome Plated Overall Length : 7-5/16 IN (18.600 CM) Shank Length : 75.000 MM Shank Type : Hollow Standard : ASME/ANSI Type : Metric, Heavy Duty Weight : 0.200 LB (0.090 KG)
0253-36C 价格&库存
很抱歉,暂时无法提供与“0253-36C”相匹配的价格&库存,您可以联系我们找货
