0254-43
0254-43
    GREENLEECOMMUNICATIONS(格林利)
    HEX KEY T-HANDLE 7/64" 5.75"
0254-43 数据手册
WRENCH,T-HANDLE,7/64" T-Handle Wrench, 7/64 Cat No: 0254-43 UPC No: 783310135012 Description • • • • • • • Heat-treated and tempered for extra strength and durability Exceeds ASME/ANSI specifications Ergonomic molded grips formax torque & comfort Ball end allows up to 30 degrees misalignment Square-cut end for high torque applications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • Handle Type : T-Handle, Ergonomic Molded Grips Overall Length : 5-3/4 IN (14.600 CM) Size : 7/64 IN Standard : ASME/ANSI Type : Hex Key Driver Weight : 0.070 LB (0.030 KG)
0254-43 价格&库存
很抱歉,暂时无法提供与“0254-43”相匹配的价格&库存,您可以联系我们找货
