0254-48
0254-48
    GREENLEECOMMUNICATIONS(格林利)
    HEX KEY T-HANDLE 7/32 7
0254-48 数据手册
WRENCH,T-HANDLE,7/32" T-Handle Wrench, 7/32 Cat No: 0254-48 UPC No: 783310135067 Description • • • • • • • Heat-treated and tempered for extra strength and durability Exceeds ASME/ANSI specifications Ergonomic molded grips formax torque & comfort Ball end allows up to 30 degrees misalignment Square-cut end for high torque applications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • Handle Type : T-Handle, Ergonomic Molded Grips Overall Length : 7.000 IN (17.800 CM) Size : 7/32 IN Standard : ASME/ANSI Type : Hex Key Driver Weight : 0.160 LB (0.070 KG)
0254-48 价格&库存
很抱歉,暂时无法提供与“0254-48”相匹配的价格&库存,您可以联系我们找货
