0254-51
0254-51
    GREENLEECOMMUNICATIONS(格林利)
    HEX KEY T-HANDLE 3/8" 8"
0254-51 数据手册
WRENCH,T-HANDLE,3/8" T-Handle Wrench, 3/8 Cat No: 0254-51 UPC No: 783310891970 Description • • • • • • • Heat-treated and tempered for extra strength and durability Exceeds ASME/ANSI specifications Ergonomic molded grips formax torque & comfort Ball end allows up to 30 degrees misalignment Square-cut end for high torque applications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • Handle Type : T-Handle, Ergonomic Molded Grips Overall Length : 8.000 IN (20.300 CM) Size : 3/8 IN Standard : ASME/ANSI Type : Hex Key Driver Weight : 0.440 LB (0.200 KG)
0254-51 价格&库存
很抱歉,暂时无法提供与“0254-51”相匹配的价格&库存,您可以联系我们找货
