0351-08M
0351-08M
    GREENLEECOMMUNICATIONS(格林利)
    PLIERS LONG NOSE 8.56"
0351-08M 数据手册
PLIERS,LONG NOSE,8" MOLDED Long Nose Pliers/Side Cutting 8 molded grip Cat No: 0351-08M UPC No: 783310547198 Description • • • • • • • Forged from chrome vanadium steel for greater durability and strength Effectively cuts both solid & stranded copper wire Serrated jaws and laser-hardened cutting edges for optimum cutting and gripping performance Through-hardened steel for longer life Exceeds ASME/ANSI specifications Rugged riveted construction for smooth precise action Lifetime limited warranty Specifications • • • • • • • • Application : For Effectively Cuts Both Solid And Stranded Copper Wire Grip Length : 8.000 IN Molded Handle Type : Custom Grip Material : Chrome Vanadium Steel Overall Length : 8-9/16 IN (21.700 CM) Standard : ASME/ANSI Type : Long Nose Side Cutting Weight : 0.640 LB (0.290 KG)
0351-08M 价格&库存
很抱歉,暂时无法提供与“0351-08M”相匹配的价格&库存,您可以联系我们找货
