0354-22
0354-22
    GREENLEECOMMUNICATIONS(格林利)
    WRENCH COMBINATION 15/16" 12.68"
0354-22 数据手册
WRENCH,COMBO RATCHET 15/16" Combination Ratcheting Wrench15/16 Cat No: 0354-22 UPC No: 783310892724 Description • • • • • • • • Compact reversible switch allows a 15° offset of the boxend for clearance of obstacles Five-degree ratcheting design for versatility and ease of use in tight spaces Polished chrome finish forsuperior corrosion resistance Precision heads for accurate fastener fit Hardened for durability and longer life Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • Application : For Versatility And Ease Of Use In Tight Spaces And Accurate Fastener Fit Drive Size : 15/16 IN Finish : Polished Chrome Overall Length : 12-11/16 IN (32.200 CM) Standard : ASME/ANSI Type : Standard, Combination Weight : 1.100 LB (0.500 KG)
0354-22 价格&库存
很抱歉,暂时无法提供与“0354-22”相匹配的价格&库存,您可以联系我们找货
