0354-55
0354-55
    GREENLEECOMMUNICATIONS(格林利)
    WRENCH COMBINATION 10MM 6.18"
0354-55 数据手册
WRENCH,COMBO RATCHET 10mm Combination Ratcheting Wrench10mm Cat No: 0354-55 UPC No: 783310892816 Description • • • • • • • • Compact reversible switch allows a 15° offset of the boxend for clearance of obstacles Five-degree ratcheting design for versatility and ease of use in tight spaces Polished chrome finish forsuperior corrosion resistance Precision heads for accurate fastener fit Hardened for durability and longer life Exceeds ASME/ANSI specifications Lifetime limited warranty Note: This is not an insulated tool Specifications • • • • • • • Application : For Versatility And Ease Of Use In Tight Spaces And Accurate Fastener Fit Drive Size : 10.000 MM Finish : Polished Chrome Overall Length : 6-3/16 IN (15.700 CM) Standard : ASME/ANSI Type : Metric, Combination Weight : 0.140 LB (0.060 KG)
0354-55 价格&库存
很抱歉,暂时无法提供与“0354-55”相匹配的价格&库存,您可以联系我们找货
