166/GR
166/GR
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE 26AWG GRAY
166/GR 数据手册
WIRE FERL INSUL Insulated Wire Ferrules Cat No: 166/GR UPC No: 783310048350 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Gray Color Code : Old DIN Standard Dimension Inches L2 : 0.236 IN (6.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K1GL, K32GL, Die 03283 Size : 0.409 IN (10.400 MM) Overall Length, 0.236 IN (6.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 0.140 SQ-MM Wire Type : Stranded
166/GR 价格&库存
很抱歉,暂时无法提供与“166/GR”相匹配的价格&库存,您可以联系我们找货
