168/6
168/6
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE 22AWG GREEN
168/6 数据手册
WIRE FERL INSUL Insulated Wire Ferrules Cat No: 168/6 UPC No: 783310029755 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Light Green Color Code : French Standard Dimension Inches L2 : 0.236 IN (6.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K1GL, K32GL, K30GL, Die 03283 Size : 0.433 IN (11.000 MM) Overall Length, 0.236 IN (6.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 22 AWG (0.340 SQ-MM) Wire Type : Stranded
168/6 价格&库存
很抱歉,暂时无法提供与“168/6”相匹配的价格&库存,您可以联系我们找货
