173/BL
173/BL
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE 14AWG BLUE
173/BL 数据手册
WIRE FERL INSUL Insulated Wire Ferrules Cat No: 173/BL UPC No: 783310048572 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Blue Color Code : Old DIN Standard Dimension Inches L2 : 0.709 IN (18.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K1GL, K32GL, K36GL, K30GL, Die 03283 Size : 0.984 IN (25.000 MM) Overall Length, 0.709 IN (18.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 14 AWG (2.500 SQ-MM) Wire Type : Stranded
173/BL 价格&库存
很抱歉,暂时无法提供与“173/BL”相匹配的价格&库存,您可以联系我们找货
