45509
45509
    GREENLEECOMMUNICATIONS(格林利)
    工具 模具组套 用于 接片和端子,10-22 AWG
45509 数据手册
Tel.: USA & Canada 800-435-0786 • Fax: USA 800-451-2632, Canada 800-524-2853 International Tel.: +1-815-397-7070 • Fax: +1-815-397-9247 • www.greenlee.textron.com Punchdown Tool Cat./UPC No. 46020 46021 46023 46022 46024 46025 46026 Description Punchdown Tool Only Punchdown Tool w/66 blade Punchdown Tool w/110 blade 66 Style Blade 110 Style Blade BIX Style Blade Krone Style Blade With a rapid, 2-step process it precisely inserts the wire for a corrosion resistant termination and then trims off excess wire. • Spring loaded for a fast, low-effort wire seating and termination. • Adjustable low and high impact force settings. • Color-coded yellow on the cut side of the tool. • Terminates 66, 110, BIX and Krone cross-connect and wall jacks. • Bayonet style blade locking mechanism. • Simplified internal impact mechanism eliminates jamming. • Neoprene® pad for shock absorption. • Spare blade storage in the handle. • Made in the USA. Clip-On Twisted Pair Kit The Clip-On Twisted Pair Kit combines the most commonly used tools for terminating voice and data cabling into an easy to carry kit that mounts on the contractor’s belt. • The kit includes the 110 Punchdown Tool, Electrician’s Snips and Twisted Pair Stripper. It provides the most essential tools right at the installer’s side. • Rugged Cordura® material is built to last, lowering replacement costs and inconvenience. • Heavy-duty metal clip snaps over the installer’s belt so that the kit can be removed without removing the belt. • Side holsters allow the installer to carry a flashlight — Greenlee #46500 POCKET-LIGHT, MINI MAGLIGHT®, or Brinkman® and a favorite screwdriver. Cat./UPC No. 46010 Screwdriver not included. 45272 46020 46021 46022 46023 46024 46025 46026 45086 45579 46500 Description Clip-On Twisted Pair Kit including Punchdown Tool with 110 blade, Snips, Twisted Pair Stripper and Flashlight Pouch Only Punchdown Tool Punchdown Tool with 66 Blade Replacement 66 Blade Punchdown Tool with 110 Blade Replacement 110 Blade Replacement BIX Blade Replacement Krone Blade Electrician‘s Snips Twisted Pair Stripper Pocket-Light Flashlight Cable TV Coax Termination Kit This all-in-one kit contains the tools and connectors necessary for installing a Cable TV system. • Durable Cordura® Plus zipper case protects and organizes tools – includes a see-through pouch for storing connectors. • An outside pocket allows convenient storage of instruction manuals or worksite documents. Cat./UPC No. 45466 Description Cable TV Coax Termination Kit Kit includes: Cat./UPC No. 45482 45578 46801 184 45516 45324 45476 Description Cable Cutter Kwik Stripper CATV Stripper with 2 level stripper for RG6, RG59, RG7, RG11 Kwik Cycle 9” Crimp Frame w/ die set for F-style connectors on RG6 and RG59 cable F Connector Insertion Tool F Style Crimp-on Connectors for Quad-shield RG6 Zipper Case Qty. 1 1 1 1 25 1 Cable TV Coax Termination and Test Kit This kit contains the basic tools, connectors and testers for installing and testing a Cable TV system. • 402 series Cable TV tone test set uses both electromagnetic and electrostatic pickup to tone through splitters, directional couplers and taps. • Durable Cordura® Plus zipper case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pocket allows convenient storage of instruction manuals or worksite documents. Cat./UPC No. 45467 Data · Signal · Voice Tel.: USA & Canada 800-435-0786 • Fax: USA 800-451-2632, Canada 800-524-2853 International Tel.: +1-815-397-7070 • Fax: +1-815-397-9247 • www.greenlee.textron.com Description Cable TV Coax Termination and Test Kit Kit includes: Cat./UPC No. 45482 45578 46801 45516 45323 402T/60376 402R/60377 45477 Description Cable Cutter Kwik Stripper CATV Stripper, 2 Level Stripper for RG6, RG59, RG7, RG11 Kwik Cycle 9 Inch Crimp Frame w/ Die Set for F Style Connectors on RG6 and RG59 Cable F Connector Insertion Tool F Style Crimp-on Connectors for Quad-shield RG6 Cable TV Tone Generator Cable TV Tone Receiver Zipper Case Qty. 1 1 1 1 25 1 1 1 Coax/Twisted Pair LAN Termination and Test Kit This all-in-one-kit provides the essential tools and testers necessary for maintaining a Local Area Network. Kit contains tools, connectors and testers for twisted pair and coax Ethernet (Thinnet) cabling. • Durable Cordura® Plus carrying case protects and organizes tools and includes see-through pouches for storing connectors. • Case has durable handles and eyelets for adding a shoulder strap. • Outside pockets provide convenient storage locations for instruction manuals or worksite documents. Cat./UPC No. 45468 Description Coax/Twisted Pair LAN Termination Kit and Test Kit Kit includes: Cat./UPC No. 45482 45579 46023 46022 45575 45577 46800 45481 AT8/08693 200EP/08671 45781 45760 45478 Description Cable Cutter Kwik Stripper Twisted Pair Stripper Punchdown Tool with 110 Blade 66 Style Punchdown Blade Telephone Ratchet Crimper for 4, 6 and 8 Position Modular Plugs Kwik Stripper Coax Stripper, 3 Level Kwik Cycle 9” Crimp Frame with Die Set for BNC Style Connectors on Thinnet RG8 Cable Center Conductor Cutter for Coax Cable AdapToner Modular Breakout Tone Generator Inductive Amplifier Probe BNC Style Coax Connectors for RG58 Thinnet Plenum Cable Category 5 Connectors, RJ45, 8 Position Carrying Case Qty. 1 1 1 1 1 1 1 1 1 1 20 50 1 185 Tel.: USA & Canada 800-435-0786 • Fax: USA 800-451-2632, Canada 800-524-2853 International Tel.: +1-815-397-7070 • Fax: +1-815-397-9247 • www.greenlee.textron.com Voice and Category 5 Data Termination Kit This handy kit includes the tools and connectors necessary for installing a voice and data network. • Durable Cordura® Plus zipper case protects and organizes tools and includes see-through pouches for storing connectors. • Outside pocket allows convenient storage of instruction manuals or worksite documents. Cat./UPC No. 45469 Description Voice and Category 5 Data Termination Kit Kit includes: Cat./UPC No. 45482 45579 46023 45575 45760 45751 45479 Description Cable Cutter Kwik Stripper Twisted Pair Stripper Punchdown Tool with 110 Blade Telephone Ratchet Crimper for 4, 6 and 8 Position Modular Plugs RJ45, 8 Position Category 5 Connectors RJ12, 6 Position, 6 Conductor, Flat Cable Connectors Zipper Case Qty. 1 1 1 1 50 50 1 Category 5 Termination and Test Kit This handy kit includes the tools, connectors and testers necessary for installing a CAT 5 network. • Durable Cordura® Plus zipper case protects and organizes tools and includes see-through pouches for storing connectors. • Outside pocket allows convenient storage of instruction manuals or worksite documents. Cat./UPC No. 45470 Description Category 5 Data Termination and Test Kit Kit includes: Cat./UPC No. 45482 45579 46023 45575 45760 468T/60379 468R/60380 45485 186 Description Cable Cutter Kwik Stripper Twisted Pair Stripper Punchdown Tool with 110 Blade Telephone Ratchet Crimper for 4, 6 and 8 Position Modular Plugs RJ45, 8 Position Category 5 Connectors Modular Cable Tester Transmitter with Tone Generator Modular Cable Tester Receiver Zipper Case Qty. 1 1 1 1 50 1 1 1
45509 价格&库存
很抱歉,暂时无法提供与“45509”相匹配的价格&库存,您可以联系我们找货
