46601
46601
    TEMPOCOMMUNICATIONS
    PRO COAX TOOL KIT
46601 数据手册
46601 Professional Coax Cable Tool Kit The Essential Tool Kit for Coaxial Cable Installation and Repair 6 tools in one convenient Grip Pack Pouch. Finally, a kit every professional cable technician needs for coaxial repair and installation. The Greenlee 46601 Coaxial Cable Tool Kit contains six essential tools needed to strip, cut and terminate coaxial cables. The kit also includes a custom molded, swivel Grip Pack holster that moves with you for extra comfort. Kit Consists of: • 8" Diagonal Cutting Pliers with Dipped Grip Handles • RG 59/6/6Q – 7/11 Coaxial Cable Stripper • RG 59/6/6Q – 7/11 Coaxial Compression Tool • 6-in-1 Multi-Tool, Cushion Grip Screwdriver / Nutdriver • LED Penlight • Combo Ratcheting and Open Ended 7/16" Wrench • Custom Grip Pack Pouch with Quick Release Belt Clip www.greenlee.com Features QTY. 1 45591 RG 59/6/6Q – 7/11 Coaxial Cable Stripper • Works with a variety of coaxial cables (RG 59/6/6Q). • Quickly strips outer sheath and dielectric. • Lightweight, single-handed operation with spring-loaded handles. 1 PA70020 RG 59/6/6Q – 7/11 Coaxial Compression Tool • Works with a variety of coaxial connectors (RG 59/6/6Q, RG 7/11) • Crimps both indoor and weather-resistant coaxial compression connectors. 1 0153-42C 6-in-1 Multi-Tool • Quickly and easily drives nuts and screws. • Sizes: Hex Nut: 1/4" and 5/16" Phillips Screw: #1 and #2 Flat Screw: 3/16" and 1/4" 1 FL2AAP LED Penlight • Sealed against water and dust. • 50,000 Hours, 7 Lumen. • 14-15 hours battery life, AAA batteries. 1 0354-14 Combo Ratcheting and Open Ended 7/16" Wrench • Compact, reversible switch with a 15 degree offset of the box end for clearance of obstacles. • Polished chrome finish for corrosion resistance. • Exceeds ASME/ANSI specifications. 1 PA5000 Custom Grip Pack Pouch with Quick Release Belt Clip • Custom-molded PVC pouch securely holds tools. • Quick-release belt clip for fast operation. • Swivel allows pouch to move for added comfort. 1 Ordering Information DESCRIPTION 46601 01292 Professional Coax Cable Tool Kit QTY. 1 DISTRIBUTOR INFORMATION: www.greenlee.com • MA-5839 10/12 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2012 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. INTERNATIONAL UPC NO. Tel: +1.815.397.7070 Fax: +1.815.397.9247 CAT NO. CANADA 8" Diagonal Cutting Pliers • Cuts most hardened wire, ACSR, bolts, screws, and nails. • Laser-hardened edges and chrome-vanadium steel construction for strength and durability. • Exceeds ASME/ANSI specifications. USA 0251-08D Tel: 866.384.8813 Fax: 800.524.2853 DESCRIPTION Tel: 800.435.0786 Fax: 800.451.2632 CAT NO.
46601 价格&库存
很抱歉,暂时无法提供与“46601”相匹配的价格&库存,您可以联系我们找货
