474/10
474/10
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE DIN 12AWG GRAY
474/10 数据手册
WIRE FERL INSUL Insulated Wire Ferrules Cat No: 474/10 UPC No: 783310045663 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Gray Color Code : DIN 46228, Part 4 Dimension Inches L2 : 0.394 IN (10.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K32GL, K36GL, K30GL, Die 03283 Size : 0.699 IN (17.000 MM) Overall Length, 0.394 IN (10.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 12 AWG (4.000 SQ-MM) Wire Type : Stranded
474/10 价格&库存
很抱歉,暂时无法提供与“474/10”相匹配的价格&库存,您可以联系我们找货
