540-20P
540-20P
    GREENLEECOMMUNICATIONS(格林利)
    PRO INSTALLER STIX KIT 20
540-20P 数据手册
PRO INSTALLER STIX KIT - 20' Professional Installers Kit: (3)-1/4 x 4' Fish Stix sections, (2)-3/16 x 2' Glo Stix Sections & (1)-5/32 x 4' Glo Stix Section, (1) whisk, (1) J hook, (1) bullet nose Cat No: 540-20P UPC No: 783310129196 Description • • • • • • Luminescent fiberglass rodsglow in the dark to make fishing voice, data and video wires easier in dark spaces, such as above ceilings, in walls, and below sub-floors More flexible for fishing in walls through outlet box holes Sturdy, steel-threaded connectors are interchangeable with Greenlee 1/4 IN (6.4 mm) Fish Stix Clear, non-metalic storagetube keeps Glo Stix charged and ready to use 200 lbs. (0.9 kN) maximum pulling strength Optional Whisk Nose Tip isavailable for fishing over obstacles, and can be used to guide extended Glo Stix sidewaysabove ceilings by rotating. Can also be used to fish longerlengths by providing a tip that can be snagged from the opposite direction with another extended Fish or Glo Stix with a hook nose tip Specifications • • • • • • • • • • Accessory : 10497 Hook Nose Tip, 10498 Bullet Nose Tip, 11426 Whisk Nose Tip Diameter : 5/32 IN (4.000 MM) Length : 6.000 FT (1.800 M) Minimum Bend Radius : 3-1/2 IN (89.000 MM) Replacement Part : 11583 1/4 IN X 4 FT Fish StixSection, 11584 1/4 IN X 6 FT Fish Stix Section, 12920 3/16 IN X 20 IN Glo Stix Section, 11585 3/16 IN x 3 FT Glo Stix Section, 11427 3/16 IN x 5 FT Glo Stix Section, 12922 5/32 INX 4 FT Glo Stix Section, 89803 5/32 IN X 6 FT Section Length : (3) 1/4 IN X 4 FT Fish Stix Sections, (2) 3/16 IN X 2 FT Glo Stix Sections, (1) 5/32 IN X4 FT Glo Stix Section Sections : 6 Sub Brand : Glo Stix Tensile Strength : 200.000 LB (0.900 KN) MaximumPulling Strength Weight : 0.400 LB (0.200 KG)
540-20P 价格&库存
很抱歉,暂时无法提供与“540-20P”相匹配的价格&库存,您可以联系我们找货
540-20P
  • 3+844.795523+105.71723
